Public KeyDB Disc Submissions
gpixel
Post by gpixel » Mon Jun 08, 2026 2:11 am
Mobile Suit Gundam GQuuuuuuX Beginning (2026), Japanese UHD
Disc type: UHD
Disc ID: 0c9e8cea1662bce91b2761ea82acdaafafb0cc7a
Disc dump filename: MKB20_v82_Mobile_Suit_Gundam_GQuuuuuuX_-Beginning-_UHD_AF62.tgz
Drive: MT1959
Drive firmware: 1.01
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1Pnpc-E ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1pgbA7M ... sp=sharing
Please note it's first time attempting this, so do flag if there are any issues - thank you!
keydb_helper
Post by keydb_helper » Mon Jun 08, 2026 2:35 am
FootFungus07 wrote: Sun Jun 07, 2026 1:20 pm The Boys in the Band Cinematographe 4K UHD TGZ & MKB_RO
Label: CIN_034_Boys_in_the_Band
TGZ: MKB20_v82_Boys_in_the_Band_A571.tgz
FootFungus07 wrote: Sun Jun 07, 2026 2:55 pm The Mangler - Vinegar Syndrome 4K UHD TGZ File and MKB_RO File
Label: VS537UHD
TGZ File: MKB20_v82_VS537UHD_A59F.tgz
FootFungus07 wrote: Sun Jun 07, 2026 2:59 pm Nightwatch Vinegar Syndrome TGZ & MKB_RO
Label: VS535UHD
TGZ File: MKB20_v82_VS535UHD_205F.tgz
FootFungus07 wrote: Sun Jun 07, 2026 3:10 pm Human Lanterns - Vinegar Syndrome TGZ and MKB_RO files
Label: VS536UHD
TGZ File: MKB20_v82_VS536UHD_6593.tgz
Thanks for the submissions, all four titles have been added to the public keydb.
Almost all of your recent titles were great candidates for SamuriHL's KeyDB Assistant as the media keys were already known to the keydb so the tool would've derived the required disc keys for you. As you use Windows there should be no barrier to running this tool before future submissions. It really is quicker and easier for everyone if we can reduce the number of avoidable posts to this thread.
Obviously if your discs remain unsupported after running the KeyDB Assistant you are welcome to post your disc dump files to this thread.
Cub40i wrote: Sun Jun 07, 2026 2:02 pm Disc ID: Unknown (If there is a clear method to get, please notify)
Hey Cub40i, I briefly mentioned the disc ID calculation in the opening post of this thread:
Please include the disc ID in your submission template. The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file in your discs AACS folder. Many tools can calculate this hash, please google the instructions for your specific platform.
As you use macOS you should be able to calculate the disc ID via the standard sha1sum/shasum utilities. I haven't used macOS for several years but you should be able to run a command like this in the terminal to get the disc ID:
# Untested and you'll want to adjust the disc volume label accordingly
sha1sum /Volumes/JAWS/AACS/Unit_Key_RO.inf
# Alternative as I forget which SHA utility is included by default and which I probably installed via MacPorts/Homebrew
shasum -a 1 /Volumes/JAWS/AACS/Unit_Key_RO.inf
Post by dcoke22 » Mon Jun 08, 2026 3:05 am
Here's a reasonable webpage for how to do a SHA1 checksum on macOS.
https://mofa.cocolabs.dev/guides/how_to_sha1.html
The short answer is in Terminal do:
shasum -a 1 /path/to/your/file
cladefe60
Post by cladefe60 » Mon Jun 08, 2026 4:32 am
Scream 7. UHD
Lettore: Verbatim 43888
Firmware 1 03
Libre Drive
Link file tgz:
https://drive.google.com/file/d/1cie8ze ... p=drivesdk
IdentityTheft
Post by IdentityTheft » Mon Jun 08, 2026 5:18 am
Disc type: UHD
Disc ID: 0a9fd4af0fa2f69d38814f5ff2fa2b730bd79c59
Disc dump filename: MKB20_v72_Top_Gun_071A
Drive: WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.proton.me/urls/ENC6BAKAGR#8EkXkjbQdNVO
Disc dump link: https://drive.proton.me/urls/7DYF299DRM#KeMk8ysVXyW3
keydb_helper
Post by keydb_helper » Mon Jun 08, 2026 6:36 am
cladefe60 wrote: Mon Jun 08, 2026 4:32 am Scream 7. UHD
Firmware 1 03
Libre Drive
Link file tgz: ...
