Dump file for Monty Python's Life of Brian UHD.
Drive: LG BU40N
LibreDrive enabled.
MakeMKV v1.18.3
Thank you.
Dump file - Monty Python's Life of Brian UHD
Clean&Profane
- MKB20_v82_MONTY_PYTHON'S_LIFE_OF_BRIAN_269E.tgz
- (3.28 MiB) Downloaded 213 times
MrPenguin
Re: Dump file - Monty Python's Life of Brian UHD
The latest KEYDB.cfg file already contains this disk. Have you tried downloading it, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Clean&Profane wrote: Tue Apr 14, 2026 1:24 am Dump file for Monty Python's Life of Brian UHD.
kaelef
I'm not the OP, but I had assumed that deleting the _private_data.tar file would have the same effect. Just did the keydb.cfg download thing and was surprised to find that it worked. Thanks
MrPenguin
FYI the _private_data.tar file contains MakeMKV's "hashed keys" database, and is nothing to do with the public KEYDB.cfg file.kaelef wrote: Thu Apr 16, 2026 2:59 pm I'm not the OP, but I had assumed that deleting the _private_data.tar file would have the same effect.
Clean&Profane
Appreciate the help. I went ahead and grabbed the latest KEYDB.cfg from the site, dropped it into the MakeMKV directory, restarted, and that did the trick. Still pretty new to all this, so I’m figuring things out as I go. This is only the second time I’ve run into an issue like this, but it’s definitely a learning process. Thanks again for pointing me in the right direction.
