Day of the Dead Scream Factory 4K UHD TGZ File
Label: Day_of_the_Dead
MKB20_v82_Day_of_the_Dead_-_Disc_One_B376.tgz
Timestamp: 2026-03-12 19:58:59
Protection: AACS2.0/C v82
Data capacity: 80.48 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Google Drive Link: https://drive.google.com/file/d/1_FM8MF ... drive_link
Public KeyDB Disc Submissions
hulahoo
FootFungus07
Scream 7 4K UHD TGZ & MKB_RO files
Label: SCREAM_7
MKB20_v82_Scream_7_1185.tgz
Timestamp: 2026-04-06 15:09:05
Data capacity: 60.97 Gb
Number of layers: 2
Revision: 1.02
TGZ File Link: https://drive.google.com/file/d/1F3wtVG ... drive_link
MKB_RO File Link: https://drive.google.com/file/d/1M0gAIT ... drive_link
Label: SCREAM_7
Number of layers: 2
Revision: 1.02
ScoobyMKV
A new set of IDs for Total Recall (1990), I believe, as I couldn't find it in the KeyDB.
Disc type: UHD
Disc ID: 0x5CCDAAD57DAC1C7CCAAD13F488A18A57F923D56F
Disc dump filename: MKB20_v70_BDROM_DE87.tgz
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1PxPbcZ ... drive_link
Disc dump link: https://drive.google.com/file/d/1ispgwi ... drive_link
Disc type: UHD
Drive: BU40N
FootFungus07
Hearts of Darkness: The Art of Eleanor Coppola Lionsgate Limited 4K UHD
Label: HEARTS_OF_DARKNESS_DISC1
MKB20_v82_Hearts_of_Darkness_-_The_Art_of_Eleanor_Coppola_Disc_1_DCDC.tgz
Timestamp: 2026-03-03 15:43:58
Data capacity: 75.44 Gb
Number of layers: 3
Revision: 1.02
Google Drive Link: https://drive.google.com/file/d/1UK7_Xq ... drive_link
Thanks again!
Number of layers: 3
Revision: 1.02
Thanks again!
eNoize
Weird. I still can't rip the disc. I keep receiving the same message that the key is unknown and can't decrypt.
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKVs data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?eNoize wrote: Thu May 28, 2026 8:17 pm Weird. I still can't rip the disc. I keep receiving the same message that the key is unknown and can't decrypt.
The KEYDB file is an optional database that MkeMKV can use, if available. And if you haven't already done so, email that TGZ dump file to svq@makemkv.com so that your key can be added to MakeMKV's own "hashed keys" database as well.
chrominance
Guess I have a new variant of Monty Python's The Meaning of Life...
Disc type: UHD
Disc ID: A928E93D300F9BAD3C88F2EACC8157F17F064434
Disc dump filename: MKB20_v76_Monty_Python's_the_Meaning_of_Life_ED2B.tgz
Drive: HL-DT-ST BD-RE BP60NB10
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1HBW9Of ... drive_link
Disc dump link: https://drive.google.com/file/d/1CAaGo5 ... drive_link
Disc type: UHD
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_A_Writers_Odyssey2_9690
*MKB20_v82_Day_of_the_Dead_-_Disc_One_B376
*MKB20_v82_Hearts_of_Darkness_-_The_Art_of_Eleanor_Coppola_Disc_1_DCDC
*MKB20_v82_ILoveMaria_UHD (0x09696B613B45B21E5DE7B2BD7CB0C0BF03A3D0A1)
*MKB20_v82_JSA_-_Joint_Security_Area_C27E
*MKB20_v82_RAMBO_DISC1_1BA8
*MKB20_v82_RAMBO_DISC2_413C
*MKB20_v82_RAMBO_DISC3_46B4
*MKB20_v82_RAMBO_DISC4_8706
*MKB20_v82_RAMBO_DISC5_C068
*MKB20_v82_RAMBO_DISC6_819A
*MKB20_v82_Shanghai_blues_9B42
*MKB20_v82_Sirat_F49C
*MKB20_v82_Unlawfull_Entry (0x02B60D0E4DE0D69F1D47806E1574BB3C97031933)
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Cuddy2977
This is for the first (4k) disc of the recent UK release of Dr Who — The Movie.
Disc type:UHD/4k
Disc ID: 0b47bfe64c588180ada6a2a8828e3e4c931627e00ab740357c06d720d83a80f0 /Users/pauldownie/Desktop/MKB20_v82_DOCTOR_WHO_96F6/AACS/Unit_Key_RO.inf
Disc dump filename: MKB20_v82_DOCTOR_WHO_96F6
Drive: BD-RW DBR-UD04
Drive firmware: 1.11
Did you sync the public keydb within the last 15 minutes?No
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):Not Known
Disc dump link: https://drive.google.com/file/d/1UPXl-f ... share_link
Please contact me if there’s issues …
Disc type:UHD/4k
MrPenguin
Can you adjust the "Share" option for this file please, so that people can access it?Cuddy2977 wrote: Fri May 29, 2026 10:14 am Disc dump filename: MKB20_v82_DOCTOR_WHO_96F6
Cuddy2977
OK, I think I’ve adjusted it properly!MrPenguin wrote: Fri May 29, 2026 10:54 amCan you adjust the "Share" option for this file please, so that people can access it?Cuddy2977 wrote: Fri May 29, 2026 10:14 am Disc dump filename: MKB20_v82_DOCTOR_WHO_96F6
MrPenguin
Thanks, and I think the latest KEYDB.cfg file already contains this disk. Have you tried downloading this file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
Cuddy2977
You mean the ‘keydb_eng.zip’ into /Users/pauldownie/Library/MakeMKV, is that right? Without unzipping the file?
Or do you mean ‘unzip keydb_eng.zip, and put the contents, put keyed.cfg into the folder, then restart’?
I’ve JUST done the latter: and that seems to be working!
MKVDUDE
Another one please - All files are in the same link - https://we.tl/t-LkSi29hpzHojyjiK
Disc type: BD
Disc ID: bcf0d20831fe7888afa2823028a93ab9
Disc dump filename: MKB_v82_BMX_BANDITS_76CC.tgz
Drive: MT1959
MKB_RO.inf link: https://we.tl/t-LkSi29hpzHojyjiK
Disc dump link: https://we.tl/t-LkSi29hpzHojyjiK
Many thanks!
Disc type: BD
Drive: MT1959
Many thanks!
