Cold storage 4k dump submitted (A2CB)
2wicky
Post by 2wicky »
Purchased from Movies Unlimited.
MrPenguin
Re: Cold storage 4k dump submitted (A2CB)
Post by MrPenguin »
2wicky wrote: Tue May 05, 2026 5:16 am Purchased from Movies Unlimited.
This TGZ dump file is too small, and so must only contain a truncated AACS/MKB_RO.inf file (56 bytes). Can you upload the full AACS/MKB_RO.inf file from your UHD disk into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk into the public KEYDB.cfg file.
2wicky
Post by 2wicky »
My apologies but how do I get the full file?
MrPenguin
Post by MrPenguin »
2wicky wrote: Tue May 05, 2026 1:44 pm My apologies but how do I get the full file?
Put your disk into your UHD drive, wait until it appears in Windows File Explorer, navigate to the disk's AACS/ folder and then zip up the MKB_RO.inf file inside it. The full file is multiple MB in size, and so should ideally be compressed before uploading it into OneDrive or Google Drive.
2wicky
Post by 2wicky »
MrPenguin
Post by MrPenguin »
2wicky wrote: Tue May 05, 2026 2:40 pm Here's the link to the file.
Thanks. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
