Dump Submitted - Stray Dog Criterion 4K
jhevans51
Post by jhevans51 »
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.2 id=CF9A35717F1B)
Saved AACS dump file as C:[Redacted].MakeMKV/MKB20_v82_STRAY_DOG_09B0.tgz
(3.25 MiB) Downloaded 3733 times
Re: Dump Submitted - Stray Dog Criterion 4K
You didn't mention if you had emailed the dump file to svq@makemkv.com so that it could be added to the program. Posting the file here can get the third-party database updated (usually), but does nothing for native capability.
MrPenguin
Post by MrPenguin »
jhevans51 wrote: Wed May 13, 2026 10:23 pm Saved AACS dump file as C:[Redacted].MakeMKV/MKB20_v82_STRAY_DOG_09B0.tgz
Since you're also using Windows, you could try using SamuriHL's KeyDB Helper utility too.
jhevans51
Post by jhevans51 »
Woodstock wrote: Thu May 14, 2026 3:12 am You didn't mention if you had emailed the dump file to svq@makemkv.com so that it could be added to the program. Posting the file here can get the third-party database updated (usually), but does nothing for native capability.
Ope! Thanks for the reminder! Long-time user, first time poster, lol.
