MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.2 id=CF9A35717F1B)
Saved AACS dump file as C:[Redacted].MakeMKV/MKB20_v82_STRAY_DOG_09B0.tgz
Dump Submitted - Stray Dog Criterion 4K
jhevans51
Re: Dump Submitted - Stray Dog Criterion 4K
You didn't mention if you had emailed the dump file to svq@makemkv.com so that it could be added to the program. Posting the file here can get the third-party database updated (usually), but does nothing for native capability.
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?jhevans51 wrote: Wed May 13, 2026 10:23 pm Saved AACS dump file as C:[Redacted].MakeMKV/MKB20_v82_STRAY_DOG_09B0.tgz
Since you're also using Windows, you could try using SamuriHL's KeyDB Helper utility too.
jhevans51
Ope! Thanks for the reminder! Long-time user, first time poster, lol.Woodstock wrote: Thu May 14, 2026 3:12 am You didn't mention if you had emailed the dump file to svq@makemkv.com so that it could be added to the program. Posting the file here can get the third-party database updated (usually), but does nothing for native capability.
