Dump Submitted - Speed Racer 4k UHD
jiffypop
#1 Post by jiffypop » Tue May 19, 2026 5:47 pm
Disc Information
Label: SPEED_RACER
Timestamp: 2026-03-23 09:34:14
Protection: AACS2.0/C v82
Data capacity: 92.11 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Downloading latest HK to C:\Users\ellie/.MakeMKV ...
Saved AACS dump file as C:\Users\ellie/.MakeMKV/MKB20_v82_Speed_Racer_65B2.tgz
Emailed to svq@makemkv.com
dramaticaudio
Re: Dump Submitted - Speed Racer 4k UHD
#2 Post by dramaticaudio » Tue May 19, 2026 11:37 pm
I've never submitted a dump before but my app spit out a file called MKB20_v82_Speed_Racer_44CE.tgz. Is there somewhere that I should send this?
MrPenguin
#3 Post by MrPenguin » Tue May 19, 2026 11:59 pm
dramaticaudio wrote: Tue May 19, 2026 11:37 pm I've never submitted a dump before but my app spit out a file called MKB20_v82_Speed_Racer_44CE.tgz. Is there somewhere that I should send this?
You mean emailing it to svq@makemkv.com?
FWIW this disk has already been added to the public KEYDB.cfg file too, so if you download this file, copy it into the same directory as MakeMKV wrote your dump into, and then restart MakeMKV then it should work.
jiffypop
#4 Post by jiffypop » Wed May 20, 2026 12:15 am
Wow that was fast! I just got it delivered today and had it pre-ordered new key file works.
Just wrongly assumed I was the first at it. :)
dramaticaudio
#5 Post by dramaticaudio » Wed May 20, 2026 12:42 am
Fantastic. Thank you!
