Public KeyDB Disc Submissions
player7
Post by player7 » Thu Apr 30, 2026 5:32 am
MrPenguin wrote: Wed Apr 29, 2026 10:22 pm
player7 wrote: Wed Apr 29, 2026 8:08 pm Disc dump filename:MKB20_v82_WICKED_FOR_GOOD_6D8E
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
Disc dump link:
Ahem, I believe both of your links are the same? ;) However, I also suspect that the public KEYDB already contains this disk anyway. Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
yes tried the keydb without success, manually scanning the file i found plenty of entries for this title, but neither the sha1 was to be found nor the 6D8E name ending, so I assume this is a new type.
updated my original post link, of course I had to mess something up, sorry.
Grahamdoh
Post by Grahamdoh » Thu Apr 30, 2026 10:28 am
keydb_helper
Post by keydb_helper » Thu Apr 30, 2026 10:50 am
excalibur wrote: Thu Apr 30, 2026 1:01 am Okay my issue was i forgot that my makemkv dir for the keydb.cfg was moved to a location that wasn't the default one. thank you!!
Glad to hear you got it working.
Grahamdoh wrote: Thu Apr 30, 2026 10:28 am Becoming Led Zeppelin Blu-ray
Thanks Graham, your disc has been added to the public keydb.
The D6CC variant of Goat (MKB20_v82_GOAT_D6CC) has also been added to the keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Grahamdoh
Post by Grahamdoh » Thu Apr 30, 2026 11:49 am
kasko
Post by kasko » Thu Apr 30, 2026 2:10 pm
keydb_helper
Post by keydb_helper » Thu Apr 30, 2026 3:26 pm
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_LA_GRAZIA_A830
MKB20_v82_MERCY_7181
*MKB20_v82_MissioneShelter_A6C2
kasko wrote: Thu Apr 30, 2026 2:10 pm MKB20_v82_MERCY_7181
Hi kasko, please try using SamuriHL's KeyDB Tool in the future. This particular disc would've been supported so you could've avoided posting and waiting for someone to process your disc dump. If your disc isn't supported by the KeyDB Tool, feel free to post to this thread.
player7 wrote: Thu Apr 30, 2026 5:32 am yes tried the keydb without success, manually scanning the file i found plenty of entries for this title, but neither the sha1 was to be found nor the 6D8E name ending, so I assume this is a new type.
Hi player7, your disc dump is unusable as LibreDrive was not correctly enabled. Any disc dump log file which contains output like this excerpt (or the localised equivalent) is unusable:
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' trat auf während der Übertragung des SCSI-Befehls AD010..080002400 zu Laufwerk 'SG:dev_21:4'
DEBUG: Code 0 at ?>@=1r\!W?_}[zdZ6:213130306
001003:0020 DEBUG: Code 0 at oH+-D*FQAz1#bPXt1=:121264395
001003:0020 DEBUG: Code 4 at oH+-D*FQAz1#bPXt1=:213130789
003306:0000 AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
This is a transient issue, so it should be resolved by power cycling your drive and generating a new disc dump file. There is no need to reflash or modify the installed firmware.
KeyDB Priority List
player7
Post by player7 » Fri May 01, 2026 2:59 pm
keydb_helper wrote: Thu Apr 30, 2026 3:26 pm Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
sorry didn't know that! Power cycling didn't help, had to switch to windows for the error to go away. now the keyDB update did the trick, no need to upload new keys anymore, thanks for the kind help!
DiscVaultKeeper13
Post by DiscVaultKeeper13 » Fri May 01, 2026 6:18 pm
MKB20_v82_Shelter_3260.tgz
Submitting dump file for the European UHD Blu-ray release of Shelter (2026) starring Jason Statham.
