The latest KEYDB.cfg file already contains this disk. Have you tried downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?ng1988 wrote: Thu Jun 04, 2026 11:32 am Disk-Informationen
Label: SCARLET
Timestamp: 2026-03-26 13:02:05
Protection: AACS2.0/C v82
Data capacity: 72.42 Gb
Disk-Typ: BD-ROM UHD
Number of layers: 3
Bus encryption markings: 80
Public KeyDB Disc Submissions
MrPenguin
MKVDUDE
Another one please - All files are in the same link - https://we.tl/t-MinyTWbywSjmPLiK
Disc type: BD
Disc ID: 0aa47d9916e6345bf875e94e99934acd1967b274
Disc dump filename: MKB_v82_Monty_Python's_Fliegender_Zirkus_F3D6.tgz
Drive: MT1959
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://we.tl/t-MinyTWbywSjmPLiK
Disc dump link: https://we.tl/t-MinyTWbywSjmPLiK
Many thanks!
Disc type: BD
Drive: MT1959
Many thanks!
Mythbuster
here is my dump file, hope you can help to decrypt.
Disc type: UHD
Disc dump filename: MKB20_v82_Spaceballs_UHD_378D
Drive: Asus BW-16D1HT
Drive firmware: 3.10MK
Disc dump link: https://drive.google.com/file/d/189KXhr ... share_link
Thank You
Disc type: UHD
Thank You
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_1_E853
*MKB20_v82_HOW_TO_MAKE_A_KILLING_0D8E
*MKB20_v82_LE_MAGE_DU_KREMLIN_9DA0
*MKB20_v82_NottingHill_UPK1_4186
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
ng1988
Wonderful, it worked perfectly. Thank you so much! =)MrPenguin wrote: Thu Jun 04, 2026 2:08 pmThe latest KEYDB.cfg file already contains this disk. Have you tried downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?ng1988 wrote: Thu Jun 04, 2026 11:32 am Disk-Informationen
Label: SCARLET
Number of layers: 3
Stryker412
Dump for Hoppers
Disc Information
Label: HOPPERS
Timestamp: 2026-04-10 18:36:38
Data capacity: 93.5 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
https://drive.google.com/file/d/1sb-RCo ... sp=sharing
Disc Information
Label: HOPPERS
Number of layers: 3
keydb_helper
Hey Stryker412, your disc was added to the public keydb on May 25. Please read the first post of this thread for info on how to configure MakeMKV to utilise the public keydb and the actual submission template.
Twistedsheep
I bombed this last time I tried, but I feel like I've crossed all my Ts. Thank you makemkv crew who helped me previously, and perhaps I discovered a spicy disk and drive combo.
The Abyss
Disc type: UHD
Disc ID: 9e8e1ce30d47315834d8a6d8721c3846d07d017c
Disc dump filename: MKB20_v77_THE_ABYSS_E1C1.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02
MKB_RO.inf link: [https://drive.google.com/file/d/18ZyiIH ... drive_link](https://drive.google.com/file/d/18ZyiIH ... drive_link)
Disc dump link: [https://drive.google.com/file/d/1Qwbp3K ... drive_link](https://drive.google.com/file/d/1Qwbp3K ... drive_link)
The Abyss
Disc type: UHD
keydb_helper
Thanks for following the submission template Twistedsheep. Your disc has been added to the public keydb.Twistedsheep wrote: Fri Jun 05, 2026 2:41 am I bombed this last time I tried, but I feel like I've crossed all my Ts. Thank you makemkv crew who helped me previously, and perhaps I discovered a spicy disk and drive combo.
The Abyss
Disc type: UHD
sergio31
Key does not still work on MKB20_v82_Avatar-_Fire_and_Ash_DB6C.keydb_helper wrote: Sun May 31, 2026 1:49 pm Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):Code: Select all
MKB20_v61_Philadelphia_FB27 *MKB20_v77_RATATOUILLE (0x2EEFB114195DCEDCCB06E0A552EC97DE6D9F6B93) *MKB20_v82_Avatar-_Fire_and_Ash_DB6C *mkb20_v82_bdrom_0ece (Gourou) MKB20_v82_Bugonia_0F35 *MKB20_v82_Hell_Or_High_Water_3132 *MKB20_v82_LEAVING_LAS_VEGAS_BB10 *MKB20_v82_NottingHill_UPK75_2E12 *MKB20_v82_Slither_UHD_3996 MKB20_v82_Speed_Racer_D1F2 *MKB20_v82_TheBurbs_UHD_22BE *MKB20_v82_The_Cars_That_Ate_Paris_UHD_22C2 *MKB20_v82_The_Flintstones_74EE
keydb_helper
Are you actually using the public keydb? Or are you relying on MakeMKV’s native title support?sergio31 wrote: Fri Jun 05, 2026 9:14 am Key does not still work on MKB20_v82_Avatar-_Fire_and_Ash_DB6C.
sergio31
Yes, I put the latest key into .MakeMKV directory.
And I still can not open disk :
Liersi
Disc type: UHD
Disc dump filename: MKB20_v82_LE_DEUXIEME_SOUFFLE_9D2A
Drive: WH16NS60
MKB_RO.inf link: https://mega.nz/file/FwsDRSbA#l4WdsAlpa ... cSaHJzhd4Q
Disc dump link: https://mega.nz/file/5hVQxKwT#TrFiIRRs6 ... 0GPFgdN6B0
Drive: WH16NS60
keydb_helper
The DB6C variant of Avatar: Fire and Ash has definitely been supported by the public keydb since May 31:sergio31 wrote: Fri Jun 05, 2026 9:37 am Yes, I put the latest key into .MakeMKV directory.
0x2D200C475AC62A53153F8E875203BB4E1D56725F = AVATAR_FIRE_AND_ASH (Avatar: Fire and Ash) | D | 0000-00-00 | M | 0x6D7C<Redacted> | I | 0xF59B<Redacted> | V | 0x4D0A<Redacted> | U | 1-0x6EC7<Redacted> ; MKBv82/BEE (UHD)
It is important to remember the ".MakeMKV directory" is the default path to place the extracted keydb.cfg file. But if you have changed the location of the MakeMKV data directory you should be placing the extracted keydb.cfg file in whichever directory MakeMKV initially stored your local "MKB20_v82_Avatar-_Fire_and_Ash_DB6C.tgz" file.
Thanks Liersi, your disc has been added to the public keydb.Liersi wrote: Fri Jun 05, 2026 10:58 am Disc type: UHD
chrominance
Second disc in as many weeks that seems like not a recent release and yet isn't in the public keydb, which makes me worried that the problem is actually on my end, but just in case:
Disc type: UHD
Disc ID: 4CCA81B810DED14859573AB43F6CCA67C3DECD7E
Disc dump filename: MKB20_v77_DECISION_TO_LEAVE_DF15.tgz
Drive: HL-DT-ST BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1BymkC2 ... drive_link
Disc dump link: https://drive.google.com/file/d/1Mw4USY ... sp=sharing
Disc type: UHD
