GET CARTER 4K
gordonepalmer
GET CARTER 4K
Post by gordonepalmer »
Just picked up Get Carter 4k.
it plays fine on my 4k blu ray player but I get the "no disc inserted" message when using makemkv.
The disc spins for 20-30 seconds then the error message.
I've ripped hundreds of 4k's and I think this is the first time I've had this particular issue reading a disc.
I've tried power cycling my blu ray drive and restarting makemkv but to no avail.
I'm running the latest version 1.18.2
Any suggestions?
Re: GET CARTER 4K
Try gently cleaning the disc. I like to use liquid dish soap and warm water.
Here's a more detailed post I've made on this topic: https://forum.makemkv.com/forum/viewtopic.php?p=186783#p186783
gordonepalmer
Re: GET CARTER 4K
I cleaned it carefully but still no joy
After spinning and trying to read, it stops and ejects the disc from the blu ray drive
I've never had that happen before
EvilWarMachine
Re: GET CARTER 4K
Post by EvilWarMachine »
I am getting this exact thing with my BFI Get Carter UHD. Windows is unable to read the disk and it gets ejected.
I have tried it in my PIONEER BDR-BDS7 and on a MAC with a PIONEER BDR-US04.
The disk plays fine in my console.
Has anyone been able to get this disk to work?
MrPenguin
Re: GET CARTER 4K
Post by MrPenguin »
EvilWarMachine wrote: Mon Jun 08, 2026 10:04 am I am getting this exact thing with my BFI Get Carter UHD. Windows is unable to read the disk and it gets ejected.
There's an entry in KEYDB.cfg for a recent "Get Carter" disk:
0x28B20939259AAC0ED9A2D903861F5BC50CB1C6F5 = Get Carter UHD (Get Carter - 4K UHD) | D | 2025-07-30 | ...
It's obviously impossible for you to confirm that this matches your disk unless your drive can read it first, but it suggests that someone may have succeeded.
EvilWarMachine
Re: GET CARTER 4K
Thanks for the reply.
I'm guessing that is the Warner Bros US disk? I have the UK BFI disk with the exact same issue as the OP.
It could be a drive issue as both the drives I have tried it on are Pioneer.
Has anyone successfully managed to read the BFI disk? If so, what drive did you use?
MrPenguin
Re: GET CARTER 4K
Post by MrPenguin »
EvilWarMachine wrote: Mon Jun 08, 2026 12:40 pm I'm guessing that is the Warner Bros US disk? I have the UK BFI disk with the exact same issue as the OP.
Hmm, maybe. The only UHD versions of "Get Carter" in KEYDB.cfg are dated "2022-06-09" and "2025-07-30" respectively. Does either of these sound like it might be yours?
MrPenguin
Re: GET CARTER 4K
Post by MrPenguin »
EvilWarMachine wrote: Mon Jun 08, 2026 12:40 pm I have tried it in my PIONEER BDR-BDS7 and on a MAC with a PIONEER BDR-US04.
Out of interest, is that BDR-BDS7 drive cross-flashed for UHD support? I am wondering if this could be some kind of rare edge-case where a drive which naturally supports UHD (e.g. a BU40N) would work better?
Also, I'm unfamiliar with a BDR-US04 drive. Do you mean a BDR-UD04?
