Your dump is useless as you have not flashed your drive to enable libredrive. This is a requirement for reading UHD discs.rigormorti@aol.com wrote: Fri May 15, 2026 8:35 pm Drive Information
OS device name: E:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO2OAM94846
Highest AACS version: 82
Disc Information
Label: BLUE THUNDER UHD
Timestamp: 2026-01-30 11:23:15
Protection: AACS2.0/C v82
Data capacity: 92.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
https://drive.google.com/file/d/1QyiJ7x ... sp=sharing
Public KeyDB Disc Submissions
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v76_Do_the_Right_Thing_162B
*MKB20_v77_1984_5A02
*MKB20_v82_ReturnToSilentHill_1A0A
*MKB20_v82_THE_GENERAL_UHD_45E8
Good eye. In addition to LibreDrive not being enabled, the link isn't even publicly accessible. So it was a remarkably long post with no useful details that ended with an invalid link to a useless file.MartyMcNuts wrote: Fri May 15, 2026 10:44 pm Your dump is useless as you have not flashed your drive to enable libredrive. This is a requirement for reading UHD discs.
acforrester
Revision: 1.00
Serial number: 805HS012073
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Disc Information
Label: SPEED_RACER
Timestamp: 2026-03-23 09:34:14
Data capacity: 92.11 Gb
Number of layers: 3
https://drive.google.com/file/d/1Q0tlRt ... drive_link
Revision: 1.00
Disc Information
Label: SPEED_RACER
Number of layers: 3
keydb_helper
Hey acforrester, please read the first post of this thread and don't include all of those unnecessary details. The submission template is very clear and the requirement for publicly accessible download links isn't optional.acforrester wrote: Sat May 16, 2026 3:07 pm Drive Information
Label: SPEED_RACER
https://drive.google.com/file/d/...
Remember, if you can't access your link in private browsing/incognito mode you shouldn't post it to this thread
Alice In Wonderland UHD
Disc type: UHD
Disc ID: MKB20_v82_Alice_In_Wonderland_7522
Disc dump filename:MKB20_v82_Alice_In_Wonderland_7522.tgz
Drive:HL-DT-ST BD-RE BP60NB10
Drive firmware:1.02
LibreDrive status: Enabled (v06.3)
MKB_RO.inf link: https://drive.google.com/file/d/1YZnVyf ... share_link
Disc dump link: https://drive.google.com/file/d/1hxEgH8 ... share_link
Disc type: UHD
Drive firmware:1.02
Thanks, but KEYDB already contains this disk. Just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.gjlutz wrote: Sat May 16, 2026 8:51 pm Alice In Wonderland UHD
Disc type: UHD
Flow (2024)
Disc type: UHD
Disc ID: 0x43CACD6BF89C66C3ADEE3C784389CDC10B2F7FA9
Disc dump filename: MKB20_v82_UHD_Flow_1623.tgz
Drive: HL-DT-ST BD-RE BU40N
Drive firmware: 1.03 (Patched)
MKB_RO.inf link: [https://drive.google.com/file/d/1F6Iiwj ... sp=sharing]
Disc dump link: [https://drive.google.com/file/d/1H6G9Np ... sp=sharing]
Disc type: UHD
Disc type: UHD
Disc ID: 59a4802500d2e63f6cafef551f914df6951eedb6
Disc dump filename: MKB20_v61_The_Matrix_CCFD
Drive: BU40N
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/1ZQZC9JHPM#LIeLJwsQy1AI
Disc dump link: https://drive.proton.me/urls/GSYWVHRH18#aqbuMGHBG2sY
Disc type: UHD
Disc ID: ff847cda77e6d104925d5a1e64208962c54b67c8
Disc dump filename: MKB20_v65_The_Matrix_Reloaded_AEBF
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/7B6TF88BA8#tK65JNFASNVx
Disc dump link: https://drive.proton.me/urls/1F50NWN4NG#ypnWfalCGS48
Disc type: UHD
Disc ID: bb7549ecdd86a8afe56c418ab4cdddce639ec80d
Disc dump filename: MKB20_v65_The_Matrix_Revolutions_771D
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/01P11CYG78#epuHwGOt7LZj
Disc dump link: https://drive.proton.me/urls/8BZ3SP2BEW#BeX0h8Le4YR3
Drive: BU40N
Disc type: UHD
Drive: BU40N
Disc type: UHD
Drive: BU40N
