Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin »
Twistedsheep wrote: Sat Apr 11, 2026 3:44 pm ohhh, I'll try to run that issue down!... I assumed that was MakeMKV attempting to grab the updated keydb or something,
MakeMKV's own database is its private "hashed keys", and it does try to update this automatically. However, the public KEYDB.cfg file is an optional database, and it is up to you to keep it up-to-date, should you choose to use it.
Since you're using Windows, you might want to try SamuriHL's KeyDB Helper utility, which can make it easier to update your KEYDB.cfg file and can also validate entries for the disks you already have.
dsstroyer
Post by dsstroyer »
Disc type: UHD
Disc ID: 1005656ACA1EE6D5EB89C1E5A75ADA28C6AE6ACD
Disc dump filename: MKB20_v77_Rings_E0B9.tgz
Drive: BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
(130.27 KiB) Downloaded 179 times
Twistedsheep wrote: Sat Apr 11, 2026 3:44 pm ohhh, I'll try to run that issue down!... I assumed that was MakeMKV attempting to grab the updated keydb or something, I didn't realize it was calling to another database entirely. I am diligent about keeping the keydb updated with latest every time I try, so I never tried to figure out what was tripping up MakeMKV, and just chalked it up to my firewall being over zealous but otherwise mood, since I was explicitly grabbing the latest key download. Hearing that if i clear up that wrinkle up, I might have better luck with my existing disks, I'll start chasing down what's blocking MakeMKV. Ty so much for pointing that out!
Most likely your firewall is geo-blocking Russia as that is where the HK database is downloaded from.
defaultjovi
Post by defaultjovi »
Disc Type: UHD
Disc ID: 0x656856B9A7A07445535B871B2AE3C6496C800E2B
Disc Dump Filename: MKB20_v72_TheGentlemen_-_UHD_CFB7.tgz
Drive: BD-RE BU40N
Drive Firmware: 1.03
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the disk dump and MKB_RO.inf: https://drive.google.com/drive/folders/ ... sp=sharing
DISC INFORMATION
Validation Data : E5472A37F6A0F5C566AD69B73B9D17DF
Media Key not found
Media Key not found!
Unit Keys validated against 3 aligned units
--- Disc Information ---
Disc ID : 0x656856B9A7A07445535B871B2AE3C6496C800E2B
Volume : TheGentlemen
Date : 2021-01-27
Disc Type : UHD
Encryption Keys:
VID : 0x9A874EFC560445D2068107E887C9237D
MKB Version : 72
Encrypted Keys (1): 1-0xF721019395FBA30A9BE8812A88D3BE63
KeyDB Status: (VALIDATED)
Status : incomplete
keydb_helper
Post by keydb_helper »
defaultjovi wrote: Sun Apr 12, 2026 2:21 am Disc Type: UHD
Thanks for the submission defaultjovi, your disc now has a complete record in the public keydb.
ellenia
Post by ellenia »
Here is a Disc Submission (Mary and the Witch's Flower)
Disc type: UHD
Disc ID: 0xF4823E09F1307DBA4864C9A9854A3E238BD41A61
Disc dump filename: MKB20_v61_UHDBDROM_7779.tgz
Drive: WH16NS60
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/16hTcSo ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1vQujW3 ... sp=sharing
tylwyth
Post by tylwyth »
The Devil's Backbone UHD - Studio Canal
Disc type: UHD
Disc ID: 2e8b2c19bfc01c553e3b264bf3967ab38223b2f2
Disc dump filename: MKB20_v82_The_Devil's_Backbone_EB0A.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/1HcBV7v ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1OrrL18 ... sp=sharing
Tihany
Post by Tihany »
Disc Submission - French UHD "Escroc, Macho et Gigolo"
Disc type: UHD
Disc ID: 0x79927448ac5d21bca0c64e1422af3193902d310d
Disc dump filename: MKB20_v82_EscrocMachoEtGigolo_B53E.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link: https://limewire.com/d/3y2qg#rLUFG3mPET
Disc dump link: https://limewire.com/d/3y2qg#rLUFG3mPET
jtpowell
Post by jtpowell »
Disc Submission - UHD Life of Brian
Disc type: UHD
Disc ID: 099662ff1255047e6ed4a739585cf5633536fce0
Disc dump filename: MKB20_v82_MONTY_PYTHON'S_LIFE_OF_BRIAN_269E
Drive: BDR-XD08U
Drive firmware: 1.04/ID05
MKB_RO.inf link : https://drive.google.com/file/d/1e7IgKp ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1NBupsv ... share_link
MrPenguin
Post by MrPenguin »
jtpowell wrote: Mon Apr 13, 2026 4:35 pm Disc Submission - UHD Life of Brian
Thanks, but KEYDB.cfg has contained this disk since the end of March 2026. Try copying the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.
BTW your "Disc ID" is actually 0xCB6C78E333F47BFE8EF1F25838E3A7A078974A1A
Twistedsheep
Post by Twistedsheep »
I won't distract this thread any more than to say thank Mr Pengin, Marty, and keydb for educating me. It was indeed my firewall blocking eastern Europe. As soon as I opened that block, everything started working, and I've been rooting through my closet ripping all my various UHDs that got kicked back. I never even thought to question that as most of my library did rip, outside of a few outlier. Thank you for noticing that right away, and hopefully I can be a cautionary tale to someone lurking like I have been. :) Ty again!
skinnypope
Post by skinnypope »
Hamnet UHD UK version dump - thanks in advance :D
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_HAMNET_EE3E
Drive: BD-RW BDR-XD08U
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1ncviEt ... drive_link
Disc dump link: https://drive.google.com/file/d/1jxKlX0 ... drive_link
zaqqaz6917
Post by zaqqaz6917 »
Disc type: UHD
Possible Variant I searched and saw a different version already posted
SHA1: B953D73365739B09DA7639F0961887C3647313EB
Disc dump filename: MKB20_v82_Mobile_Suit_Gundam_SEED_Freedom_AC28
Disc dump link: https://www.mediafire.com/file/7e3gp8q9 ... 8.rar/file
MKB_RO.inf link: yes in above folder
Drive INFO
Firmware version: 1.02
Edit to add
Id shows up in key dB but in same line says unvalidated...not sure what this means but still fails to decrypt as if this edit
defaultjovi
Disc Type: UHD
Disc ID: 0x7C2ABA74B21A6896A1BDD622C35AAC2DB3C55560
Disc Dump Filename: MKB20_v61_LALALAND_C635.tgz
Drive: BD-RE BU40N
hulahoo
Post by hulahoo »