Disc information:
Title: Shelter (2026)
Volume: SHELTER
Disc Type: UHD Blu-ray
MKB Version: 82
Disc Date: 2026-03-06
Disc ID: 0x5E1648071FCB5BFA6B30131133B5AAA89D7E939E
Validation Data: 42E2A6CBF3550307BDFB10E715364B6F
Encrypted Key [1]: 0x81F089E662A7B3F829E6BEF0A3D35458
Dump filename: MKB20_v82_Shelter_3260.tgz
I have also emailed the dump to svq@makemkv.com.
keydb_helper
Post by keydb_helper » Sat May 02, 2026 1:52 am
*MKB20_v82_BODY_HEAT_6008
*MKB20_v82_FIGHT_CLUB_7318
*MKB20_v82_Patchwork_2986
*MKB20_v82_Shelter_3260
*MKB20_v82_THE_WIZ_UHD (0xBC85E946C4141D125B87641A744086B30904139C)
*MKB20_v82_UHD_ARCO_ADB2
DiscVaultKeeper13 wrote: Fri May 01, 2026 6:18 pm MKB20_v82_Shelter_3260.tgz
Hi DiscVaultKeeper13, thanks for the submission and welcome to the forum. Your disc has been added to the public keydb. In the future please use a file host such as Google Drive, Dropbox, OneDrive, MEGA, Swisstransfer etc instead of attaching files to your post. The forum has very limited storage capacity and it causes a headache for the forum admins when they have to clean up larger attachments.
KeyDB Priority List
German
Post by German » Sat May 02, 2026 4:30 am
Submitting dump file for Point Blank (1967) 4K UHD:
Disc type: UHD
Disc ID: E640894CC9B2200DCC2A72365F3B1D8C5BE46882
Disc dump filename: MKB20_v82_POINT_BLANK_E706
Drive: BD-RE BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link: https://limewire.com/d/URTbU#ZYv0B4Vefm
Disc dump link: https://limewire.com/d/XBHGz#GyOSIWYp1H
Many thanks for your time.
Best regards,
Germán
jackycyk0924
Post by jackycyk0924 » Sat May 02, 2026 9:16 am
Here is the information of a new Bluray disc. Thanks for help!
Disc type: BD / Blu-ray
Disc ID: 0x59d151544c370f0a3a33eaed9106d47f404a8f4b
Disc dump filename: MKB_v82_PDXX_70034_D58E.tgz
Drive: BD-RE ASUS SBW-06D5H-U
Drive firmware: E101
MKB_RO.inf link: https://drive.google.com/file/d/1M8lhLH ... drive_link
Disc dump link: https://drive.google.com/file/d/1N1gNge ... drive_link
DiscVaultKeeper13
Post by DiscVaultKeeper13 » Sat May 02, 2026 9:30 am
keydb_helper wrote: Sat May 02, 2026 1:52 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
TY! I will use a file host going forward.
MrPenguin
Post by MrPenguin » Sat May 02, 2026 11:41 am
KEYDB does actually contain your disk. But unfortunately, MakeMKV had failed to enable LibreDrive, and so bus encryption was still active.
jump4joy
Post by jump4joy » Sat May 02, 2026 2:20 pm
Wired For Chaos 2024
MKB20_v82_WiredForChaos_5A38
https://www.swisstransfer.com/d/4201727 ... 7e7f29a71d
keydb_helper
Post by keydb_helper » Sat May 02, 2026 4:41 pm
German wrote: Sat May 02, 2026 4:30 am Hi,
Disc type: UHD
Hey Germán, welcome to the forum. Your disc has been added to the public keydb. Thanks for following the template so carefully.
jump4joy wrote: Sat May 02, 2026 2:20 pm Wired For Chaos 2024
Hey jump4joy, thanks for the new disc dump. Your disc has also been added to the public keydb.
DiscVaultKeeper13 wrote: Sat May 02, 2026 9:30 am TY! I will use a file host going forward.
Thanks, I'm sure that will be appreciated by the forum admins and moderators.
MrPenguin wrote: Sat May 02, 2026 11:41 am KEYDB does actually contain your disk. But unfortunately, MakeMKV had failed to enable LibreDrive, and so bus encryption was still active.
Good call MrPenguin. I'm not sure how I missed the fact it was already present in the keydb.
KeyDB Priority List