This disk already has a fully validated entry in the latest KEYDB.cg file. The reason MakeMKV failed to decrypt it is likely because it failed to enable LibreDrive.noboddy wrote: Sat May 16, 2026 10:46 pm Flow (2024)
Disc type: UHD
jack_ripper
Did I submit something incorrectly or do some titles take longer to get sorted out; thanks!jack_ripper wrote: Tue May 12, 2026 7:53 pm Disc type: UHD
Disc ID: 2c7db48d18ac560e5f03b3e7b7527efb9888c53c
Disc dump filename: MKB20_v61_Blade_Runner_2049_9FAB
Drive: BUFFALO Optical Drive
MKB_RO.inf: https://drive.proton.me/urls/T4JXMY1FYC#Btjr3AIclHnb
Disc dump link: https://drive.proton.me/urls/Y68PW4APN8#gV4FUvEcnnF8
The KEYDB.cfg file already contains your disk, except its "Disc ID" is actually 0xD18F736EA922461CD8E9BD7420B4DB048FF38A48.jack_ripper wrote: Sun May 17, 2026 11:34 pmDid I submit something incorrectly or do some titles take longer to get sorted out; thanks!jack_ripper wrote: Tue May 12, 2026 7:53 pm Disc type: UHD
Perhaps you're not using the KEYDB.cfg file at all, because your log.txt file contains this line:
003339:0000 Automatic HK downloading is disabled or failed.Re: Public KeyDB Disc Submissions
This is interesting, getting an error "This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com...", which I've never seen before. I thought standard bluray had been well and truly cracked, but I guess they still have some obnoxious tricks up their sleeves. I did click the submit link, and also emailed the dumps as usual.
Disc type: Blu Ray
Disc ID: 3cb20edb93c3a473ccf3b96dfc714f5c07085295
Disc dump filename: MKB_v82_RESIDENT_ALIEN_S4D1_025A.tgz
Drive: BD-RW BDR-S13JX
Drive firmware: 1.03/ID72
MKB_RO.inf link: https://drive.proton.me/urls/DKTN0SYKTC#tIIxAI6K3g3h
Disc dump link: https://drive.proton.me/urls/SH4MQYBV60#xLUPrdsGLIbW
Disc type: Blu Ray
Disc ID: 989967cdef238f5e7825a5041b0afa71592a92fc
MKB_RO.inf link: https://drive.proton.me/urls/0QVFFCTMFR#zFWOVO3sj3nL
Disc dump link: https://drive.proton.me/urls/BZCYJVYQJC#PwGsHtVAwqKI
Disc type: Blu Ray
Disc type: Blu Ray
Blurays use 128 bit AACS encryption, and so cannot be "well and truly cracked" in the sense that DVDs have been. You can "brute-force" a DVD's keys in seconds even on a standard PC, whereas AACS cannot even be brute-forced using a quantum computing cluster! Any success in decrypting standard Blurays is due to Friendly Elves managing to obtain and publicly release both AACS device keys and AACS host certificates faster than AACS-LA can revoke them.loucipher wrote: Mon May 18, 2026 1:02 am I thought standard bluray had been well and truly cracked, but I guess they still have some obnoxious tricks up their sleeves.
With the arrival of MKBv82, the last publicly known host certificate for standard Blurays has now been revoked, and no replacement has been published. But this shouldn't be any problem now so long as your drive supports LibreDrive. And as for device keys, MakeMKV now seems to be handling them the same as UHDs by generating dump files for unknown disks.
OS device name: F:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK01N4KD0653
Firmware date: 2120-05-07 09:35
Highest AACS version: 78
Firmware version: 1.02
Disc Information
Label: TOP_GUN_MAVERICK
Timestamp: 2022-08-18 10:22:47
Protection: AACS2.0/C v76
Data capacity: 90.20 Gb
Number of layers: 3
https://drive.google.com/file/d/1Vc1hi5 ... sp=sharing
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 3
OK, cool, good to know! I have a procedural question then. This is the submission channel for dumps, but it's specifically in the UHD discs section. Do we want to submit dumps for standard blurays here, or should there be a separate thread for standard non-uhd discs?
