Dump file - Monty Python's Life of Brian UHD
Clean&Profane
Post by Clean&Profane » Tue Apr 14, 2026 1:24 am
Dump file for Monty Python's Life of Brian UHD.
Drive: LG BU40N
LibreDrive enabled.
MakeMKV v1.18.3
Thank you.
MKB20_v82_MONTY_PYTHON'S_LIFE_OF_BRIAN_269E.tgz
(3.28 MiB) Downloaded 136 times
MrPenguin
Re: Dump file - Monty Python's Life of Brian UHD
Post by MrPenguin » Tue Apr 14, 2026 10:09 am
Clean&Profane wrote: Tue Apr 14, 2026 1:24 am Dump file for Monty Python's Life of Brian UHD.
The latest KEYDB.cfg file already contains this disk. Have you tried downloading it, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
kaelef
Post by kaelef » Thu Apr 16, 2026 2:59 pm
MrPenguin wrote: Tue Apr 14, 2026 10:09 am The latest KEYDB.cfg file already contains this disk. Have you tried downloading it, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
I'm not the OP, but I had assumed that deleting the _private_data.tar file would have the same effect. Just did the keydb.cfg download thing and was surprised to find that it worked. Thanks
MrPenguin
Post by MrPenguin » Thu Apr 16, 2026 3:15 pm
kaelef wrote: Thu Apr 16, 2026 2:59 pm I'm not the OP, but I had assumed that deleting the _private_data.tar file would have the same effect.
FYI the _private_data.tar file contains MakeMKV's "hashed keys" database, and is nothing to do with the public KEYDB.cfg file.
Clean&Profane
Post by Clean&Profane » Sun Apr 19, 2026 1:30 am
Appreciate the help. I went ahead and grabbed the latest KEYDB.cfg from the site, dropped it into the MakeMKV directory, restarted, and that did the trick. Still pretty new to all this, so I’m figuring things out as I go. This is only the second time I’ve run into an issue like this, but it’s definitely a learning process. Thanks again for pointing me in the right direction.
