Dump submitted: Hunter's Blood (1986)
isp1985
Post by isp1985 » Sun May 17, 2026 11:28 pm
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOFPAIJ4832
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: Hunters_Blood
Timestamp: 2026-02-09 17:53:33
Protection: AACS2.0/C v82
Data capacity: 84.69 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Saved AACS dump file as C:\Users\Ted/.MakeMKV/MKB20_v82_Hunter's_Blood_6568.tgz
I can't seem to open this disc yet. I have the latest keydb.cfg from fvonline-db.bplaced.net
File submitted to svq@makemkv.com on 5/14/26.
Thank you.
MrPenguin
Re: Dump submitted: Hunter's Blood (1986)
Post by MrPenguin » Mon May 18, 2026 10:26 am
isp1985 wrote: Sun May 17, 2026 11:28 pm
Have you copied this KEYDB.cfg file into your "C:\Users\Ted/.MakeMKV/" directory and then restarted MakeMKV? If you still cannot rip your disk after doing this then could you upload this TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the KEYDB.cfg file.
isp1985
Post by isp1985 » Tue May 19, 2026 10:02 pm
MrPenguin wrote: Mon May 18, 2026 10:26 amHave you copied this KEYDB.cfg file into your "C:\Users\Ted/.MakeMKV/" directory and then restarted MakeMKV?
Yes.
MrPenguin wrote: Mon May 18, 2026 10:26 amIf you still cannot rip your disk after doing this then could you upload this TGZ dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the KEYDB.cfg file.
Thank you for the tip!
MKB20_v82_Hunters_Blood_6568
MrPenguin
Post by MrPenguin » Wed May 20, 2026 3:02 pm
isp1985 wrote: Tue May 19, 2026 10:02 pm Thank you for the tip!
And as a Windows user, you might also consider using SamutiHL's utility, to simplify the integration of the public KEYDB.cfg file with MakeMKV.
