Public KeyDB Disc Submissions
Westy83
Post by Westy83 »
Disc type: Blu-ray
Disc ID: 0x98506F867C43D029211DEBBCCB5AFF9F98F3069E
No drive info, ripped on a PS3 as an ISO file
Dump file and MKB-RO.inf here https://limewire.com/d/IaDaS#PWgNckX4FG
ZeroMatrix
Post by ZeroMatrix »
Disc type: UHD
Disc ID: e1c8f41ec3533425989c35ba58ab5af12abcd811
Disc dump filename: MKB20_v82_SINNERS_5B09.tgz
Drive: BD-RE BU40N
Drive firmware: 2116-12-20 15:28
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://limewire.com/d/sadgi#zT4myZzEAY
Disc dump link: https://limewire.com/d/kB8Ns#BawLiQuQJV
axelmace
Post by axelmace »
Raw Deal (Ejecutor) UHD 4K - Spain (Divisa Films)
Disc title: Raw Deal (Ejecutor)
Country: Spain
Publisher: Divisa Films
Format: UHD Blu-ray 4K
AACS: MKB20 v82
Unknown volume key:
MKB20_v82_RawDeal_EJECUTOR_3C9E
The dump file has already been submitted to [svq@makemkv.com](mailto:svq@makemkv.com).
Thanks.
keydb_helper
Post by keydb_helper »
Tacocat707 wrote: Sat Jun 06, 2026 5:04 pm Zootopia 2 (2025) Japanese UHD
Disc Type: UHD
Disc ID: 342973036cbe98ff2a4369fce39222c82be61353
Disc Dump File Name: MKB20_v77_Zootopia_2_0570
ZeroMatrix wrote: Sat Jun 06, 2026 7:17 pm Disc type: UHD
Thanks for the submissions. Both discs have been added to the public keydb.
Westy83 wrote: Sat Jun 06, 2026 5:35 pm Disc type: Blu-ray
Sorry, but disc dumps created by attempting to process ISO files dumped via a PS3 are useless. They don't contain the disc metadata required for deriving disc keys. If you'd like to decrypt your disc you'll probably need to buy a Blu-ray drive.
axelmace wrote: Sat Jun 06, 2026 10:16 pm Raw Deal (Ejecutor) UHD 4K - Spain (Divisa Films)
Country: Spain
AACS: MKB20 v82
Unknown volume key:
Thanks.
I'm not sure why you felt the need to make your own submission template which lacks the required details... This thread is for posting disc dump files so that discs can be added to the public keydb. I don't have access to that email address, so there is absolutely no point posting here to say you've sent an email.
Follow the template from the opening post of this thread if you'd like to see your disc added to the public keydb. Otherwise you'll need to wait for the MakeMKV team to process your disc dump.
Talamera
Post by Talamera »
I indeed had set the wrong path. The keydb.cfg must be placed at my F:/Bluray/. Now it works. Thanks for the info.
cladefe60
Post by cladefe60 »
Oggetto: SCREAM7
HO INVIATO Dump sull'email sviluppatori ma niente. .voi qualcuno con il mio stesso problema su questo disco ?
cladefe60
Post by cladefe60 »
OGGETTO: INVIO DATI DISCO
DISCO: SCREAM 7 (2026) UHD ITALIANO
COME POSSO INVIARE IL FILE TGZ NN ME LO FA COPIARE
cladefe60
Post by cladefe60 »
OGGETTO: INVIO DUMP DISCO
FILM: SCREAM 7 UHD ITALIANO
FILE :MKB20_v82_Scream_7_A991
FootFungus07
Post by FootFungus07 »
The Boys in the Band Cinematographe 4K UHD TGZ & MKB_RO
Label: CIN_034_Boys_in_the_Band
TGZ: MKB20_v82_Boys_in_the_Band_A571.tgz
Timestamp: 2026-04-06 14:46:44
Protection: AACS2.0/C v82
Data capacity: 61.12 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Did you sync the public keyDB within the last 15 minutes? Yes
MKB_RO Link: https://drive.google.com/file/d/186QMQh ... drive_link
TGZ File Link: https://drive.google.com/file/d/1RaJhDv ... drive_link
Cub40i
Post by Cub40i »
Disc type: BD-ROM
Disc ID: Unknown (If there is a clear method to get, please notify)
Disc dump filename: MKB_v82_Avatar-_Fire_and_Ash_323E.tgz
Drive: BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KL6OC5D4307d
Drive firmware: 1.02 2118-10-29
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/16WrqSD ... share_link
Disc dump link: https://drive.google.com/file/d/1qCUajp ... share_link
FootFungus07
The Mangler - Vinegar Syndrome 4K UHD TGZ File and MKB_RO File
Label: VS537UHD
TGZ File: MKB20_v82_VS537UHD_A59F.tgz
Timestamp: 2026-04-04 21:04:42
Data capacity: 61.65 Gb
Number of layers: 2
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1bi1n_o ... drive_link
TGZ File Link: https://drive.google.com/file/d/1WeLFmH ... drive_link
FootFungus07
Nightwatch Vinegar Syndrome TGZ & MKB_RO
Label: VS535UHD
TGZ File: MKB20_v82_VS535UHD_205F.tgz
Timestamp: 2026-04-07 19:00:15
Data capacity: 70.18 Gb
Number of layers: 3
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1RWoGQT ... drive_link
TGZ File Link: https://drive.google.com/file/d/1BdE0kU ... drive_link
FootFungus07
Human Lanterns - Vinegar Syndrome TGZ and MKB_RO files
Label: VS536UHD
TGZ File: MKB20_v82_VS536UHD_6593.tgz
Timestamp: 2026-04-17 13:14:46
Data capacity: 70.75 Gb
Number of layers: 3
Revision: 1.02
MKB_RO File Link: https://drive.google.com/file/d/1865POX ... drive_link
TGZ File Link: https://drive.google.com/file/d/1R1Z7bx ... drive_link
cladefe60
SCREAM 7 UHD
Post by cladefe60 »
FILM: SCREAM 7 UHD ITALIANO -INGLESE
FILE DUMP: MKB20_v82_Scream_7_A99
LETTORE : VERBATIM 43888
FIRMWARE 1.03
MrPenguin
Re: SCREAM 7 UHD
Post by MrPenguin »
cladefe60 wrote: Sun Jun 07, 2026 5:21 pm FILM: SCREAM 7 UHD ITALIANO -INGLESE
FILE DUMP: MKB20_v82_Scream_7_A991
Questo non serve a nulla a meno che tu non carichi anche il tuo file di dump su un servizio di hosting come Google Drive o OneDrive e poi pubblichi qui un link per il download pubblico.
Dovresti inoltre inviare quel file TGZ via email a svq@makemkv.com.