Read the first post of this thread. No one can help you if your fucking link isn't publicly available. There is a reason for the submission template.
MrPenguin
Post by MrPenguin » Mon Jun 08, 2026 9:55 am
Grazie, e potresti anche modificare l'opzione "Condividi" per quel file in modo che tutti possano accedervi? I file su Google Drive sono privati ​​per impostazione predefinita, quindi al momento nessuno può scaricare il tuo file di dump.
FootFungus07
Post by FootFungus07 » Mon Jun 08, 2026 12:06 pm
[/quote]
OH Wild, I didn't know that tool existed - I'll have to give it a whirl - thank you! And thank you for dropping those discs in!
JSA_123
Post by JSA_123 » Mon Jun 08, 2026 5:34 pm
Disc type: BD-ROM
Disc ID: TWBS_5486_1
Disc dump filename: MKB_v82_TWBS_5486_1_E6E6
Drive: BD-RE ASUS SBW-06D2X-U 1.10 AFDL221226WLd
Drive firmware: 1.10
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://drive.google.com/file/d/1LdOWmx ... share_link
Disc dump link: https://drive.google.com/file/d/1kZnaxO ... share_link
JSA_123
Post by JSA_123 » Mon Jun 08, 2026 5:35 pm
Disc type: BD-ROM
Disc ID: TWBS_5486_2
Disc dump filename: MKB_v82_TWBS_5486_2_6C6C
MKB_RO.inf link: https://drive.google.com/file/d/1HzCXSo ... share_link
Disc dump link: https://drive.google.com/file/d/1i1BVak ... share_link
keydb_helper
Post by keydb_helper » Tue Jun 09, 2026 6:00 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v72_Top_Gun_071A
*MKB20_v82_ERASER_1FEE
*MKB20_v82_FIVE_EASY_PIECES_9250
*MKB20_v82_KNIGHT_OF_SEVEN_KINGDOMS_S1_D1_C708
*MKB20_v82_KNIGHT_OF_SEVEN_KINGDOMS_S1_D2_1A80
*MKB20_v82_Mobile_Suit_Gundam_GQuuuuuuX_-Beginning-_UHD_AF62
*MKB20_v82_THE_SUPER_MARIO_GALAXY_MOVIE_D2C8
snl20
Post by snl20 » Tue Jun 09, 2026 11:58 am
-- thanks for adding
My submisson of
Eraser (1996) 4K Steelbook
bought in Norway and delivered pre release date.
Label: ERASER
Disc type: UHD
Disc ID: 0x59725BDD6C38A9EBB2EDF87FF2676A2C1CA89BDD
Disc dump filename: MKB20_v82_ERASER_1BC4
Drive: PIONEER BD-RW BDR-S12U
MKB_RO.inf link: x
Disc dump link: x
-- dvdfab also reads this now :)
keydb_helper
Post by keydb_helper » Tue Jun 09, 2026 12:15 pm
snl20 wrote: Tue Jun 09, 2026 11:58 am My submisson of
Label: ERASER
Disc type: UHD
Thanks for the submission, your disc has been added to the public keydb.
cladefe60
Post by cladefe60 » Tue Jun 09, 2026 1:47 pm
MrPenguin wrote: Mon Jun 08, 2026 9:55 am
Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive ma poi basta questo o per forza devo inserire id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo mb.ro che cosa e' e dove lo prendo?come invio anche..devo mettere tutto?
Come prima volta ho letto il primo messaggio e ho cercato di seguirlo ma si danno per scontato passaggi forse da spiegare meglio a chi si avvicina per la prima volta a questo servizio...
Grazie
cladefe60
Post by cladefe60 » Tue Jun 09, 2026 1:51 pm
keydb_helper wrote: Mon Jun 08, 2026 6:36 am
Firmware 1 03
Libre Drive
Link file tgz: ...
Ciao e grazie per la risposta..ok vedo se riesco a rendere pubblico il file su google drive(se magari mi si indica come si fa..) ma poi basta questo o per forza devo inserire anche id disco..(dove lo Prendo i dati da make mkv o altro?) e poi leggo da inserire anche il file " mb.ro "che cosa e' e dove lo prendo per pubblicarlo ?devo mettere tutto?
Come prima volta ho letto il tuo primo messaggio e ho cercato di seguirlo ma si danno per scontato passaggi forse da spiegare meglio a chi si avvicina per la prima volta a questo servizio...
Grazie
