Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
asmcom
Post by asmcom »
lmwardx wrote: Tue Mar 17, 2026 3:45 pm
Coopervid wrote: Tue Mar 17, 2026 1:37 pm
lmwardx wrote: Tue Mar 17, 2026 11:48 am
Thank you, Marty! Quick question - the only bin file I'm seeing in the firmware pack is the HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin file - it doesn't really say 1.03 MK. Is this the correct one? If so, I will try again, but I did try this in the SDFtool and I'm still getting that my drive is a BP50NB50, even after applying the BP60NB10 file.
Appreciate the response!
Yes, that is the MK firmware. First flash this. Make sure that it is then showing this in Makemkv info. The start the recovery process as shown in the gif.
viewtopic.php?f=16&t=22896&hilit=SDFTool
So I definitely didn't scroll down far enough to download your specific All You Need Firmware Pack... I just had the one that was posted in the main topic of this thread. I downloaded yours, followed your instructions/GIF and everything worked like a charm!
To claim one more moment of your expertise - I downloaded the BP60NB10 1.00 MK firmware to my drive, but there is a 1.02 MK bin available. Is it better to upgrade to the 1.02 or leave as 1.00? My other disc drive (same model, but SVC is the NB50) is 1.02, so wasn't sure if it was recommended I flash to latest version.
Appreciate your time!
We have extensively tested the BP55EB40 with both 1.02MK and 1.00MK firmware versions.
Firmware 1.00MK is clearly the best option if you are using the drive solely with MakeMKV. If you require broader compatibility (e.g. DVDFab support), then the BU40N with 1.00DE firmware is the better choice.
In our testing, 1.02MK frequently failed on discs where 1.00MK succeeded first time.
We would agree with martymcnuts, newer is not always better.
UHD Friendly Drive Team
Asmcom :mrgreen:
babayaga
Post by babayaga »
tomty89 wrote: Sun Apr 19, 2026 1:23 am
babayaga wrote: Sat Apr 18, 2026 6:56 pm So the trick was to only flash DE_LG_BU40N_1.03_MK.bin and everything worked, no more no less, it's a bit hard to understand sometimes in this forum, what you should actually do, and the guide can be a bit misleading i think. And what about the HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin that is included with the flasher? is this a newer iteration of the 1.03MK firmware or just a original 1.04 firmware?
Files in the MK firmware pack are all MK firmware. An MK firmware is just an original firmware of the same version number that has been patched in some way, so when there is a more updated original firmware, there's a chance that mike could patch it and update the pack.
(Note really sure what DE_LG_BU40N_1.03_MK.bin is.)
... If your drive has one of these firmwares, and there is no MK version of the same firmware/drive model or higher number, you will have to sidegrade to ... or (BU40N 1.03MK LG Slim drives ONLY) ...
But I have to admit that I'm also not sure whether there's something "special" about HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin, or if it's just that "The all you need firmware pack" and the guide didn't catch up with it when the MK firmware pack got updated...
P.S. The thing is being more updated does not necessarily means the firmware is better, especially when it comes to UHD capability / ripping compatibility / ... (what people here mainly concern). Also maybe whoever maintains the guide / all you need pack follows the "not broken don't fix it" policy (while mike just tried his best in MK-ising the relevant original firmware when new versions showed up).
No, this is the reason so many people ask the same question here, because there are tons of different firmware packs, flashers, and what not, now im reading that pioneer players (built within the years of working firmware that is), doesn't need firmware updates (well, they can update), but they do read UHD discs out of the box, and a firmware is not really needed? or am im completely in the woods :)
tomty89
Post by tomty89 »
Well after all these are just "community efforts" from different people, and they might all have a different thought about e.g. what's neat.
I think the all you need firmware pack(s) was actually trying to simplify things for people, but I guess sometimes when you do that things could end up getting a bit confusing.
I don't think there are really that many flasher, unless you count those that are for e.g. recovery purpose. For the "liberation" of the LG/ASUS drives there is just really one, command-line sdftool / makemkvcon f (which are really the same thing).
(I think the GUI sdftool flasher is a wrapper / clone of the CLI one that comes with MakeMKV, and works in only Windows, but I could be wrong.)
