Decryption failed. Requesting Key.
404 NOT FOUND
Post by 404 NOT FOUND » Tue Apr 07, 2026 10:50 am
Decryption failed for Evangelion: 3.0+1.0 (Hong Kong Edition / Region A)
MrPenguin
Re: Decryption failed. Requesting Key.
Post by MrPenguin » Tue Apr 07, 2026 11:04 am
404 NOT FOUND wrote: Tue Apr 07, 2026 10:50 am Decryption failed for Evangelion: 3.0+1.0 (Hong Kong Edition / Region A)
Can you also upload the AACS/MKB_RO.inf file from your physical UHD disk into (say) OneDrive or Google Drive please, and then reply with a public download link? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself :(. (The full file should be several MB in size.)
