Public KeyDB Disc Submissions
mattmak464
Disc type: UHD
Disc ID: 0xC6B1F37D8FC5BA0EFFBC211CD4CA2B2B510E955E
Disc dump filename: MKB20_v82_Halloween_4_3872.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1xPyBKw ... share_link
Disc dump link: https://drive.google.com/file/d/10h1gxD ... share_link
Drive: BD-RE BU40N
mattmak464
Disc type: UHD
Disc ID: 0xEF2547ABEE5F0EAD1C1B8AE82AD2716D17D26268
Disc dump filename: MKB20_v82_Halloween_5_6600.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1EP4UJI ... share_link
Disc dump link: https://drive.google.com/file/d/1X9jGJc ... share_link
Drive: BD-RE BU40N
wierdkeydb_helper wrote: Fri May 08, 2026 3:53 am
Hey xokia, thanks for the attempt but it is really weird that you ignored the submission template except for a single line which wasn't even correct as your disc was added to the public keydb on April 23.
I literally used keydb_helper before uploading maybe its not updating?
*update* not only did keydb_helper not update my keydb.cfg file it zeroed out the existing file. hmmm.....
"UHD disc dump files are generally 3-8MB. If your disc dump is less than 1MB, you will need to manually include the MKB_RO.inf file when uploading your disc dump file. "
Figured MKB_RO.inf was not needed since the file was almost 4MB.
I'll try and be more careful next time
Disc type: UHD
Disc dump filename: MKB20_v82_ENTRE_LE_CIEL_ET_L_ENFER_UHD_1EF4
Drive: WH16NS60
Drive firmware: 1.03
MKB_RO.inf link: https://mega.nz/file/ok0AEJqB#jKtLEEdWi ... vA1QMBg97Q
Disc dump link: https://mega.nz/file/o4MDya4R#HcBQ-H93F ... Jox5pKLraw
Drive: WH16NS60
DiscVaultKeeper13
Title: Cold Storage (2026)
Volume: COLD_STORAGE
Disc Type: UHD Blu-ray
Protection: AACS2.0/C v82
MKB Version: 82
Drive: LG BU40N
Drive firmware: 1.03-MK
Dump filename: MKB20_v82_Cold_Storage_A2CB.tgz
Dump file available via Dropbox: https://www.dropbox.com/scl/fi/axtcfyuc ... eh0gd&dl=0
I have also emailed the dump to svq@makemkv.com. Thanks in advance!
UPDATE: Apologies I recognize a key was already created. I will make sure to check before posting next time.
MKB Version: 82
Drive: LG BU40N
Last edited by DiscVaultKeeper13 on Sat May 09, 2026 12:49 am, edited 1 time in total.
Disc type: UHD
Disc ID: 0x08A5E392C672E638117B63F760AB05DA7C153A08
Disc dump filename: MKB20_v61_Gladiator_6E87
Drive: BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1jD2oDL ... drive_link
Disc dump link: https://drive.google.com/file/d/1Azea2s ... drive_link
Drive: BU40N
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
(I know the naming is a bit confusing but my username keydb_helper is distinct from SamuriHL's KeyDB Helper tool and I'm not involved in the development of that software)
You can determine if the full MKB_RO.inf file is required without extracting the disc dump file by looking at the file name and noting the "variant ID" (Eg: 1EF4 in MKB20_v82_ENTRE_LE_CIEL_ET_L_ENFER_UHD_1EF4.tgz). This is a hexadecimal number and the partial MKB_RO.inf status is determined by the least significant bit. If the variant ID is even (LSB is zero), the disc dump file is complete. Otherwise, it will be a partial disc dump file and the MKB_RO.inf file must be supplied.
