Public KeyDB Disc Submissions
keydb_helper
#2191 Post by keydb_helper » Fri Apr 10, 2026 3:24 pm
BrianInSC wrote: Fri Apr 10, 2026 3:00 pm Disc type: UHD
Disc ID: 0xB5B814B870CB16C9293CBB796F5507DBFFB5B1BA
Disc dump filename: MKB20_v77_Casablanca_98C7.tgz
Hey Brian, as I mentioned to frameloose just now, you can actually self-serve that particular title using SamuriHL's KeyDB Tool.
BrianInSC wrote: Fri Apr 10, 2026 3:00 pm *Added 0x prefix to the SHA-1 hash to match template formatting
Thanks for paying attention to the template, it is appreciated.
frameloose
#2192 Post by frameloose » Fri Apr 10, 2026 3:43 pm
keydb_helper wrote: Fri Apr 10, 2026 3:19 pm
frameloose wrote: Fri Apr 10, 2026 1:16 pm MKB20_v82_The_Housemaid_E7A4
Hey frameloose, thanks for the new disc dump. Your disc has been added to the public keydb. As you use Windows, you could've processed this particular disc with SamuriHL's KeyDB Tool. That would've avoided the need to post to this thread, so I'd definitely recommend trying it in the future. You can always post here if your title remains unsupported.
Here i have been using KeyDB Tool for like a year without knowing that feature :D Will try it next time :)
BrianInSC
#2193 Post by BrianInSC » Fri Apr 10, 2026 3:47 pm
Thank you! Working on the Samurai app now. My first disc dump and I'll continue to contribute.
I enjoy ripping 4k movies and direct playing them on my Plex server. Currently has two ASUS BW-16D1X-U drives.
MrPenguin
#2194 Post by MrPenguin » Fri Apr 10, 2026 4:09 pm
keydb_helper wrote: Fri Apr 10, 2026 3:19 pm @RandomSelf, please stop creating new threads for each disc. You've created dozens of threads with zero replies and all it does is slow down the process of adding new titles by effectively hiding your own submissions.
To be clear, creating a new thread for each movie title (such as "Elio") is how MakeMKV expects people to announce their dump variants, as well as emailing those dumps to svq@makemkv.com. This allows people to know which TGZ dump files have already been emailed in, and so helps avoid overloading the mailbox with duplicates.
But the best way to add your dump to KEYDB is to post to this "Public KeyDB Disc Submissions" thread by following @keydb_helper's template :).
BrianInSC
#2195 Post by BrianInSC » Fri Apr 10, 2026 4:41 pm
I had great success with the Samurai tool. Thank you for pointing me in that direction. It's easy and also, make sure your makemkv points to the updated directory. I did the Samurai tool and makemkv didn't work because I hadn't changed the database folder location. Very impressive. :D
keydb_helper
#2196 Post by keydb_helper » Fri Apr 10, 2026 4:56 pm
frameloose wrote: Fri Apr 10, 2026 3:43 pm Here i have been using KeyDB Tool for like a year without knowing that feature :D Will try it next time :)
BrianInSC wrote: Fri Apr 10, 2026 4:41 pm I had great success with the Samurai tool. Thank you for pointing me in that direction. It's easy and also, make sure your makemkv points to the updated directory. I did the Samurai tool and makemkv didn't work because I hadn't changed the database folder location. Very impressive. :D
Thanks guys. I didn't want to seem like I was complaining about the submissions, but self-serve really is the quickest and easiest option for everyone where possible.
Great to hear the custom data folder location is handled properly, I know that can be a source of frustration for MakeMKV users.
MrPenguin wrote: Fri Apr 10, 2026 4:09 pm To be clear, creating a new thread for each movie title (such as "Elio") is how MakeMKV expects people to announce their dump variants, as well as emailing those dumps to svq@makemkv.com. This allows people to know which TGZ dump files have already been emailed in, and so helps avoid overloading the mailbox with duplicates.
Fair point, I probably should've requested a post here in addition to rather than instead of a title-specific thread.
MrPenguin wrote: Fri Apr 10, 2026 4:09 pm But the best way to add your dump to KEYDB is to post to this "Public KeyDB Disc Submissions" thread by following @keydb_helper's template :).
I'm not 100% sure the '@'-tagging works here - I was only notified about the quote/reply. No idea why I thought that would work in my earlier post.
