Public KeyDB Disc Submissions
Disc type: UHD
Disc ID: 88b776fd0fa6c44f179b10fe51cb8db843f962a2
Disc dump filename: MKB20_v77_Reservoir_Dogs_07F1
Drive: BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/22M9H54YRC#KINdwjHpBwic
Disc dump link: https://drive.proton.me/urls/EQPGH95M7M#0tg3cnwPlQoL
Drive: BU40N
Thanks for thesebennof wrote: Thu Apr 23, 2026 11:48 am House of the Dragon Season 2 UHD Disc 1-4
Disc-ID:
0x80BD562C62161B3293D6A2ACAA64FEDC691E3B4D
0x4719ADD083545043F3E854DAF1D6C51219C54B35
0x007686B4FE71B81330747DA2A9E506D6355DECE6
0x639B8A1B2A170478AA5E8D03975DBFEAB22CD320
Disc dump filename:
MKB20_v77_HOUSE_OF_THE_DRAGON_S2_D1_6F8F
MKB20_v77_HOUSE_OF_THE_DRAGON_S2_D2_EB15
MKB20_v77_HOUSE_OF_THE_DRAGON_S2_D3_1045
MKB20_v77_HOUSE_OF_THE_DRAGON_S2_D4_0CE3
We are going to need to fix this entry for disk 3 so that we can calculate the disk's actual Volume Unique Key (VUK). Since you are using Windows, can you download SamuriHL's KeyDB Helper utility please, and use it to validate your disk 3? The entry does already contain the correct Unit Key, and so this entry should validate, and hopefully remove its incorrect Media Key at the same time.
And if the entry doesn't validate because of its incorrect Media Key (the "| M | 0xE0F6... " part) then just delete its "| M | <value> " field and try validating your disk again. Thanks.
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v70_Apollo_11_B614
*MKB20_v82_HEXEN_1_F45C
MKB20_v82_DustBunnyUHD_C3F7
*MKB20_v82_GOAT_431A
*MKB20_v82_STRAY_DOG_09B0
*MKB20_v82_THE_MAN_WHO_HAUNTED_HIMSELF (0xA3311EF651405EDF2F4A2FBC0C74B424576388A6)
*MKB20_v82_WUTHERING_HEIGHTS_84F2
Discs 1 and 3 now have complete records in the public keydb and the incorrect media key you noticed has been corrected. Validation with KeyDB Tool or FindVUK would still be appreciated but no manual editing should be required.MrPenguin wrote: Thu Apr 23, 2026 7:36 pm Thanks for these. The latest KEYDB.cfg does have entries for these four disks, although the entries for disks 1 and 3 are incomplete. However, the entry for disk 3 also contains the incorrect Media Key. (It actually has the Media Key for disk 2, which looks suspiciously like a "copy-and-paste" error
Highest 2 Lowest (2025)
Disc type: UHD
Disc ID: B34C429C008EBF9D1FFF7EB7A91511EB8E0F47B5
Disc dump filename: MKB20_v82_HIGHEST_2_LOWEST_7B16.tgz
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link: https://drive.proton.me/urls/YGCFQVJ7H8#dLngcuLPvG2H
Disc dump link: https://drive.proton.me/urls/HNNJQPXV50#Ux1iiJLuhivD
Disc type: UHD
Drive: BW-16D1HT
Disc type: UHD
Disc ID: 5ca12765838b68802e7f424f4e473cba7ff84a12
Disc dump filename: MKB20_v68_Once_Upon_a_Time_in_Hollywood_A603
Drive: BU40N
MKB_RO.inf: https://drive.proton.me/urls/1WA74ADPQG#u7KFUrMJPddW
Disc dump link: https://drive.proton.me/urls/G8ACYSVBRG#p7lacUnIvbIB
Drive: BU40N
buffalobossie
Faces of Death
Disc type: UHD
Disc ID: 6a7c666a5f9570f50853080aacfdac7fa962faae
Disc dump filename: MKB20_v82_VSA062UHD_7073.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1IhVxdP ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1CFaxL0 ... sp=sharing
Escape from Death
Disc type: UHD
Disc ID: c40bf3d0b7cc82480e1ca0d81a80d8efb774f9de
Disc dump filename: MKB20_v82_VS532UHD_D755.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1ZAGTD2 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1lpOJhg ... sp=sharing
Mutant
Disc type: UHD
Disc ID: 4d9ac13c2ce5835049ba5575e8a4a71e3787ee95
Disc dump filename: MKB20_v82_VS533UHD_3FB7.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1oLSxJC ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1546eYp ... sp=sharing
Disc type: UHD
Escape from Death
Disc type: UHD
Mutant
Disc type: UHD
UHD Submission - LA FEMME DE MENAGE (French Edition) - MKB v82
Hi everyone,
I'm submitting the dump for the French UHD release of "La Femme de Ménage" (The Housemaid).