So these disc dump files are known to be complete dumps purely from the filename:
MKB20_v77_TOMBSTONE_8860.tgz
MKB20_v77_MADS_04A2.tgz
MKB20_v77_What_Lies_Beneath_4E74.tgz
MKB20_v77_Breakdown_5B66.tgz
MKB20_v77_THE_UMBRELLAS_OF_CHERBOURG_49D8.tgz
MKB20_v77_Pale_Rider_EA0A.tgz
MKB20_v77_The_Outlaw_Josey_Wales_B22C.tgz
MKB20_v77_DPIX006UHD_127E.tgz
Whilst these are partial/incomplete disc dump files as the final hexadecimal variant ID digit is odd:
MKB20_v61_BLADE_RUNNER_THE_FINAL_CUT_2781.tgz
MKB20_v77_Airplane!_5663.tgz
MKB20_v77_Nosferatu_EF45.tgz
MKB20_v76_Halloween_3C37.tgz
MKB20_v76_The_Bride_of_Frankenstein_C359.tgz
MKB20_v76_CAGLIOSTRO_UHD_572B.tgz
MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
MKB20_v76_The_Mummy_E51F.tgz
*MKB20_v82_ENTRE_LE_CIEL_ET_L_ENFER_UHD_1EF4
*MKB20_v82_Halloween_4_3872
*MKB20_v82_Halloween_5_6600
*MKB20_v82_MartySupreme_543C
*MKB20_v82_SENTIMENTAL_VALUE_BA54
No worries, thanks for the edit. Please make sure you include the full MKB_RO.inf file as well next time.DiscVaultKeeper13 wrote: Fri May 08, 2026 6:02 pm Dump filename: MKB20_v82_Cold_Storage_A2CB.tgz
Hey xokia, I'm not sure what might've happened to your local keydb.cfg file. You'll probably want to reach out to SamuriHL to see if there is some edge case in the KeyDB Tool or its interactions with FindVUK.xokia wrote: Fri May 08, 2026 6:03 am I literally used keydb_helper before uploading maybe its not updating?
I try to encourage folks to always include the MKB_RO.inf file. A significant number of MakeMKV users have generated a drive firmware dump at some point and this ends up getting included in every disc dump they create. Some users consistently provide 6-8MB disc dump files as they contain multiple drive firmware dumps. It can be tricky for these users to know whether they have produced a complete or incomplete disc dump file just by checking the file size.xokia wrote: Fri May 08, 2026 6:03 am "UHD disc dump files are generally 3-8MB. If your disc dump is less than 1MB, you will need to manually include the MKB_RO.inf file when uploading your disc dump file. "
PhilipNEIN
Disc type: UHD
Disc ID: 0x8efa69bf99e56491fe68c6111daa71db663a7573
Disc dump filename: MKB20_v77_Se7en_18EF.tgz
Drive: HL-DT-ST BD-RE BU40N
MKB_RO.inf link: https://1drv.ms/u/c/adff3152abb11a94/IQ ... 8?e=0pUuj8
Disc dump link: https://1drv.ms/u/c/adff3152abb11a94/IQ ... 0?e=2SbR2M
Thanks so much, keydb_helper! The updated config is now allowing the disc to be read, and as my PC is the only way I can watch them, being able to use MakeMKV makes this possible. Thank you!
Re: Public KeyDB Disc Submissions (G.I. Joe: The Riser of Cobra )
Disc type: UHD
Disc ID: 0xA342491E65E40822EF53CCCF108B105EAC1247A1
Disc dump filename: MKB20_v61_G_I_Joe_The_Rise_of_Cobra_C7DD
Drive: BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1D_trkk ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1XsFk8t ... sp=sharing
Drive: BD-RE BU40N
keydb_helper
*MKB20_v82_INVADERS_FROM_MARS (0x538C188F6A762EDFDFA2FA8A00952C4594325D42)
Re: Public KeyDB Disc Submissions (G.I. Joe: Retaliation)
Disc type: UHD
Disc ID: 0x9EBDD73A0546CA93F9A7F811225349C485BAA107
Disc dump filename: MKB20_v61_G_I_Joe-_Retaliation_7D1F
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1ycLeT- ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ZyYGvX ... sp=sharing
Drive: BD-RE BU40N
keydb_helper
*MKB20_v82_Bridesmaids_DFB2
*MKB20_v82_Pusher_1_66EA
*MKB20_v82_Pusher_2_9236
*MKB20_v82_Pusher_3_C012
Speed Racer (2008)
Disc type: UHD
Disc ID: 092778a1f884068ee7800d6676757e26e81fedbd
Disc dump filename: MKB20_v82_Speed_Racer_44CE.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://drive.google.com/file/d/1YtbTBW ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1r3WCBc ... sp=sharing
Disc type: UHD
Space Jam (1996) Australia / New Zealand release
Disc type: UHD
Disc ID: 0x7861F7320B72F38B69B1D83C229BF8773189A800
Disc dump filename: MKB20_v76_Space_Jam_E4EF
Drive: Pioneer BDR-XD07TB
Drive firmware: BDR-BDS7 1.05/ID05
MKB_RO.inf link: https://drive.google.com/file/d/1ISgob6 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1e1bpUf ... sp=sharing
Disc type: UHD
