Public KeyDB Disc Submissions
OK, cool, good to know! I have a procedural question then. This is the submission channel for dumps, but it's specifically in the UHD discs section. Do we want to submit dumps for standard blurays here, or should there be a separate thread for standard non-uhd discs?
This thread is happily accepting both UHD and BD dumps.loucipher wrote: Mon May 18, 2026 3:15 pm OK, cool, good to know! I have a procedural question then. This is the submission channel for dumps, but it's specifically in the UHD discs section. Do we want to submit dumps for standard blurays here, or should there be a separate thread for standard non-uhd discs?
Halloween 4
Disc type: UHD
Disc dump filename: MKB20_v82_Halloween4_29C0.tgz
Drive: LG BU40N
Drive firmware: 1.03 - Patched (microcode access re-enabled)
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1iGzi-O ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1iKtoKR ... drive_link
Disc type: UHD
Drive: LG BU40N
frameloose
Managed to FindVUK two discs, but this one wont do, the third party app says it has the disc but have not got a key in four days, maybe you have another way to get the Volume Key.
Cold Storage C16A
No entry for discid >1B13594DC28A55C2AD8925B94B431BDF41F881B7
https://drive.google.com/drive/folders/ ... axLWRmwquf
Cold Storage C16A
Halloween 5
Disc type: UHD
Disc dump filename: MKB20_v82_Halloween5_7082.tgz
Drive: LG BU40N
MKB_RO.inf link: https://drive.google.com/file/d/117abJS ... drive_link
Disc dump link: https://drive.google.com/file/d/1U-6VoR ... drive_link
Disc type: UHD
Drive: LG BU40N
polskasubie
Disc type: UHD
Disc dump filename: MKB20_v82_Ilsa,_the_Wicked_Warden_A38C.tgz
Drive: PIONEER BDR-BDS7
Drive firmware: Original (unpatched)
Disc dump link: https://drive.google.com/file/d/1_pcc5N ... drive_link
Can you adjust the "Share" option for this file please, so that people can access it?polskasubie wrote: Mon May 18, 2026 5:12 pm Disc dump filename: MKB20_v82_Ilsa,_the_Wicked_Warden_A38C.tgz
polskasubie
sorry about that... has been corrected...MrPenguin wrote: Mon May 18, 2026 5:39 pmCan you adjust the "Share" option for this file please, so that people can access it?polskasubie wrote: Mon May 18, 2026 5:12 pm Disc dump filename: MKB20_v82_Ilsa,_the_Wicked_Warden_A38C.tgz
FootFungus07
Avatar: Fire and Ash - 4K UHD TGZ & MKB_RO [UPDATE 5/19] - FIXED the TGZ file link to the CORRECT title, apologies for the mixup there.
Avatar Fire and Ash
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_7728.tgz
Label: AVATAR_FIRE_AND_ASH
Timestamp: 2026-04-10 13:39:45
Protection: AACS2.0/C v82
Data capacity: 86.88 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
TGZ File Link: https://drive.google.com/file/d/1MpoPeW ... drive_link
Avatar Fire and Ash
Number of layers: 3
Revision: 1.02
Actually, that TGZ dump file is MKB20_v82_FIRE_AND_ICE_0491.tgz, and the latest KEYDB.cfg file already contains this diskFootFungus07 wrote: Mon May 18, 2026 7:01 pm Avatar: Fire and Ash - 4K UHD TGZ & MKB_RO
Avatar Fire and Ash
brandonyeo
Speed Racer
Disc type: UHD
Disc dump filename: MKB20_v82_Speed_Racer_44CE.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10 - Patched (microcode access re-enabled)
MKB_RO.inf link: https://drive.proton.me/urls/1NG202ADA0#XLhYcxBRyucz
Disc dump link: https://drive.proton.me/urls/VDB0VP3990#BSB3b48y55r0
Disc type: UHD
FootFungus07
lol son of a derp - I uploaded that already lol! Too many Fire and Whatever titles. Here's the correct link: https://drive.google.com/file/d/1MpoPeW ... sp=sharingMrPenguin wrote: Mon May 18, 2026 7:12 pmActually, that TGZ dump file is MKB20_v82_FIRE_AND_ICE_0491.tgz, and the latest KEYDB.cfg file already contains this diskFootFungus07 wrote: Mon May 18, 2026 7:01 pm Avatar: Fire and Ash - 4K UHD TGZ & MKB_RO
Avatar Fire and Ash
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_7728.tgz.
This disk was added to KEYDB.cfg last week. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?brandonyeo wrote: Mon May 18, 2026 11:41 pm Disc dump filename: MKB20_v82_Speed_Racer_44CE.tgz
As a Windows user, you could also try using SamuriHL's KeyDB Helper utility to simplify installing/updating the KEYDB.cfg file.
Hi. This is my dump file.
Hope you can help decrypt. Thank you!
https://drive.google.com/drive/folders/ ... drive_link
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_AVATAR_FIRE_AND_ASH (0xFBDC96F79AE15CD611C4BF4261224F172E566C79)
*MKB20_v82_Avatar-_Fire_and_Ash_7728 (0x44F6D7CB148774EC65B9890E71E8F8CF0E18A50E)
*MKB20_v82_Halloween4_29C0
*MKB20_v82_Halloween5_7082
*MKB20_v82_Ilsa,_the_Wicked_Warden_A38C
*MKB20_v82_LEAVING_LAS_VEGAS_5CDC
*MKB20_v82_UHD_CLDS_DEUK_C16A
It would be great to have an equivalent thread within the BD section for AACS 1.0 disc dump files. But I feel like the relatively low number of AACS 1.0 disc dump submissions would limit the adoption/usage of a specialised thread.
