Hi, I just received my copy of the band, The Warning Live from Auditorio Nacional, CDMX on blue ray. It was a pre order and I am or was excited to check it out. So i popped it in my LG drive on my computer to make MKV and it says there is no encryption keys. So i was hopping for some help getting some, it created a log dump so ill include it as well
Thanks so much everyone
The Warning Live Blue ray encryption keys? log attached
bonno
bonno
Re: The Warning Live Blue ray encryption keys? log attached
harborless-accept5
You need to email the AACS dump to the programs author as outlined in Fixing Volume Key is Unknown
MrPenguin
bonno
Ok seems to be going.
