Many thanks!keydb_helper wrote: Fri May 22, 2026 8:25 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):Code: Select all
*MKB20_v76_The_Thing_CEC9 *MKB20_v77_TERMINATOR_2_5418 *MKB20_v82_DeepStar_Six_C986 *MKB20_v82_FALLING_DOWN_-_UHD_38C4 *MKB20_v82_HARD_BOILED_2FB4 *MKB20_v82_Return_To_Silent_Hill_8206 *MKB20_v82_SOYLENT_GREEN_-_UHD_DC1A *MKB20_v82_THE_KILLER_FE10 *MKB20_v82_TO_LIVE_AND_DIE_IN_L_A_B206 *MKB20_v82_TRAINSPOTTING_7932 *MKB20_v82_Wuthering_Heights_96C2
Public KeyDB Disc Submissions
Disc type: UHD
Disc ID: 00d59fd6ffb2269685e5c48999acb031123d9998
Disc dump filename: MKB20_v77_THE_LIGHTHOUSE_C43B
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/3VX0KDGB20#fsGAFozBaE3v
Disc dump link: https://drive.proton.me/urls/PMES3ANXMW#zQ3g2m06M77d
Drive: BU40N
keydb_helper
Thanks kario, your disc has been added to the public keydb. The 4024 variant of Scarlet (MKB20_v82_Scarlet_4024) has also been added.kario wrote: Fri May 22, 2026 4:31 pm Disc type: UHD
Disc type: BD-ROM
Disc ID: SHBR_0801
Disc dump filename: MKB_v82_SHBR_0801_C02C
Drive: BD-RE ASUS SBW-06D2X-U 1.10 AFDL221226WLd
Drive firmware: 1.10
LibreDrive status: Possible, not yet enabled
MKB_RO.inf link: https://drive.google.com/file/d/1teH6TK ... share_link
Disc dump link: https://drive.google.com/file/d/1DpOxVe ... share_link
Disc ID: SHBR_0801
Disks 1 & 3 worked fine, just disk 2 throwing error. All of Season 2 worked fine as well.
Disc type: UHD
Disc ID: 3895b8c1f3fa583608469fffb719f4f0dee89ca0
Disc dump filename: MKB20_v77_ARCANE_SEASON_1_-_DISC_2_65EB
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.proton.me/urls/R11F7W94PG#JiRn5KzQzzxS
Disc dump link: https://drive.proton.me/urls/6VGJBKM63G#tXzvJZd3w9QQ
Disc type: UHD
Disc type: UHD
Disc ID: 7710ddb88cc939727b38b3fe41513a36407ad53c
Disc dump filename: MKB20_v72_GEMINI_MAN_2B11.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/kw75yifz ... 1.tgz/file
Thank you!
Thank you!
Disc type: UHD
Disc ID: ed1da27bb7dc093650d982ef5753a21afe425f80
Disc dump filename: MKB20_v66_MORTAL_ENGINES_1427.tgz
Disc dump link: https://www.mediafire.com/file/xj6fetug ... 7.tgz/file
Thank you!
Thank you!
Disc type: UHD
Disc ID: 85182cdcf50ed5a8c7cbd52131a52d6447ca6299
Disc dump filename: MKB20_v76_PERFECT_PLANET_DISC_1_4627.tgz
Disc dump link: https://www.mediafire.com/file/xvc89tx2 ... 7.tgz/file
Thank you!
Thank you!
Disc type: UHD
Disc ID: 5413735e9ae02a2306c8dcbcd33e0100d445b345
Disc dump filename: MKB20_v76_PERFECT_PLANET_DISC_2_FE91.tgz
Disc dump link: https://www.mediafire.com/file/9j2r8tme ... 1.tgz/file
Thank you!
Thank you!
NOTE: Something strange is happening with this disc. The KeyDB_Helper_1.0.2.1 tool reports that the disc id is already present in the keydb.cfg file. But when I try it in MakeMKV I still get "The volume key is unknown for this disc - video can't be decrypted". I have tried syncing the keydb file multiple times and even manually downloading it with no luck.
Disc type: UHD
Disc ID: 7bc9aeab746bf477e0e96cf6e47dc34958728469
Disc dump filename: MKB20_v66_DYNASTIES_DISC_1_E7AF.tgz
Disc dump link: https://www.mediafire.com/file/hs9i7hsa ... F.tgz/file
Thank you!
Disc type: UHD
Thank you!
NOTE: Something strange is happening with this disc. The KeyDB_Helper_1.0.2.1 tool reports that the disc id is already present in the keydb.cfg file. But when I try it in MakeMKV I still get "The volume key is unknown for this disc - video can't be decrypted". I have tried syncing the keydb file multiple times and even manually downloading it with no luck. This has happened with both Disc 1 and Disc 2 of DYNASTIES.
Disc type: UHD
Disc ID: a00c5fd7dfee30e7ea524cf2c030e50503909b26
Disc dump filename: MKB20_v66_DYNASTIES_DISC_2_8DD3.tgz
Disc dump link: https://www.mediafire.com/file/nnb2olre ... 3.tgz/file
Thank you!
