Broken libmmbd with libbdplus
Hen23776
Post by Hen23776 »
Hi there,
There is a bug with libmmbd and some disks using bdplus encoding.
First of all, using MakeMkv directly works without issues.
However, any player (VLC, HandBrake...) using libmmbd (or libbdplus emulation) will start receiving garbage after about 20 minutes. It looks like only the first part of the FUT is being applied even though libmmbd thinks it is using the whole table (nothing on the log)
I have only seen this with James Bond movies (1080 BDs), but it looks like all of them do the same, regardless of the version of BD+ encoding.
I reported the issue earlier this year but I guess it was the wrong forum. Also, it looks like I'm not the only one seeing the issue.
I hope this time Mike sees the post
pikmin_tom
Re: Broken libmmbd with libbdplus
Post by pikmin_tom »
I've only just started to try using libmmbd for direct disc playback in VLC and I've seen exactly the same behaviour with the video starting to be corrupted after 15 or 20 minutes. I don't think I have many BD+ discs but it happens with both of the discs I've tried: Skyfall and Avatar. I have three BD drives, all different models, and it happens with all of them.
I'm running Linux and I've tried with both the most recent v1.18.3 and older v1.17.7 versions of MakeMKV and it happens with both. If I rip the discs directly with MakeMKV then they rip perfectly.
MrPenguin
Post by MrPenguin »
pikmin_tom wrote: Thu Jun 04, 2026 11:03 pm I've only just started to try using libmmbd for direct disc playback in VLC and I've seen exactly the same behaviour with the video starting to be corrupted after 15 or 20 minutes. I don't think I have many BD+ discs but it happens with both of the discs I've tried: Skyfall and Avatar. I have three BD drives, all different models, and it happens with all of them.
Personally, I don't recommend "direct disc playback" because it puts unnecessary wear-and-tear on your drive. And such drives are no longer being manufactured, so are becoming increasingly difficult to replace.
Suppose you create an encrypted back-up of one of these disks, i.e. replicating the contents of the BD on your hard drive: Can VLC play the back-up cleanly? Because if so, maybe there's an occasional glitch in the data stream from the drive over the data bus (USB?), and VLC isn't coping with it successfully? However, a data stream read from a hard drive should be smoother...
Sayaka
Post by Sayaka »
Is this true even if you plan on watching a Blu-ray movie only once ? Could anyone please clarify this ? It would take forever to make a backup copy of each disc from my Walking Dead collection (not to mention I believe it would use up a lot of storage space), and once I'm done watching the seasons I missed I am unlikely to have the time needed to go through the whole series again, so I just had to ask - making a backup of each disc just doesn't seem worth it right now.
Sayaka wrote: Fri Jun 05, 2026 6:35 pm
i backed up the whole walking dead its like 2tb
but i used 6 drives at a time to do it
pikmin_tom
MrPenguin wrote: Fri Jun 05, 2026 11:49 am Personally, I don't recommend "direct disc playback" because it puts unnecessary wear-and-tear on your drive. And such drives are no longer being manufactured, so are becoming increasingly difficult to replace.
I mostly do rip discs in advance, but sometimes it's convenient to just play them, e.g. if I have a group of friends round and one brings a film to watch, I want to just play it, not wait an hour for it to rip first!
MrPenguin wrote: Fri Jun 05, 2026 11:49 amSuppose you create an encrypted back-up of one of these disks, i.e. replicating the contents of the BD on your hard drive: Can VLC play the back-up cleanly? Because if so, maybe there's an occasional glitch in the data stream from the drive over the data bus (USB?), and VLC isn't coping with it successfully? However, a data stream read from a hard drive should be smoother...
I have just tried this and get exactly the same result when played from the hard drive so it's definitely not because the drive can't keep up.
It might be worth noting that this is not specific to VLC as the same happens if I use Kodi, both directly from the disc or hard drive backup. Also if I correctly install libaacs and libbdplus and the necessary files (KEYDB.cfg, VM0 and the conversion tables) so that libmmbd is not used, then the film plays perfectly, so there's no problem with the disc or the drive or the player software, it's just libmmbd.
