scream 4 LLSB dumps submitted
swarm87
submitted for both the hd and 4k, should mention that they were submitted from the lionsgate limited steelbook, not sure if the standard editions will use the same discs
MrPenguin
Re: scream 4 LLSB dumps submitted
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?swarm87 wrote: Mon Jun 08, 2026 8:55 pm submitted for both the hd and 4k, should mention that they were submitted from the lionsgate limited steelbook, not sure if the standard editions will use the same discs
If this doesn't work, could you also upload your TGZ dump files into a file host such as OneDrive or Google Drive please, and then reply with public download lniks for them? This would allow people to try adding your disks to the public KEYDB.cfg file as well.
briansemerick
this worked for my Scream 4! Thanks!MrPenguin wrote: Mon Jun 08, 2026 10:46 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?swarm87 wrote: Mon Jun 08, 2026 8:55 pm submitted for both the hd and 4k, should mention that they were submitted from the lionsgate limited steelbook, not sure if the standard editions will use the same discs
aimforsilence
I've got the normal non-steelbook edition and it won't load with the latest keydb file.
MrPenguin
Then can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.aimforsilence wrote: Tue Jun 09, 2026 10:45 pm I've got the normal non-steelbook edition and it won't load with the latest keydb file.
aimforsilence
What's the process for doing this? I'm newer here and have never done that before.MrPenguin wrote: Tue Jun 09, 2026 11:37 pmThen can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.aimforsilence wrote: Tue Jun 09, 2026 10:45 pm I've got the normal non-steelbook edition and it won't load with the latest keydb file.
MrPenguin
Has MakeMKV generated a TGZ dump file for your disk? Because if so, the process is precisely as I have described above.aimforsilence wrote: Wed Jun 10, 2026 12:49 pmWhat's the process for doing this? I'm newer here and have never done that before.MrPenguin wrote: Tue Jun 09, 2026 11:37 pm Then can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.
aimforsilence
Then here is a link to the TGZ dump fileMrPenguin wrote: Wed Jun 10, 2026 2:14 pmHas MakeMKV generated a TGZ dump file for your disk? Because if so, the process is precisely as I have described above.aimforsilence wrote: Wed Jun 10, 2026 12:49 pmWhat's the process for doing this? I'm newer here and have never done that before.MrPenguin wrote: Tue Jun 09, 2026 11:37 pm Then can you upload your TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? And also email your dump to svq@makemkv.com, of course.
https://1drv.ms/u/c/f78d1e813f837b48/IQ ... o?e=nIrlsl
MrPenguin
