Thank you very much the copye is in progress now.
Thank you KEYDB_HELPER
Public KeyDB Disc Submissions
mattmak464
Disc type: UHD
Disc ID: 0x98D51B20626EC82A7EE574E84DD258B5660B1322
Disc dump filename: MKB20_v82_Hamnet_E89C.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1-GYnnT ... share_link
Disc dump link: https://drive.google.com/file/d/16oMuWp ... share_link
Drive: BD-RE BU40N
keydb_helper
Thanks mattmak464, your disc has been added to the public keydb.mattmak464 wrote: Thu May 07, 2026 6:52 am Disc type: UHD
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Captain Ron
keydb_helper. I had indeed downloaded the correct keydb.cfg file but it needed relocated to the MakeMKV data directory. Now my "Send Help" UHD is decrypting and backing up fine.
Thanks for your help with this. I understand the process properly now.
rdschouw
Disc type: Blu-Ray
Disc ID: f77536fc7b34e964c2e293f12dc4efb51c85c80c
Disc dump filename: MKB_v82_Gilmore_Girls_The_Series_Season_1_Disc_1_B0DE
Drive: BD-RE WH16NS60
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1QJJhgg ... F9ZhwJ899n
Disc dump link: https://drive.google.com/file/d/1VrN2HR ... drive_link
MrPenguin
Seeing as you are also a Windows user, may I suggest SamuriHL's KeyDB Helper utility asCaptain Ron wrote: Thu May 07, 2026 8:43 am keydb_helper. I had indeed downloaded the correct keydb.cfg file but it needed relocated to the MakeMKV data directory. Now my "Send Help" UHD is decrypting and backing up fine.Thanks for your help with this. I understand the process properly now.
This utility acts as a convenient front-end to the FindVUK program, allowing you to perform incremental updates to your local KEYDB.cfg file, as well as copying this file to the correct directory for MakeMKV to use. And in some cases, it may even be able to infer what a missing entry should be, validate it against your disk and then upload that entry into the online KEYDB without any outside assistance at all
Validating existing "(NOTVALIDATED)" entries for any disks you may own is also useful, of course...
FootFungus07
Alice in Wonderland 4K UHD
MKB20_v82_Alice_In_Wonderland_E2E4.tgz
Label: ALICE_IN_WONDERLAND
Timestamp: 2026-03-05 14:20:04
Protection: AACS2.0/C v82
Data capacity: 56.2 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Product: BD-RE BP60NB10
Here's my Google Drive link:
https://drive.google.com/file/d/1arDLeQ ... drive_link
Number of layers: 2
xokia
Disc Information
Label: GOAT
Timestamp: 2026-03-10 18:44:39
Data capacity: 68.64 Gb
Number of layers: 3
https://limewire.com/d/bArDK#volhdZPsAk
Linked to uploaded MKB20_v82_GOAT_431A.tgz
Label: GOAT
Number of layers: 3
jabbo13
Bridesmaids (2011)
Disc type: UHD
Disc ID: 57707cccb4d980dad039b6d4ce0d0edbf24338be
Disc dump filename: MKB20_v82_Bridesmaids_C946
Drive: BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Link
Disc dump link: Link
Disc type: UHD
Drive: BD-RE BU40N
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
All of these details are either irrelevant for the purposes of this thread or they can be obtained from the disc dump file:
*MKB20_v82_Bridesmaids_UPK75_C946
Thanks for the update. Glad to hear you got it working.Captain Ron wrote: Thu May 07, 2026 8:43 am keydb_helper. I had indeed downloaded the correct keydb.cfg file but it needed relocated to the MakeMKV data directory. Now my "Send Help" UHD is decrypting and backing up fine.Thanks for your help with this. I understand the process properly now.
Hey xokia, thanks for the attempt but it is really weird that you ignored the submission template except for a single line which wasn't even correct as your disc was added to the public keydb on April 23.xokia wrote: Fri May 08, 2026 12:51 am Disc Information
Label: GOAT
xokia wrote: Fri May 08, 2026 12:51 am Timestamp: 2026-03-10 18:44:39
Number of layers: 3
mattmak464
Disc type: UHD
Disc ID: 0xC6B1F37D8FC5BA0EFFBC211CD4CA2B2B510E955E
Disc dump filename: MKB20_v82_Halloween_4_3872.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1xPyBKw ... share_link
Disc dump link: https://drive.google.com/file/d/10h1gxD ... share_link
Drive: BD-RE BU40N
mattmak464
Disc type: UHD
Disc ID: 0xEF2547ABEE5F0EAD1C1B8AE82AD2716D17D26268
Disc dump filename: MKB20_v82_Halloween_5_6600.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1EP4UJI ... share_link
Disc dump link: https://drive.google.com/file/d/1X9jGJc ... share_link
Drive: BD-RE BU40N
xokia
wierdkeydb_helper wrote: Fri May 08, 2026 3:53 am
I literally used keydb_helper before uploading maybe its not updating?
*update* not only did keydb_helper not update my keydb.cfg file it zeroed out the existing file. hmmm.....
"UHD disc dump files are generally 3-8MB. If your disc dump is less than 1MB, you will need to manually include the MKB_RO.inf file when uploading your disc dump file. "
Figured MKB_RO.inf was not needed since the file was almost 4MB.
I'll try and be more careful next time
Liersi
Disc type: UHD
Disc dump filename: MKB20_v82_ENTRE_LE_CIEL_ET_L_ENFER_UHD_1EF4
Drive: WH16NS60
MKB_RO.inf link: https://mega.nz/file/ok0AEJqB#jKtLEEdWi ... vA1QMBg97Q
Disc dump link: https://mega.nz/file/o4MDya4R#HcBQ-H93F ... Jox5pKLraw
Drive: WH16NS60
DiscVaultKeeper13
Title: Cold Storage (2026)
Volume: COLD_STORAGE
Disc Type: UHD Blu-ray
MKB Version: 82
Drive: LG BU40N
Drive firmware: 1.03-MK
Dump filename: MKB20_v82_Cold_Storage_A2CB.tgz
Dump file available via Dropbox: https://www.dropbox.com/scl/fi/axtcfyuc ... eh0gd&dl=0
I have also emailed the dump to svq@makemkv.com. Thanks in advance!
UPDATE: Apologies I recognize a key was already created. I will make sure to check before posting next time.
MKB Version: 82
Drive: LG BU40N
Last edited by DiscVaultKeeper13 on Sat May 09, 2026 12:49 am, edited 1 time in total.