BrianInSC
#2197 Post by BrianInSC » Fri Apr 10, 2026 6:35 pm
"Thanks guys. I didn't want to seem like I was complaining about the submissions, but self-serve really is the quickest and easiest option for everyone where possible.
Great to hear the custom data folder location is handled properly, I know that can be a source of frustration for MakeMKV users."
No problem at all. I want to clarify the workflow if I could. If Makemkv can't locate a key, run Samurai's db tool first to update the database as that alone might fix the issue. If not, and the app is pointed to the new/updated database, a disc dump would be the next step. Let me know if I missed anything.
Lastly, would grabbing the disc info from the db tool and saving it locally be of any value to the end user?
#2198 Post by SamuriHL » Fri Apr 10, 2026 7:29 pm
I wrote the tool to give people more information about their discs. Under the covers it's using FindVUK to do all the heavy lifting (Nalor rocks!). The MakeMKV data directory copy was an annoyance for myself which is why I solved it in the tool.
The reason keydb_helper is pointing anyone on Windows to it on unknown discs isn't because there's some magic that my tool does. It scans the freshly downloaded KeyDB (from FindVUK) for media keys that are already known and checks if there's one that works for your particular disc. If it finds one it uses libaacs to calculate the keys for you and then uses FindVUK to call validate disc which will validate the calculated keys and upload them to the keydb. My tool simply helps make this easier for people.
Twistedsheep
#2199 Post by Twistedsheep » Sat Apr 11, 2026 3:47 am
I've been re-trying these every few days, but finally sat down to get all the details together. This is my first time doing this so hopefully everything is in order. I grabbed the latest DB, and double-checked each one with KeyDB Helper, so hopefully everything is in order. To everyone answering these posts, thank you soo much! It is very appreciated!...
The Shining
Disc type: UHD
Disc ID: 0x74246F9614344A58BDA276A399BFE883414C67B2
Disc dump filename: MKB20_v68_THE_SHINING_5C51.tgz
Drive: BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? Yes (and double checked with KeyDB Helper)
MKB_RO.inf link: https://drive.google.com/file/d/1HeKLtC ... drive_link
Disc dump link: https://drive.google.com/file/d/1luS1Py ... drive_link
Doctor Sleep
Disc type: UHD
Disc ID: 0xEFF2691110AE7D88A0F09C9DBEA6A643E8D0206F
Disc dump filename: MKB20_v72_DOCTOR_SLEEP_FFDF.tgz
Drive: BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1dSQBbw ... drive_link
Disc dump link: https://drive.google.com/file/d/1XLnvbD ... drive_link
Tenet
Disc type: UHD
Disc ID: 0x470CC727C0BACAE34A14831FD0C9BBFE778539DE
Disc dump filename: MKB20_v76_TENET_2AA3.tgz
Drive: BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1Vv9ip5 ... drive_link
Disc dump link: https://drive.google.com/file/d/1DXOFDa ... drive_link
Jaws
Disc type: UHD
Disc ID: 0x0D7878C24738958A69E3DEAA44D763198B4A8B40
Disc dump filename: MKB20_v72_JAWS_5ED3.tgz
Drive: BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1JaqYfZ ... drive_link
Disc dump link: https://drive.google.com/file/d/1Fzvuts ... drive_link
Annihilation
Disc type: UHD
Disc ID: 0x38D7829C911895111E1E5A6A36E6D6DF6F6400B3
Disc dump filename: MKB20_v61_ANNIHILATION_37F3.tgz
Drive: BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/10PuL24 ... drive_link
Disc dump link: https://drive.google.com/file/d/1QSzenU ... drive_link
MKVDUDE
#2200 Post by MKVDUDE » Sat Apr 11, 2026 9:56 am
Another load please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_DRUNKEN_MASTER_II_0710.tgz
MKB20_v82_FIRST_STRIKE_-_HONG_KONG_VERSION_06BE.tgz
MKB20_v82_FIRST_STRIKE_-_INTERNATIONAL_VERSION_A8E8.tgz
MKB20_v82_MR_NICE_GUY_-_INTERNATIONAL_CUT_9F9A.tgz
MKB20_v82_MR_NICE_GUY_BF36.tgz
MKB20_v82_RUMBLE_IN_THE_BRONX_-_HONG_KONG_VERSION_006E.tgz
MKB20_v82_RUMBLE_IN_THE_BRONX_-_INTERNATIONAL_VERSION_6C24.tgz
MKB20_v82_THUNDERBOLT_94E4.tgz
MKB20_v82_WHO_AM_I_-_INTERNATIONAL_VERSION_75BC.tgz
MKB20_v82_WHO_AM_I_78B0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-d7JXtwKC08t8NEMY
Many thanks!