P.S. Do not "update" your Pioneer drive with official updater from Pioneer, especially not an updater that were released after November 2022. I don't think there is any case that you would need / want to do that. "Upgrading" as in crossflashing with a firmware of a later-generation drive is another story. You might have a better idea once you receive the flasher frome someone as it comes with a manual. I also explained it for a bit in the other thread where you asked.
ralauscon
Post by ralauscon »
Are you able to flash pioneer bdr-xd05?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: SADL091165UC
Firmware date: 2017-06-22
Highest AACS version: 68
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
ralauscon wrote: Tue Apr 21, 2026 1:12 am Are you able to flash pioneer bdr-xd05?
OS device name: F:
Revision: 3.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Erdie
Post by Erdie »
Dear all,
I am new here and I have issue with my brand new Asus SBW-06D5H-U. The Drive information is:
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: A102
Serienummer: MO9OCA91429
Firmware-Datum: 2124-08-05 14:55
Markierungen der Bus-Verschlüsselung: 1F
As far as I know the required firmware would be "ASUS-SBW-06D5H-U-A102-MK". But I do not know where to get it. Any help is appreciated.
Thank you
Erdie
Erdie wrote: Thu Apr 23, 2026 6:15 pm Dear all,
Produzent: ASUS
Revision: A102
Thank you
Erdie
Treat it as a bu40n
Or email me or Marty for an automated flasher
inw13210
Post by inw13210 »
I got Logitec LBD-PWA6U3L and i can't rip UHD Bluray
Do i have to flash firmware?
If i have to, what firmware i have to download?
OS device name: G:
Product: BD-RE BP71N
Revision: 1.03
Serial number: SIK09P7GB1515
Firmware date: 2122-02-18 16:25
Bus encryption flags: 1F
Highest AACS version: 61
Erdie
Post by Erdie »
Thanks Billy, I have now a working device!
nicholfd
Post by nicholfd »
inw13210 wrote: Sat Apr 25, 2026 10:24 am I got Logitec LBD-PWA6U3L and i can't rip UHD Bluray
You need to post the MakeMKV drive info for anyone to be able to help you.
inw13210
Post by inw13210 »
nicholfd wrote: Sat Apr 25, 2026 4:15 pm
I already fix the post
nicholfd
Post by nicholfd »
inw13210 wrote: Sat Apr 25, 2026 6:02 pm
Looks like others successfully flashed the drive to BU40N-1.03 for 4K/UHD.
See this thread:
viewtopic.php?f=16&t=28105&p=198604&hil ... 1N#p198604
adradr
Post by adradr »
Hello all. Thought I'd post in this thread rather than opening a new one, but if it's preferred I post a standalone thread, I'd be happy to.
I am attempting to flash a Buffalo BRXL-16U3 on a Mac.
Product: BD-RE BH16NS58
Revision: 1.03
Firmware date: 2120-05-08 09:33
I paid attention to the first post of this guide and downgraded my MakeMKV :wink: and downgraded my MakeMKV to 1.17.7 (I bought a license to satisfy the prompt that said I needed to. Afterwards the initial launch would say that the program failed, though it still started up alright).
I moved the
sdf.bin
file and the version of the firmware that my searches of the forum indicated I should use
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
to the /tmp directory and fired up the CLI to get the drive ID
$ cd /Applications/MakeMKV.app/Contents/MacOS
$ ./makemkvcon f -l
After that I ran the full command:
./makemkvcon f -d '/IOBDServices/B16D63D6' -f /tmp/sdf.bin rawflash main -i '/tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin'
Which completed with a "Done successfully"
Then I reinstalled the latest version of MakeMKV (because of the fatal error bug) and unplugged the drive and plugged it back in. But the firmware remains the original version.'
Happy to try again or take a new tack. Can I just use 1.18.3?
adradr wrote: Sat Apr 25, 2026 8:44 pm Hello all. Thought I'd post in this thread rather than opening a new one, but if it's preferred I post a standalone thread, I'd be happy to.
Revision: 1.03
I moved the
sdf.bin
$ ./makemkvcon f -l
You need to follow enc instructions
nicholfd
Post by nicholfd »
Revision: 1.03
I moved the
sdf.bin
$ ./makemkvcon f -l
No need to downgrade or use an old version of MakeMKV on macOS. It's great that you bought a license of MakeMKV - need to support those who support our hobby. I'm not aware of any requirement to buy a license to use the tool, as long as you have a current/non-expired "beta" key.
That drive has encrypted firmware. You need to use the encryption option ("enc" I believe - check the instructions).
Thanks,
Frank
