Some like it hot 4K (Manche mögens heiss) unknown Volume key
Sammler
Post by Sammler » Sat May 09, 2026 5:03 pm
The 4K-disk 'some like it hot' from Billy Wilder with Marilyn Monroe, Tony Curtis an Jack Lemmon from 1959 doesn't worK:
Using LibreDrive mode (v02.1 id=489CDFD6D392)
Direkter Zugriffsmodus wird verwendet
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
AACS Ausgabedatei als C:\Users\Roland/.MakeMKV/MKB20_v82_Some_like_it_hot_CEE1.tgz gesichert
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
Das Öffnen der Disk schlug fehl
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: CKDL124625WL
Firmware-Datum: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
Disk-Informationen
Label: SOME LIKE IT HOT
Zeitstempel: 2026-03-16 11:24:47
Schutz: AACS2.0/C v82
Datenkapazität: 93.21 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
MrPenguin
Re: Some like it hot 4K (Manche mögens heiss) unknown Volume key
Post by MrPenguin » Sun May 10, 2026 11:12 am
Sammler wrote: Sat May 09, 2026 5:03 pm The 4K-disk 'some like it hot' from Billy Wilder with Marilyn Monroe, Tony Curtis an Jack Lemmon from 1959 doesn't worK:
You need to email your MKB20_v82_Some_like_it_hot_CEE1.tgz file to svq@makemkv.com. And could you also upload this file into (say) OneDrive or Google Drive please, along with the full AACS/MKB_RO.inf file from your physical UHD disk? This would allow people to try adding your disk to the public KEYDB.cfg file as well.
Note that while your TGZ dump file will already contain a file called AACS/MKB_RO.inf, this particular copy of the file will have been truncated to only 56 bytes, making it unusable to anyone except MakeMKV itself.
Sammler
Post by Sammler » Sun May 10, 2026 4:33 pm
I sent the file.
Thank you!
MrPenguin
Post by MrPenguin » Sun May 10, 2026 11:33 pm
Sammler wrote: Sun May 10, 2026 4:33 pm I sent the file.
Great, this will allow MakeMKV to add your disk to its private "hashed keys" database at some point. Unfortunately, it's impossible to say when - it could be anything between a few days or even weeks. Could you also upload your TGZ dump file into a file host such as Google Drive or OneDrive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file as well, and potentially sooner than to MakeMKV's hashed keys.
