I have submitted the .tgz dump file for the new 2026 Pal, BFI release of "Invaders From Mars" 4K to svq email address.
2026 PAL 4K , BFI Invaders from Mars Dump submitted
Bob-Vidoh
MrPenguin
Re: 2026 PAL 4K , BFI Invaders from Mars Dump submitted
Can you also upload this dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cg file as well.Bob-Vidoh wrote: Mon May 11, 2026 4:59 pm I have submitted the .tgz dump file for the new 2026 Pal, BFI release of "Invaders From Mars" 4K to svq email address.
Bob-Vidoh
Hi,MrPenguin wrote: Mon May 11, 2026 8:15 pmCan you also upload this dump file into a file host such as OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cg file as well.Bob-Vidoh wrote: Mon May 11, 2026 4:59 pm I have submitted the .tgz dump file for the new 2026 Pal, BFI release of "Invaders From Mars" 4K to svq email address.
I don't have access to either of those services, however i have save the file to dropbox https://www.dropbox.com/scl/fo/6p3ewwpk ... hpl17&dl=0
Hope this helps
MrPenguin
Thanks, DropBox works tooBob-Vidoh wrote: Tue May 12, 2026 5:30 pm I don't have access to either of those services, however i have save the file to dropbox
Bob-Vidoh
Ok, that worked a treat. Thank youMrPenguin wrote: Tue May 12, 2026 7:27 pmThanks, DropBox works tooBob-Vidoh wrote: Tue May 12, 2026 5:30 pm I don't have access to either of those services, however i have save the file to dropbox. And I think your disk was added to the public KEYDB.cfg file two days ago, so if you download the latest file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV then it should all work.
