Dump submitted - Ho! (1968) (Robert Enrico)
RandomSelf
Post by RandomSelf » Fri May 15, 2026 12:30 pm
Greetings all,
Disc type : UHD
Disc ID : 7FED01AFE1EDACBE8AC07DDA3ADAA04275BEA3C1
Disc dump filename : MKB20_v82_HO!_B346
Drive : BD-RE ASUS BW-16D1HT
Drive firmware : 3.10
LibreDrive status : Enabled
Did you sync the public keydb within the last 15 minutes : Yes
Submission links are accessible in incognito/private browsing : Verified
MKB_RO.inf link : https://drop.chapril.org/download/7799a ... ejEEMhhSLA
Disc dump link : https://drop.chapril.org/download/50f31 ... KAhvW0uSTQ
All the best,
RandomSelf
RandomSelf
Re: Dump submitted - Ho! (1968) (Robert Enrico)
Post by RandomSelf » Wed May 27, 2026 5:36 pm
Greetings Team,
Thanks for the load of new keys added following my last requests :D .
Yet, I still can’t access this disk. Was its key added to the log ?
All the best to all,
RandomSelf
MrPenguin
Post by MrPenguin » Wed May 27, 2026 6:26 pm
RandomSelf wrote: Wed May 27, 2026 5:36 pm Yet, I still can’t access this disk. Was its key added to the log ?
This disk was added to the KEYDB.cfg file last year. Its DiscId is actually 0xF7064CFA845C235DF15051869074DE066D35AB83.
RandomSelf
Post by RandomSelf » Fri May 29, 2026 6:16 am
Greetings and thanks for the reply MrPenguin,
I just checked my own disc Unit_Key_RO.inf file. It has the same hash that you posted F7064CFA845C235DF15051869074DE066D35AB83.
I have tried to back up my disc several times since my initial message but it always failed.
Is there something I can do. It's the first time I got this dead end with a UHD disc.
All the best to the team,
RandomSelf
MrPenguin
Post by MrPenguin » Fri May 29, 2026 9:52 am
RandomSelf wrote: Fri May 29, 2026 6:16 am I have tried to back up my disc several times since my initial message but it always failed.
You haven't described the failure you are seeing. However, since the latest KEYDB.cfg file has a full entry for your disk, the only encryption problem you could have here would be from LibreDrive failing to disable bus encryption.
RandomSelf
Post by RandomSelf » Sun May 31, 2026 6:30 am
Greetings MrPenguin,
I probably shouldn't have written "failed" as this most likely isn't a failure per se.
The application provides the usual message that alerts the user the keydb is unknown.
If the problem is LibreDrive can't disable bus encryption, given an entry already exists for this disc, is there any turnaround to backup the disc anyway ?
Best regards,
RandomSelf
MakeMKV v1.17.7 darwin(arm64-release)
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
