Public KeyDB Disc Submissions
Talamera
Post by Talamera »
I indeed had set the wrong path. The keydb.cfg must be placed at my F:/Bluray/. Now it works. Thanks for the info.
cladefe60
Post by cladefe60 »
Oggetto: SCREAM7
HO INVIATO Dump sull'email sviluppatori ma niente. .voi qualcuno con il mio stesso problema su questo disco ?
cladefe60
Post by cladefe60 »
OGGETTO: INVIO DATI DISCO
DISCO: SCREAM 7 (2026) UHD ITALIANO
COME POSSO INVIARE IL FILE TGZ NN ME LO FA COPIARE
cladefe60
Post by cladefe60 »
OGGETTO: INVIO DUMP DISCO
FILM: SCREAM 7 UHD ITALIANO
FILE :MKB20_v82_Scream_7_A991
FootFungus07
Post by FootFungus07 »
The Boys in the Band Cinematographe 4K UHD TGZ & MKB_RO
Label: CIN_034_Boys_in_the_Band
TGZ: MKB20_v82_Boys_in_the_Band_A571.tgz
Timestamp: 2026-04-06 14:46:44
Protection: AACS2.0/C v82
Data capacity: 61.12 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Did you sync the public keyDB within the last 15 minutes? Yes
MKB_RO Link: https://drive.google.com/file/d/186QMQh ... drive_link
TGZ File Link: https://drive.google.com/file/d/1RaJhDv ... drive_link
Cub40i
Post by Cub40i »
Disc type: BD-ROM
Disc ID: Unknown (If there is a clear method to get, please notify)
Disc dump filename: MKB_v82_Avatar-_Fire_and_Ash_323E.tgz
Drive: BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KL6OC5D4307d
Drive firmware: 1.02 2118-10-29
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/16WrqSD ... share_link
Disc dump link: https://drive.google.com/file/d/1qCUajp ... share_link
FootFungus07
The Mangler - Vinegar Syndrome 4K UHD TGZ File and MKB_RO File
Label: VS537UHD
TGZ File: MKB20_v82_VS537UHD_A59F.tgz
Timestamp: 2026-04-04 21:04:42
Data capacity: 61.65 Gb
Number of layers: 2
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1bi1n_o ... drive_link
TGZ File Link: https://drive.google.com/file/d/1WeLFmH ... drive_link
FootFungus07
Nightwatch Vinegar Syndrome TGZ & MKB_RO
Label: VS535UHD
TGZ File: MKB20_v82_VS535UHD_205F.tgz
Timestamp: 2026-04-07 19:00:15
Data capacity: 70.18 Gb
Number of layers: 3
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1RWoGQT ... drive_link
TGZ File Link: https://drive.google.com/file/d/1BdE0kU ... drive_link
FootFungus07
Human Lanterns - Vinegar Syndrome TGZ and MKB_RO files
Label: VS536UHD
TGZ File: MKB20_v82_VS536UHD_6593.tgz
Timestamp: 2026-04-17 13:14:46
Data capacity: 70.75 Gb
Number of layers: 3
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1865POX ... drive_link
TGZ File Link: https://drive.google.com/file/d/1R1Z7bx ... drive_link
cladefe60
SCREAM 7 UHD
Post by cladefe60 »
FILM: SCREAM 7 UHD ITALIANO -INGLESE
FILE DUMP: MKB20_v82_Scream_7_A99
LETTORE : VERBATIM 43888
FIRMWARE 1.03
MrPenguin
Re: SCREAM 7 UHD
Post by MrPenguin »
cladefe60 wrote: Sun Jun 07, 2026 5:21 pm FILM: SCREAM 7 UHD ITALIANO -INGLESE
FILE DUMP: MKB20_v82_Scream_7_A991
Questo non serve a nulla a meno che tu non carichi anche il tuo file di dump su un servizio di hosting come Google Drive o OneDrive e poi pubblichi qui un link per il download pubblico.
Dovresti inoltre inviare quel file TGZ via email a svq@makemkv.com.
gpixel
Post by gpixel »
Mobile Suit Gundam GQuuuuuuX Beginning (2026), Japanese UHD
Disc type: UHD
Disc ID: 0c9e8cea1662bce91b2761ea82acdaafafb0cc7a
Disc dump filename: MKB20_v82_Mobile_Suit_Gundam_GQuuuuuuX_-Beginning-_UHD_AF62.tgz
Drive: MT1959
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1Pnpc-E ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1pgbA7M ... sp=sharing
Please note it's first time attempting this, so do flag if there are any issues - thank you!
keydb_helper
Post by keydb_helper »
FootFungus07 wrote: Sun Jun 07, 2026 1:20 pm The Boys in the Band Cinematographe 4K UHD TGZ & MKB_RO
FootFungus07 wrote: Sun Jun 07, 2026 2:55 pm The Mangler - Vinegar Syndrome 4K UHD TGZ File and MKB_RO File
Label: VS537UHD
FootFungus07 wrote: Sun Jun 07, 2026 2:59 pm Nightwatch Vinegar Syndrome TGZ & MKB_RO
Label: VS535UHD
FootFungus07 wrote: Sun Jun 07, 2026 3:10 pm Human Lanterns - Vinegar Syndrome TGZ and MKB_RO files
Label: VS536UHD
Thanks for the submissions, all four titles have been added to the public keydb.
Almost all of your recent titles were great candidates for SamuriHL's KeyDB Assistant as the media keys were already known to the keydb so the tool would've derived the required disc keys for you. As you use Windows there should be no barrier to running this tool before future submissions. It really is quicker and easier for everyone if we can reduce the number of avoidable posts to this thread.
Obviously if your discs remain unsupported after running the KeyDB Assistant you are welcome to post your disc dump files to this thread.
Cub40i wrote: Sun Jun 07, 2026 2:02 pm Disc ID: Unknown (If there is a clear method to get, please notify)
Hey Cub40i, I briefly mentioned the disc ID calculation in the opening post of this thread:
Please include the disc ID in your submission template. The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file in your discs AACS folder. Many tools can calculate this hash, please google the instructions for your specific platform.
As you use macOS you should be able to calculate the disc ID via the standard sha1sum/shasum utilities. I haven't used macOS for several years but you should be able to run a command like this in the terminal to get the disc ID:
# Untested and you'll want to adjust the disc volume label accordingly
sha1sum /Volumes/JAWS/AACS/Unit_Key_RO.inf
# Alternative as I forget which SHA utility is included by default and which I probably installed via MacPorts/Homebrew
shasum -a 1 /Volumes/JAWS/AACS/Unit_Key_RO.inf
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Here's a reasonable webpage for how to do a SHA1 checksum on macOS.
https://mofa.cocolabs.dev/guides/how_to_sha1.html
The short answer is in Terminal do:
shasum -a 1 /path/to/your/file
cladefe60
Post by cladefe60 »
Scream 7. UHD
Lettore: Verbatim 43888
Firmware 1 03
Libre Drive
Link file tgz:
https://drive.google.com/file/d/1cie8ze ... p=drivesdk
