[solved] Andor Disc 3 key exchange failure - key not present
Saidom
#1 Post by Saidom » Sat May 23, 2026 9:40 pm
Hello
the previous discs ripped without problems but I cannot get Disc 3 to work. I've attached the dump-file and the MKB_RO, however copying that from the disc took quite long so I am not completely sure if that worked correctly.
Also I've looked up the disc ID in the KEYDB.cfg file and found it.
[links]
Any help is appreciated.
MrPenguin
Re: Andor Disc 3 key exchange failure - key not present
#2 Post by MrPenguin » Sat May 23, 2026 11:02 pm
Saidom wrote: Sat May 23, 2026 9:40 pm Hello
You cannot rip this disk because MakeMKV failed to enable LibreDrive for some reason:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
DEBUG: Code 0 at ?>@=1r\!W?_}[zdZ6:213130306
DEBUG: Code 0 at oH+-D*FQAz1#bPXt1=:121264395
DEBUG: Code 4 at oH+-D*FQAz1#bPXt1=:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
This meant that MakeMKV could not disable bus encryption :(. Since you have already successfully ripped other disks, try power-cycling your UHD drive and trying again. Hopefully LibreDrive will enable next time.
Saidom
#3 Post by Saidom » Sat May 23, 2026 11:18 pm
MrPenguin wrote: Sat May 23, 2026 11:02 pm ... try power-cycling your UHD drive and trying again. Hopefully LibreDrive will enable next time.
thanks, I did try this already.
by cure coincidence I read the BD+ announcement and updated the dsall.svq file. This solved my problem.
Thanks for the help anyway
