I have sent information to make his drive UHD capable.tomty89 wrote: Tue May 19, 2026 9:28 pmHmm I thought drive without UHD capable firmware will not "see" UHD disc when inserted? Or do you mean some UHD firmware is bugged or so?Coopervid wrote: Tue May 19, 2026 9:21 pm All well meant but I have sent information to make his drive UHD capable. No chance w/o flashing to UHD.
LibreDrive for Pioneer drives
Not really sure what you mean but what I meant was:Coopervid wrote: Tue May 19, 2026 9:35 pmI have sent information to make his drive UHD capable.tomty89 wrote: Tue May 19, 2026 9:28 pmHmm I thought drive without UHD capable firmware will not "see" UHD disc when inserted? Or do you mean some UHD firmware is bugged or so?Coopervid wrote: Tue May 19, 2026 9:21 pm All well meant but I have sent information to make his drive UHD capable. No chance w/o flashing to UHD.
Disc Information
Label: GET_OUT
Timestamp: 2017-06-28 08:14:37
Protection: AACS2.0/C v61
Data capacity: 60.59 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Besides, BDR-S12J-X is supposed to be an official UHD model anyway, AFAIK.
Should work as isalexbar wrote: Tue May 19, 2026 6:31 pm This one here:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: AIDL006471WL
Firmware date: 2020-07-21
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.01/ID72
Disc Information
Label: GET_OUT
Number of layers: 2
My drive is listed above but it doesn't appear to be supported yet. This is the model information as it appears on MakeMKV:
OS device name: /dev/rdisk6
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: CHDL115607WL
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
Thank you!
Revision: 1.14
Thank you!
Should work as isbiturbeh wrote: Wed May 20, 2026 3:01 pm My drive is listed above but it doesn't appear to be supported yet. This is the model information as it appears on MakeMKV:
Revision: 1.14
Thank you!
If you have volume key unknown see UHD disc section and look for keydb
Ah, the Goode Olde Verbatim 43888, Pioneer model! This UHD drive should work "out of the box" with MakeMKV, without needing to have its firmware updated first. After all, MakeMKV does[/] already say that LibreDrive is enabledbiturbeh wrote: Wed May 20, 2026 3:01 pm My drive is listed above but it doesn't appear to be supported yet. This is the model information as it appears on MakeMKV:
Revision: 1.14
drknight71
Thank you for the information. Was wondering why my old 211M 1.54 firmware was acting weird with non UHD disks. Ordering the Sata USB adapter. Thank you.Coopervid wrote: Tue May 05, 2026 3:54 pm All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
This 211 should be used internally. If you want to rule out the root cause you should get a Benfei USB -> SATA adapter like this. If it works with that your enclosures don't support all functions. Why this happens with this 211 I don't know.
https://www.amazon.com/BENFEI-Drive-Ada ... 9hdGY&th=1
PS: Can you please share if there is a firmware that will cross flash on the 1.54 to something else more friendly?
I have the BDR flash utility already with 1.53 firmware but don't think that will work.
drknight71
What about this one. Its a Benfei usb adapter but this one has external power support:
https://www.amazon.com/gp/product/B07JG ... XLEXM&th=1
It's not necessarily about power (power does matter) - it's about the USB -> SATA chipset & how completely/accurately it impliments the SATA standard. You won't find that listed in any specs. Must try/test with the adapter. And then, some Mfg's make design changes without changing model number (Archgon), and what was tested & did work, newer manufactured ones may not work.drknight71 wrote: Thu May 21, 2026 1:43 amCoopervid wrote: Tue May 05, 2026 3:54 pm All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
If the adapter with power has the same USB-SATA design/implementation, then it *should* be ok, or even better with the additional power.
Thanks,
Frank
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
Hi all,
I have two Pioneer drives which both do not detect UHD Blu-rays:
The BDR-S09 should be capable of, but for the BDR-212D I'm not sure.
OS device name: E:
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: removed
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.03
Firmware date: 2022-10-13
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.03/ID61
sure email me that infonotes4me wrote: Fri May 22, 2026 11:24 pm Hi all,
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.55 Serial number: removed Firmware date: 2023-02-16 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.55/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc insertedThe BDR-S09 should be capable of, but for the BDR-212D I'm not sure.Code: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.03 Serial number: removed Firmware date: 2022-10-13 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.03/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
and all others email me no need to post your info here publicly just reach out to me directly
see below for email
drknight71
nicholfd wrote: Thu May 21, 2026 2:04 amIt's not necessarily about power (power does matter) - it's about the USB -> SATA chipset & how completely/accurately it impliments the SATA standard. You won't find that listed in any specs. Must try/test with the adapter. And then, some Mfg's make design changes without changing model number (Archgon), and what was tested & did work, newer manufactured ones may not work.drknight71 wrote: Thu May 21, 2026 1:43 amCoopervid wrote: Tue May 05, 2026 3:54 pm All non-UHD drives flashed for UHD might say that they are BEE enabled but they "lie". The chip to do so is missing.
Thanks,
Frank
Wanted to confirm after using the Benfei adapter today so far no errors with the 211M Pioneer drive.
Thank you for your reply. You told me the truth, my drive is already ready for UHD Blu-ray. I managed to play the disc directly in VLC, AFTER having to update the makemkv registry. I added some extra files to the VLC Player folder, and I don't know if that's why it plays. However, it's not playing in MPC-be. Do I have to put those same files in the MPC folder? Is MPC-be really the best player for this? Remember that I want to play the disc directly in a player on a Windows 11 PC.Billycar11 wrote: Tue May 19, 2026 10:15 pmShould work as isalexbar wrote: Tue May 19, 2026 6:31 pm This one here:
OS device name: E:
Revision: 1.01
Disc Information
Label: GET_OUT
Number of layers: 2
Toscaclarinet
I have never had any luck getting mpc-be to play uhd discs directly. MPC-HC yes, not MPC-BE.alexbar wrote: Mon May 25, 2026 5:09 pm Thank you for your reply. You told me the truth, my drive is already ready for UHD Blu-ray. I managed to play the disc directly in VLC, AFTER having to update the makemkv registry. I added some extra files to the VLC Player folder, and I don't know if that's why it plays. However, it's not playing in MPC-be. Do I have to put those same files in the MPC folder? Is MPC-be really the best player for this? Remember that I want to play the disc directly in a player on a Windows 11 PC.
How did you do it?Toscaclarinet wrote: Wed May 27, 2026 5:11 amI have never had any luck getting mpc-be to play uhd discs directly. MPC-HC yes, not MPC-BE.alexbar wrote: Mon May 25, 2026 5:09 pm Thank you for your reply. You told me the truth, my drive is already ready for UHD Blu-ray. I managed to play the disc directly in VLC, AFTER having to update the makemkv registry. I added some extra files to the VLC Player folder, and I don't know if that's why it plays. However, it's not playing in MPC-be. Do I have to put those same files in the MPC folder? Is MPC-be really the best player for this? Remember that I want to play the disc directly in a player on a Windows 11 PC.