Disc type: UHD
Thank you!
keydb_helper
Great to see submissions for the older MKB versions as they really help to fill gaps in the keydb.
The KeyDB tool can generally derive the VUK and create a complete entry when the media key is already known to the public keydb. When the KeyDB tool can't create a complete entry that is your cue to post a submission to this thread.
Sync your local keydb and you'll be able to process your discs with MakeMKV now that the entries for your discs are complete.
*MKB20_v66_DYNASTIES_DISC_1_E7AF
*MKB20_v66_DYNASTIES_DISC_2_8DD3
*MKB20_v66_MORTAL_ENGINES_1427
*MKB20_v72_GEMINI_MAN_2B11
*MKB20_v76_PERFECT_PLANET_DISC_1_4627
*MKB20_v76_PERFECT_PLANET_DISC_2_FE91
*MKB20_v82_Chasers_7A06
*MKB20_v82_Chill_Factor_85E2
When a disc has an incomplete record in the public keydb, such as your Dynasties discs, your experience is to be expected. Incomplete records are useful as VLC and other opensource software will happily playback a disc when only the unit key (UK) is available. But MakeMKV requires the volume unique key (VUK) in order to decrypt a disc.user76419 wrote: Fri May 22, 2026 9:24 pm NOTE: Something strange is happening with this disc. The KeyDB_Helper_1.0.2.1 tool reports that the disc id is already present in the keydb.cfg file. But when I try it in MakeMKV I still get "The volume key is unknown for this disc - video can't be decrypted". I have tried syncing the keydb file multiple times and even manually downloading it with no luck.
frameloose
I had that problem with Cannibal Holocaust from Studio S. The key was in keydb.cfg file, could validate and everything. But MakeMKV returned the same message you got. For me the issue got solved when i updated from MakeMKV version 1.18.2 to 1.18.3. Now i don't know if the issue was related to the version, or that just a fresh copy solved it.user76419 wrote: Fri May 22, 2026 9:25 pm NOTE: Something strange is happening with this disc. The KeyDB_Helper_1.0.2.1 tool reports that the disc id is already present in the keydb.cfg file. But when I try it in MakeMKV I still get "The volume key is unknown for this disc - video can't be decrypted". I have tried syncing the keydb file multiple times and even manually downloading it with no luck. This has happened with both Disc 1 and Disc 2 of DYNASTIES.
Re: Public KeyDB Disc Submissions (Cloak & Dagger)
Disc type: UHD
Disc ID: 0x96158B04260AB335DA6A59BB3A117BE4EE48BE9B
Disc dump filename: MKB20_v76_Cloak_and_Dagger_D099.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1eAXjib ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ugEowK ... sp=sharing
Drive: BD-RE BU40N
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been processed but the public keydb seems to be having an issue accepting submissions (new media keys are indicated with an asterisk):
Until the public keydb issue is resolved, the new keys are available here: Pastebin Link
Using the Dynasties example from yesterday, this was the prior keydb entry (keys redacted for the forum):
This earlier entry was correct and would've been correctly validated. It also would've enabled playback via VLC/libaacs. But it wasn't complete so it couldn't be used with MakeMKV.
The same disc now has a complete record so it can be used with MakeMKV:
*MKB20_v82_DARK_BLUE_E3C8
*MKB20_v82_No_Other_Choice_FDF4
*MKB20_v82_Scarlet_CAB8
*MKB20_v82_State_of_Grace_C52E
Thanks for the submission makeit99. As you use Windows I'd recommend trying out SamuriHL's KeyDB Tool. The media key for your Cloak and Dagger disc was already known to the public keydb, so the tool would've created the complete keydb entry. If any disc records remain incomplete/unsupported after using the tool you can always post disc dump files here.makeit99 wrote: Sat May 23, 2026 10:52 pm Disc type: UHD
The timing was most likely a coincidence. The volume key error would've been resolved by either the public keydb getting a complete record for your disc or MakeMKV natively supporting it.frameloose wrote: Sat May 23, 2026 6:33 pm I had that problem with Cannibal Holocaust from Studio S. The key was in keydb.cfg file, could validate and everything. But MakeMKV returned the same message you got. For me the issue got solved when i updated from MakeMKV version 1.18.2 to 1.18.3. Now i don't know if the issue was related to the version, or that just a fresh copy solved it.
0x7BC9AEAB746BF477E0E96CF6E47DC34958728469 = DYNASTIES_DISC_1 (Dynasties - Disc 1) | D | 2019-01-02 | U | 1-0x06D0<Redacted> ; MKBv66/BEE/FindVUK 1.30 - VolumeSize: 65237811200 (UHD)
0x7BC9AEAB746BF477E0E96CF6E47DC34958728469 = DYNASTIES_DISC_1 (Dynasties - Disc 1) | D | 2019-01-02 | M | 0x69FB<Redacted> | I | 0x8D73<Redacted> | V | 0x8AC7<Redacted> | U | 1-0x06D0<Redacted> ; MKBv66/BEE/FindVUK 1.30 - VolumeSize: 65237811200 (UHD)
