LibreDrive for Pioneer drives
#1981 Post by Coopervid » Tue May 19, 2026 9:35 pm
tomty89 wrote: Tue May 19, 2026 9:28 pm
Coopervid wrote: Tue May 19, 2026 9:21 pm All well meant but I have sent information to make his drive UHD capable. No chance w/o flashing to UHD.
Hmm I thought drive without UHD capable firmware will not "see" UHD disc when inserted? Or do you mean some UHD firmware is bugged or so?
tomty89
#1982 Post by tomty89 » Tue May 19, 2026 10:14 pm
Coopervid wrote: Tue May 19, 2026 9:35 pm
Not really sure what you mean but what I meant was:
Disc Information
Label: GET_OUT
Timestamp: 2017-06-28 08:14:37
Protection: AACS2.0/C v61
Data capacity: 60.59 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Doesn't that mean his drive is / was already UHD capable? (Even though it has only two layers -- but more than 50GB)
Besides, BDR-S12J-X is supposed to be an official UHD model anyway, AFAIK.
#1983 Post by Billycar11 » Tue May 19, 2026 10:15 pm
alexbar wrote: Tue May 19, 2026 6:31 pm This one here:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: AIDL006471WL
Firmware date: 2020-07-21
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.01/ID72
Disc Information
Label: GET_OUT
Number of layers: 2
Should work as is
biturbeh
#1984 Post by biturbeh » Wed May 20, 2026 3:01 pm
My drive is listed above but it doesn't appear to be supported yet. This is the model information as it appears on MakeMKV:
OS device name: /dev/rdisk6
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: CHDL115607WL
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
Thank you!
#1985 Post by Billycar11 » Wed May 20, 2026 3:58 pm
biturbeh wrote: Wed May 20, 2026 3:01 pm My drive is listed above but it doesn't appear to be supported yet. This is the model information as it appears on MakeMKV:
Revision: 1.14
Thank you!
Should work as is
If you have volume key unknown see UHD disc section and look for keydb
MrPenguin
#1986 Post by MrPenguin » Wed May 20, 2026 3:59 pm
Revision: 1.14
Ah, the Goode Olde Verbatim 43888, Pioneer model! This UHD drive should work "out of the box" with MakeMKV, without needing to have its firmware updated first. After all, MakeMKV does[/] already say that LibreDrive is enabled :|.
drknight71
#1987 Post by drknight71 » Thu May 21, 2026 1:40 am
Coopervid wrote: Tue May 05, 2026 3:54 pm All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
This 211 should be used internally. If you want to rule out the root cause you should get a Benfei USB -> SATA adapter like this. If it works with that your enclosures don't support all functions. Why this happens with this 211 I don't know.
https://www.amazon.com/BENFEI-Drive-Ada ... 9hdGY&th=1
Thank you for the information. Was wondering why my old 211M 1.54 firmware was acting weird with non UHD disks. Ordering the Sata USB adapter. Thank you.
PS: Can you please share if there is a firmware that will cross flash on the 1.54 to something else more friendly?
I have the BDR flash utility already with 1.53 firmware but don't think that will work.
drknight71
#1988 Post by drknight71 » Thu May 21, 2026 1:43 am
What about this one. Its a Benfei usb adapter but this one has external power support:
https://www.amazon.com/gp/product/B07JG ... XLEXM&th=1
nicholfd
#1989 Post by nicholfd » Thu May 21, 2026 2:04 am
drknight71 wrote: Thu May 21, 2026 1:43 am
It's not necessarily about power (power does matter) - it's about the USB -> SATA chipset & how completely/accurately it impliments the SATA standard. You won't find that listed in any specs. Must try/test with the adapter. And then, some Mfg's make design changes without changing model number (Archgon), and what was tested & did work, newer manufactured ones may not work.
If the adapter with power has the same USB-SATA design/implementation, then it *should* be ok, or even better with the additional power.
Thanks,
Frank
notes4me
#1990 Post by notes4me » Fri May 22, 2026 11:24 pm
Hi all,
I have two Pioneer drives which both do not detect UHD Blu-rays:
OS device name: E:
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: removed
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.03
Firmware date: 2022-10-13
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.03/ID61
The BDR-S09 should be capable of, but for the BDR-212D I'm not sure.
#1991 Post by Billycar11 » Sat May 23, 2026 12:21 am
notes4me wrote: Fri May 22, 2026 11:24 pm Hi all,
OS device name: E:
Revision: 1.55
OS device name: E:
Revision: 1.03
sure email me that info
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
drknight71
#1992 Post by drknight71 » Sat May 23, 2026 12:31 am
nicholfd wrote: Thu May 21, 2026 2:04 am
Thanks,
Frank
Wanted to confirm after using the Benfei adapter today so far no errors with the 211M Pioneer drive.
alexbar
#1993 Post by alexbar » Mon May 25, 2026 5:09 pm
Billycar11 wrote: Tue May 19, 2026 10:15 pm
OS device name: E:
Revision: 1.01
Disc Information
Label: GET_OUT
Number of layers: 2
Should work as is
Thank you for your reply. You told me the truth, my drive is already ready for UHD Blu-ray. I managed to play the disc directly in VLC, AFTER having to update the makemkv registry. I added some extra files to the VLC Player folder, and I don't know if that's why it plays. However, it's not playing in MPC-be. Do I have to put those same files in the MPC folder? Is MPC-be really the best player for this? Remember that I want to play the disc directly in a player on a Windows 11 PC.
Toscaclarinet
#1994 Post by Toscaclarinet » Wed May 27, 2026 5:11 am
alexbar wrote: Mon May 25, 2026 5:09 pm Thank you for your reply. You told me the truth, my drive is already ready for UHD Blu-ray. I managed to play the disc directly in VLC, AFTER having to update the makemkv registry. I added some extra files to the VLC Player folder, and I don't know if that's why it plays. However, it's not playing in MPC-be. Do I have to put those same files in the MPC folder? Is MPC-be really the best player for this? Remember that I want to play the disc directly in a player on a Windows 11 PC.
I have never had any luck getting mpc-be to play uhd discs directly. MPC-HC yes, not MPC-BE.
alexbar
#1995 Post by alexbar » Thu May 28, 2026 5:30 pm
Toscaclarinet wrote: Wed May 27, 2026 5:11 am
How did you do it?
