Public KeyDB Disc Submissions
kario
Post by kario »
Disc type: UHD
Disc ID: 5ca12765838b68802e7f424f4e473cba7ff84a12
Disc dump filename: MKB20_v68_Once_Upon_a_Time_in_Hollywood_A603
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/1WA74ADPQG#u7KFUrMJPddW
Disc dump link: https://drive.proton.me/urls/G8ACYSVBRG#p7lacUnIvbIB
buffalobossie
Post by buffalobossie »
Faces of Death
Disc type: UHD
Disc ID: 6a7c666a5f9570f50853080aacfdac7fa962faae
Disc dump filename: MKB20_v82_VSA062UHD_7073.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1IhVxdP ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1CFaxL0 ... sp=sharing
Escape from Death
Disc type: UHD
Disc ID: c40bf3d0b7cc82480e1ca0d81a80d8efb774f9de
Disc dump filename: MKB20_v82_VS532UHD_D755.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1ZAGTD2 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1lpOJhg ... sp=sharing
Mutant
Disc type: UHD
Disc ID: 4d9ac13c2ce5835049ba5575e8a4a71e3787ee95
Disc dump filename: MKB20_v82_VS533UHD_3FB7.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1oLSxJC ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1546eYp ... sp=sharing
Skolven
UHD Submission - LA FEMME DE MENAGE (French Edition) - MKB v82
Post by Skolven »
Hi everyone,
I'm submitting the dump for the French UHD release of "La Femme de Ménage" (The Housemaid).
MakeMKV was unable to generate a .tgz file due to hash/checksum errors during the initial scan, so I have provided a manual dump of the full AACS directory.
Disc type: UHD
Disc ID: 0x4CEB5BD47BD46ADCBC28C5684007541E0839F7D6
Disc dump filename: MKB20_v82_LA_FEMME_DE_MENAGE_35CA.zip
Drive: Verbatim 43888 (External)
Drive firmware: 1.03-MK (LibreDrive Enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1Ifx-NP ... sp=sharing
Full AACS Dump link: https://drive.google.com/file/d/10y9_YQ ... sp=sharing
Thanks in advance for adding this :D
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v68_Once_Upon_a_Time_in_Hollywood_A603
*MKB20_v77_Reservoir_Dogs_07F1
*MKB20_v82_88FU046A_BB74
*MKB20_v82_BD_88FU046B_C142
*MKB20_v82_BDROM_D1F4
*MKB20_v82_Diabolisch_6906
*MKB20_v82_HIGHEST_2_LOWEST_7B16
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Iannautilus
Post by Iannautilus »
Usual Suspects Steelbook UHD (French Version)
Disc type: UHD
Disc ID: 0xc5e3676b1929b3a6e673d20d8745c158b9df9e60
Disc dump filename: MKB20_v82_BDROM_10B5
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1GntfRy ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1givYB9 ... sp=sharing
warhorus
Post by warhorus »
Cauldron Film's UHD release of Fulci's Conquest (1983):
Disc type: UHD
Disc ID: fcb7d73e5239ef2ea62f775e9bdb41d6bbc3169b
Disc dump filename: MKB20_v82_Conquest_8827.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1mTXoD8 ... drive_link
Disc dump link: https://drive.google.com/file/d/12QqXQx ... drive_link
(Edit: updated MKB_RO.inf file with proper version from the disc, not the .tgz)
warhorus
Post by warhorus »
Cauldron Film's UHD release of Franco's Jack the Ripper (1976):
Disc type: UHD
Disc ID: 959c95ab01301ba5bf641d26afc97816e1ef678d
Disc dump filename: MKB20_v82_Jack_the_Ripper_2B7D.tgz
Drive: BW-16D1HT
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1PUAv3D ... drive_link
Disc dump link: https://drive.google.com/file/d/1JuHg4T ... drive_link
(Edit: Corrected MKB_RO.inf link to reflect copy found on disc, not from the .tgz)
MrPenguin
Post by MrPenguin »
warhorus wrote: Sat Apr 25, 2026 4:11 pm MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
Your MKB_RO.inf files are only 56 bytes long, which means you have done what the instructions say not to do. We already have these 56-byte-long MKB_RO.inf files because they are the ones from the TGZ files which you have provided. Can you provide the MKB_RO.inf files from the actual physical disks instead please?
warhorus
Post by warhorus »
I apologize for the oversight, this is what happens when you do things in a rush! Here are the updated linked (I'll edit the original posts as well):
Conquest: https://drive.google.com/file/d/1mTXoD8 ... drive_link
Jack the Ripper: https://drive.google.com/file/d/1PUAv3D ... drive_link
Sorry again for being That Guy!
keydb_helper
Re: UHD Submission - LA FEMME DE MENAGE (French Edition) - MKB v82
*MKB20_v82_BDROM_10B5
*MKB20_v82_ROBIN_HOOD-_PRINCE_OF_THIEVES_-_4K_UHD_2462
Skolven wrote: Fri Apr 24, 2026 9:18 pm Hi everyone,
Hi Skolven, welcome to the forum. The AACS directory alone is not sufficient for deriving disc keys. The discatt.dat or discattd.dat file generated by MakeMKV is also required. If you can get MakeMKV to start producing an encrypted full disc backup this should create a usable discatt.dat file early in the process. You can then cancel the backup and post a link to the discatt file to this thread.
KeyDB Priority List
A complete record has been uploaded to the KeyDB for the movie Mercy (2026). The dump has also been emailed to svq@makemkv.com for processing.
Disc ID: 488F1B926A653FE8C1F86611459FDE60C0CBD657
Dump File Name: MKB20_v82_MERCY_D857
anengma
Post by anengma »
Disc type: UHD
Disc ID: 791C768D45E847A7EACE764C9DC7886782B0908A
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_478D
Drive: BW-16D1HT
Drive firmware: 3.10MK
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1-Er1LT ... C3AJA/view
Disc dump link: https://drive.google.com/file/d/1FjZ6HL ... kB0t7/view
w00tabega
Post by w00tabega »
Street Trash UK UHD
Disc type: UHD
Disc ID: 4245F9B002A0637855DD0C2AC7D0A95FC712E806
Disc dump filename: MKB20_v82_Street_Trash_AFD8
Drive: BD-RE BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.septicisle.info/dudewhat/MK ... h_AFD8.rar
Disc dump link: https://www.septicisle.info/dudewhat/MK ... h_AFD8.tgz
keydb_helper
*MKB20_v82_GILDA_UHD_FEBA
*MKB20_v82_IT_WELCOME_TO_DERRY_S1_D1_9658
*MKB20_v82_IT_WELCOME_TO_DERRY_S1_D2_C1EC
*MKB20_v82_IT_WELCOME_TO_DERRY_S1_D3_933E
w00tabega wrote: Mon Apr 27, 2026 10:07 pm Street Trash UK UHD
Disc type: UHD
Hi w00tabega, thanks for the submission but I can't seem to access your links. Could you please try using a different file host?
KeyDB Priority List
Fresca
Post by Fresca »
Submitted to svq@makemkv.com as well
No Other Choice (2025) (Madman Australian release) 4K UHD
Disc type: UHD
Disc ID: sorry i have no idea how to get this with my player
Disc dump filename: MKB20_v82_No_Other_Choice_79CA.tgz
Drive: BD-RE BU40N
AACS dump & RO.inf file here: https://mega.nz/folder/kTQ20TDQ#di_rS4eZSiugyZPoGHVMZA
