VLC can read UHD disc, but not MakeMKV backup
Xehelios
Post by Xehelios » Fri Apr 10, 2026 6:47 am
Not sure where to begin. I scoured the forum, but didn't find anything.
I have a UHD Blu-ray (The Hobbit 1). I have a drive that I flashed with the MK firmware (see drive info below). I can read the disc fine within VLC (I used the MakeMKV libraries inside VLC).
However, when I point VLC to a backup of the disc made with MakeMKV, VLC does nothing. It just outputs a bunch of files in the playlist. I did make sure to check "decrypt video files" when making the backup. So why can VLC play the disc itself but not the backup? I don't see an error message, so I'm not sure where to begin.
Any help is greatly appreciated.
OS device name: /dev/rdisk18
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO5PAIB5810
Highest AACS version: 76
Firmware version: 1.03
Disc Information
Label: THE HOBBIT AUJ THE
Timestamp: 2020-09-24 22:08:28
Protection: AACS2.0/C v76
Data capacity: 73.47 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MrPenguin
Re: VLC can read UHD disc, but not MakeMKV backup
Post by MrPenguin » Fri Apr 10, 2026 1:51 pm
Xehelios wrote: Fri Apr 10, 2026 6:47 am However, when I point VLC to a backup of the disc made with MakeMKV, VLC does nothing. It just outputs a bunch of files in the playlist. I did make sure to check "decrypt video files" when making the backup. So why can VLC play the disc itself but not the backup? I don't see an error message, so I'm not sure where to begin.
You need to tell VLC to open your backup of the disk as a disk, i.e. "Media/Open Disc..." menu, and then select your backup directory as the disk root.
Xehelios
Post by Xehelios » Fri Apr 10, 2026 1:57 pm
MrPenguin wrote: Fri Apr 10, 2026 1:51 pm
I'm such an idiot! :roll: :shock: :? Thank you so much for that... All is right again with the world...