MakeMKV was unable to generate a .tgz file due to hash/checksum errors during the initial scan, so I have provided a manual dump of the full AACS directory.
Disc type: UHD
Disc ID: 0x4CEB5BD47BD46ADCBC28C5684007541E0839F7D6
Disc dump filename: MKB20_v82_LA_FEMME_DE_MENAGE_35CA.zip
Drive: Verbatim 43888 (External)
Drive firmware: 1.03-MK (LibreDrive Enabled)
MKB_RO.inf link: https://drive.google.com/file/d/1Ifx-NP ... sp=sharing
Full AACS Dump link: https://drive.google.com/file/d/10y9_YQ ... sp=sharing
Thanks in advance for adding this
Disc type: UHD
keydb_helper
*MKB20_v68_Once_Upon_a_Time_in_Hollywood_A603
*MKB20_v77_Reservoir_Dogs_07F1
*MKB20_v82_88FU046A_BB74
*MKB20_v82_BD_88FU046B_C142
*MKB20_v82_BDROM_D1F4
*MKB20_v82_Diabolisch_6906
*MKB20_v82_HIGHEST_2_LOWEST_7B16
Iannautilus
Usual Suspects Steelbook UHD (French Version)
Disc type: UHD
Disc ID: 0xc5e3676b1929b3a6e673d20d8745c158b9df9e60
Disc dump filename: MKB20_v82_BDROM_10B5
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1GntfRy ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1givYB9 ... sp=sharing
Disc type: UHD
Drive: BD-RE BU40N
Cauldron Film's UHD release of Fulci's Conquest (1983):
Disc type: UHD
Disc ID: fcb7d73e5239ef2ea62f775e9bdb41d6bbc3169b
Disc dump filename: MKB20_v82_Conquest_8827.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1mTXoD8 ... drive_link
Disc dump link: https://drive.google.com/file/d/12QqXQx ... drive_link
(Edit: updated MKB_RO.inf file with proper version from the disc, not the .tgz)
Disc type: UHD
Drive: BW-16D1HT
Cauldron Film's UHD release of Franco's Jack the Ripper (1976):
Disc type: UHD
Disc ID: 959c95ab01301ba5bf641d26afc97816e1ef678d
Disc dump filename: MKB20_v82_Jack_the_Ripper_2B7D.tgz
Drive: BW-16D1HT
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1PUAv3D ... drive_link
Disc dump link: https://drive.google.com/file/d/1JuHg4T ... drive_link
(Edit: Corrected MKB_RO.inf link to reflect copy found on disc, not from the .tgz)
Disc type: UHD
Drive: BW-16D1HT
Your MKB_RO.inf files are only 56 bytes long, which means you have done what the instructions say not to do. We already have these 56-byte-long MKB_RO.inf files because they are the ones from the TGZ files which you have provided. Can you provide the MKB_RO.inf files from the actual physical disks instead please?warhorus wrote: Sat Apr 25, 2026 4:11 pm MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):
I apologize for the oversight, this is what happens when you do things in a rush! Here are the updated linked (I'll edit the original posts as well):
Conquest: https://drive.google.com/file/d/1mTXoD8 ... drive_link
Jack the Ripper: https://drive.google.com/file/d/1PUAv3D ... drive_link
Sorry again for being That Guy!
keydb_helper
Re: UHD Submission - LA FEMME DE MENAGE (French Edition) - MKB v82
*MKB20_v82_BDROM_10B5
*MKB20_v82_ROBIN_HOOD-_PRINCE_OF_THIEVES_-_4K_UHD_2462
Hi Skolven, welcome to the forum. The AACS directory alone is not sufficient for deriving disc keys. The discatt.dat or discattd.dat file generated by MakeMKV is also required. If you can get MakeMKV to start producing an encrypted full disc backup this should create a usable discatt.dat file early in the process. You can then cancel the backup and post a link to the discatt file to this thread.Skolven wrote: Fri Apr 24, 2026 9:18 pm Hi everyone,
A complete record has been uploaded to the KeyDB for the movie Mercy (2026). The dump has also been emailed to svq@makemkv.com for processing.
Disc ID: 488F1B926A653FE8C1F86611459FDE60C0CBD657
Dump File Name: MKB20_v82_MERCY_D857
