Public KeyDB Disc Submissions
brandonyeo
Post by brandonyeo »
MrPenguin wrote: Tue May 19, 2026 9:58 am
brandonyeo wrote: Mon May 18, 2026 11:41 pm Disc dump filename: MKB20_v82_Speed_Racer_44CE.tgz
This disk was added to KEYDB.cfg last week. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
As a Windows user, you could also try using SamuriHL's KeyDB Helper utility to simplify installing/updating the KEYDB.cfg file.
Thank you so much for the KeyDB recommendation. Not quite sure why it wasn't reading before, even with the internet option enabled in settings.
Zeigster
Post by Zeigster »
Disc type: UHD
Disc ID: BD0A09FFA35318AF69DDE1E601389EB053AB7254
Disc dump filename: MKB20_v82_Scarlet_8040
Drive: BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1jhh_EH ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1j16TWD ... sp=sharing
queeg500
Post by queeg500 »
Some Like It Hot 4k Dump File for addition to public database
https://drive.google.com/file/d/1F4mZsa ... sp=sharing
MrPenguin
Post by MrPenguin »
queeg500 wrote: Wed May 20, 2026 8:25 am Some Like It Hot 4k Dump File for addition to public database
MKB20_v82_Some_like_it_hot_CEE1.tgz
Could you also provide the full AACS/MKB_RO.inf file from the physical UHD disk please? There is an entry for your disk in the latest KEYDB.cfg file, but it doesn't look compatible with your dump. Having the actual MKB_RO.inf file should help resolve this.
SFD136
Post by SFD136 »
Disc type: UHD BD
Disc dump filename: MKB20_v77_Fear_and_Dreams_Eason_Chan_Disc1_EFC0
Drive: BUFFALO Optical Drive (Marketing Model Name: BDXL-PTV6U3-BKB / LibreDrive: Enabled / Drive Platform: MT1959)
Drive firmware: 1.03
Did you sync the public keydb within the last 15 minutes?: Yes
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/z7tethv32l5u0do/
https://www.mediafire.com/file/o82gjemnygs818t/
Disc type: UHD BD
Disc dump filename: MKB20_v77_Fear_and_Dreams_Eason_Chan_Disc2_D65E
Disc dump / MKB_RO.inf link: https://www.mediafire.com/file/0lgwkpxtzepzsyq/
https://www.mediafire.com/file/y95db4r5bq7zvye/
Thank you very much.
NotThatGuy
Post by NotThatGuy »
EDIT: Scratch that, just found a bug in my keydb checker so the key is available :| Sorry about that
loucipher
Post by loucipher »
Saw this was submitted already, but I wasn't sure if multiple dumps from different drives were helpful, so I thought I'd do it anyway.
Disc type: Blu Ray
Disc ID: bd0a09ffa35318af69dde1e601389eb053ab7254
Disc dump filename: MKB20_v82_SCARLET_8040.tgz
Drive: BD-RW BDR-S13JX
Drive firmware: 1.03/ID72
MKB_RO.inf link: https://drive.proton.me/urls/JCZQNCNEZ8#8nfPWqFpX7t3
Disc dump link: https://drive.proton.me/urls/9B33XD2M6R#wt9785NUQcB3
MrPenguin
Post by MrPenguin »
loucipher wrote: Wed May 20, 2026 6:42 pm Saw this was submitted already, but I wasn't sure if multiple dumps from different drives were helpful, so I thought I'd do it anyway.
The trick is to have "one good dump" for each disk variant, e.g. 8040 in the case of this disk.
J3Joe
Post by J3Joe »
Disc type: BD-ROM UHD
Disk ID: C57394F0354C1B2F9F83E6BB53AFCD4C1E563C20D3B425C9B6D159500646C1EA
Disc dump filename:MKB20_v82_Return_To_Silent_Hill_8206
Drive:WH16NS60
MKB_RO.inf link: https://drive.google.com/file/d/12og-WF ... drive_link
Disc dump link: https://drive.google.com/file/d/1et8RPj ... sp=sharing
Thank you
MrPenguin
Post by MrPenguin »
J3Joe wrote: Wed May 20, 2026 8:20 pm Disc dump filename:MKB20_v82_Return_To_Silent_Hill_8206
Could you adjust the "Share" option for both these files please, so that people can access them?
loucipher
Post by loucipher »
MrPenguin wrote: Wed May 20, 2026 7:03 pm
Well, it's interesting, I actually have two dumps. The first time I ran it, before updating my KEYDB again, it came out in lowercase, MKB20_v82_Scarlet_8040.tgz, and the second one came out all caps. No idea why, but a diff shows that they're not the same. I can supply the lowercase one if that's helpful.
MrPenguin
Post by MrPenguin »
loucipher wrote: Wed May 20, 2026 9:54 pm Well, it's interesting, I actually have two dumps. The first time I ran it, before updating my KEYDB again, it came out in lowercase, MKB20_v82_Scarlet_8040.tgz, and the second one came out all caps. No idea why, but a diff shows that they're not the same. I can supply the lowercase one if that's helpful.
I suspect the lowercase one contains BDMV/META/DL/bdmt_*.xml files, whereas the other one does not. I don't know why MakeMKV sometimes excludes the bdmt_*.xml files from the dump, but it's a minor point in the bigger picture ;). The more cosmetic details can be added to the KEYDB.cfg entry by running "findvuk validate" against a copy of the physical UHD disk.
jenrashe
Post by jenrashe »
Greenland Migration
Disc type: UHD
Disc dump filename: MKB20_v82_BLU-RAY_UHD_D26E
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1iKtoKR ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1XY1oY_ ... sp=sharing
kuronekonoyoru
Post by kuronekonoyoru »
Timelesz momentum
Disc type: BD-ROM
Disc ID: MKB_v82_OVXX_11008_FE24
Drive: PIONEER BD-RW BDR-UD02
Drive firmware: 1.00
https://drive.google.com/drive/folders/ ... drive_link
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_Fear_and_Dreams_Eason_Chan_Disc1_EFC0
*MKB20_v77_Fear_and_Dreams_Eason_Chan_Disc2_D65E
*MKB20_v82_BLU-RAY_UHD_03AC
*MKB20_v82_BLU-RAY_UHD_D26E
*MKB20_v82_Et_Dieu_créa_la_femme_8EF4
*MKB20_v82_Hi_Mom_UHD_CD1A
*MKB20_v82_Hunters_Blood_6568
*MKB20_v82_IlMioNomeENessuno_3B92
*MKB20_v82_Insomnia_UHD_EAEC
*MKB20_v82_PARENTHOOD_E344
*MKB20_v82_SCARLET_8040
MKB20_v82_The_Bride!_43B8
*MKB20_v82_The_Devils_Candy_UHD_E58C
*MKB20_v82_The_Haunting_AA96
I believe all other valid submissions have been added to the public keydb. If any submitted disc remains unsupported, please read the opening post of this thread and provide all required details in a new post.
