Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper » Thu Apr 16, 2026 10:04 am
el_vandragon wrote: Thu Apr 16, 2026 4:08 am Oh fascinating, I thought people were mostly just using it to sync KEYDB files, I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!
Great to hear that it worked out for you. Discs which don't utilise media keys already known to the keydb (generally newer discs or less popular older titles) will still need to be posted here.
MrPenguin
Post by MrPenguin » Thu Apr 16, 2026 10:41 am
The "validate" functionality needs to have an entry in the KEYDB.cfg file to validate. And when there isn't any such entry for your disk then the helper utility needs to create one first. Whether or not it can create this new entry is unfortunately a matter of luck, but it would always recommend trying to validate your disk anyway, just in case.
To be fair, I would consider just upgrading a "NOT VALIDATED" entry to a "VALIDATED" one to be worth it :).
asdc2004
Post by asdc2004 » Thu Apr 16, 2026 1:16 pm
Disc type: BD
Title: Perfect Blue (Korean release)
Region: Korea
Disc ID: (paste SHA-1 here)
Disc dump filename: MKB20_v82_PERFECT_BLUE_AC51
Drive: BP60NB10
Drive firmware: 1.02
Thanks for your help.
MKB20_v82_PERFECT_BLUE_AC51.tgz
(72.14 KiB) Downloaded 234 times
Post by SamuriHL » Thu Apr 16, 2026 2:03 pm
MrPenguin wrote: Thu Apr 16, 2026 10:41 am To be fair, I would consider just upgrading a "NOT VALIDATED" entry to a "VALIDATED" one to be worth it :).
So do I...that's why I added it. :)
el_vandragon
Post by el_vandragon » Thu Apr 16, 2026 4:30 pm
keydb_helper wrote: Thu Apr 16, 2026 10:04 am
el_vandragon wrote: Thu Apr 16, 2026 4:08 am I normally just use FindVUK manually and didn't realize this could be used to get missing information. Looks like it worked and was able to validate! Thanks!
Yep! It is cool that it can try similar discs to see if there is a matching key. I validate or aacskeys all my discs but I have never tried media keys from other entries so I will make sure to use this utility whenever I run into discs with just UK and then only post here if it can't find a match. Thanks for the help everyone!
Ostermosmergoll
Post by Ostermosmergoll » Thu Apr 16, 2026 5:04 pm
Disc type: BD-ROM UHD
Disc dump filename: MKB20_v82_Primitive_War_-_UHD_64C9
Drive: BW-16D1HT
Drive firmware: 3.10
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?Yes
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link: https://drive.google.com/file/d/1-5YhwL ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Isr_I2 ... drive_link
Last edited by Ostermosmergoll on Fri Apr 17, 2026 11:52 am, edited 1 time in total.
MrPenguin
Post by MrPenguin » Thu Apr 16, 2026 8:12 pm
Ostermosmergoll wrote: Thu Apr 16, 2026 5:04 pm Disc dump filename: MKB20_v82_Primitive_War_-_UHD_64C9
Actually, "No".
Can you change the "Share" setting for both these files please, so that people can access them?
Ostermosmergoll
Post by Ostermosmergoll » Thu Apr 16, 2026 8:45 pm
Oh, I'm sorry.
I've changed it.
Mrjeverett
Post by Mrjeverett » Thu Apr 16, 2026 11:14 pm
Five Nights At Freddy's 2
Disc type:UHD
Disc ID: FNAF2_UPK75
Disc dump filename:MKB20_v82_Five_Nights_at_Freddy's_2_C682
Drive:BD-RE WH16NS60
Drive firmware:2118-10-29 19:36
LibreDrive status:YES
Did you sync the public keydb within the last 15 minutes?YES
Have you verified that all submission links are accessible in incognito/private browsing?YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/drive/folders/ ... drive_link
Disc dump link:https://drive.google.com/drive/folders/ ... drive_link
MrPenguin
Post by MrPenguin » Fri Apr 17, 2026 12:06 am
Ostermosmergoll wrote: Thu Apr 16, 2026 8:45 pm Oh, I'm sorry. I've changed it.
Thanks, and I can now see that both your links are for the TGZ dump file. Can you also provide the full AACS/MKB_RO.inf file from this UHD disk please? This file should be several MB in size.
FootFungus07
Post by FootFungus07 » Fri Apr 17, 2026 2:58 am
Good Luck, Have Fun, Don't Die
Disc type: UHD
Disc dump filename: MKB20_v82_Good_Luck,_Have_Fun,_Don't_Die_9EAE.tgz
Drive: BD-RE BP60NB10
Drive firmware: Enabled 2120-05-07 09:35
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Google Drive Link:
https://drive.google.com/file/d/1QUWaej ... drive_link
Thanks again!
MKVDUDE
Post by MKVDUDE » Fri Apr 17, 2026 2:20 pm
Another 2 please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_AUDITION_-_4K_UHD_C8B2.tgz
MKB20_v82_WAKE_IN_FRIGHT_-_4K_UHD_2F06.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-cmy7yARbhnEJiVyk
Many thanks!
Ostermosmergoll
Post by Ostermosmergoll » Fri Apr 17, 2026 3:32 pm
MrPenguin wrote: Fri Apr 17, 2026 12:06 am
I have uploaded the file and edited the link in my first post.
rez83
Post by rez83 » Fri Apr 17, 2026 5:33 pm
Hello, I just got Sleepers from Gruv:
Disc type: UHD
Disc ID: C6E394721728F0EC2571C56C2F7739964BD49ECE
Disc dump filename: MKB20_v82_Sleepers_BD32
Drive: BW-16D1HT
RAR link for both files:
https://drive.google.com/file/d/1wwrjwF ... drive_link
MrPenguin
Post by MrPenguin » Fri Apr 17, 2026 10:43 pm
rez83 wrote: Fri Apr 17, 2026 5:33 pm Disc dump filename: MKB20_v82_Sleepers_BD32
Can you adjust the "Share" option for this file please, so that people can access it?
