Babylon 5 Blu Ray - multiple rip failures
NickBR
Post by NickBR » Tue May 12, 2026 10:32 am
I recently bought the complete Babylon 5 on Blu Ray.
Several discs will not rip with MakeMKV.
S2D4 will not rip at all. S3D2 only one episode will rip - and so on.
Tried on 2 computers each with three different BluRay drives (Toshiba, Verbatim (reskinned Pioneer) and Samsung.
I have given up and fired up my old copy of DVDFab - which rips every episode on every disc with no errors.
Interesting. If you have trouble ripping Blu Ray with MakeMKV, try DVDFab instead.
MrPenguin
Re: Babylon 5 Blu Ray - multiple rip failures
Post by MrPenguin » Tue May 12, 2026 11:35 am
NickBR wrote: Tue May 12, 2026 10:32 am I recently bought the complete Babylon 5 on Blu Ray.
Is that the large plastic box-set containing 21 disks, double-stacked? (Ugh!) What kind of errors are you seeing from MakeMKV? If this is the same box-set as mine, then all disks are MKBv68 without bus-encryption and should rip fine with MakeMKV.