MKVDUDE
#2201 Post by MKVDUDE » Sat Apr 11, 2026 9:58 am
And another please! -
Disc type: UHD
MKB_v82_BULLET_IN_THE_HEAD_-_BONUS_DISC_939E.tgz
MKB_v82_BULLET_IN_THE_HEAD_-_FESTIVAL_CUT_03E2.tgz
MKB20_v82_BULLET_IN_THE_HEAD_-_UHD_5446.tgz
Drive: BD-RE BU40N
Disc dumps link: https://we.tl/t-wgK1RJ17buyi8tSs
Many Thanks!
MrPenguin
#2202 Post by MrPenguin » Sat Apr 11, 2026 10:20 am
Twistedsheep wrote: Sat Apr 11, 2026 3:47 am I've been re-trying these every few days, but finally sat down to get all the details together. This is my first time doing this so hopefully everything is in order.
Can you adjust the "Share" option for all of these files please, so that people can access them?
keydb_helper
#2203 Post by keydb_helper » Sat Apr 11, 2026 10:59 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_BABY_BOY_ADC6
*MKB20_v82_BOYZ_N_THE_HOOD_B7EE
*MKB20_v82_BULLET_IN_THE_HEAD_-_UHD_5446
*MKB20_v82_Death_Ship_E094
*MKB20_v82_DRUNKEN_MASTER_II_0710
*MKB20_v82_FIRST_STRIKE_-_HONG_KONG_VERSION_06BE
*MKB20_v82_FIRST_STRIKE_-_INTERNATIONAL_VERSION_A8E8
*MKB20_v82_MR_NICE_GUY_BF36
*MKB20_v82_MR_NICE_GUY_-_INTERNATIONAL_CUT_9F9A
*MKB20_v82_POETIC_JUSTICE_9D7E
*MKB20_v82_Remo_Williams_8602
*MKB20_v82_RUMBLE_IN_THE_BRONX_-_HONG_KONG_VERSION_006E
*MKB20_v82_RUMBLE_IN_THE_BRONX_-_INTERNATIONAL_VERSION_6C24
*MKB20_v82_SLEEPERS_BD32
*MKB20_v82_The_Phantom_4986
*MKB20_v82_THUNDERBOLT_94E4
*MKB20_v82_WHO_AM_I_78B0
*MKB20_v82_WHO_AM_I_-_INTERNATIONAL_VERSION_75BC
Twistedsheep wrote: Sat Apr 11, 2026 3:47 am I've been re-trying these every few days, but finally sat down to get all the details together. This is my first time doing this so hopefully everything is in order. I grabbed the latest DB, and double-checked each one with KeyDB Helper, so hopefully everything is in order. To everyone answering these posts, thank you soo much! It is very appreciated!...
Hey Twistedsheep, welcome to the forum. Your first post was very comprehensive and you included almost everything required. If you can sort out the availability of those links it would be appreciated.
Twistedsheep
#2204 Post by Twistedsheep » Sat Apr 11, 2026 2:53 pm
Gah, stumbled right out of the gate. I hit the folder with 'anyone with link' permissions. It seems to work on my end, and using incognito mode to view the files. Please let me know if it's still being stubborn... and thank you again!
MrPenguin
#2205 Post by MrPenguin » Sat Apr 11, 2026 3:25 pm
Twistedsheep wrote: Sat Apr 11, 2026 2:53 pm Gah, stumbled right out of the gate. I hit the folder with 'anyone with link' permissions. It seems to work on my end, and using incognito mode to view the files. Please let me know if it's still being stubborn... and thank you again!
Thanks for doing that :). However, I have noticed this line in all your log files:
003339:0000 Automatic HK downloading is disabled or failed.
I strongly suspect that MakeMKV would have been able to decrypt all of your disks out-of-the-box, had it been able to download its "hashed keys" (HK) database successfully ;).
Having said that, your TGZ dump files all look complete and you could also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files - C:\Users\buffy\.MakeMKV\ in your case) and restarting MakeMKV.
