Pioneer Bluray Drive does not work in Linux Version
Jogibaer
#1 Post by Jogibaer » Mon Apr 06, 2026 7:40 am
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-X13
Revision: 1.01
Serienummer:
Firmware-Datum: 2022-02-18
Highest AACS version: 76
Drive platform: Pioneer RS9400
Firmware version: ID56
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.50
Serienummer: REDL014336WL
Firmware-Datum: 2017-12-21
Drive platform: RS8601
Firmware version: 8.50/ID52
These Informations were taken using the current version 1.18.3 on Windows 11. The software works without any issues and can read and convert both DVDs and Blu-ray discs.
This is not the case on Linux... MakeMKV was compiled and installed using make, following the installation instructions in this forum. The program installed libmmbd, but the integration does not work. Whilst DVDs can also be played and converted here, the integration with VLC does not work... VLC cannot read Blu-ray discs and freezes... The same thing happens when I try to read a disc with MakeMKV. The only solution here is to use kill -9...
I still have an old Buffalo drive (BRXL-16U3), and with this drive, both VLC and MakeMKV work without any problems with both DVDs and Blu-ray discs.
As both drives work with the same software version and the same discs on Windows, it cannot be down to the drives’ firmware. Clearly, the Linux version of MakeMKV does not work with every drive. This may have something to do with LibreDrive compatibility or with the libmmbd Library... but that doesn’t explain why it works on Windows....
Is there a workaround for this? Or is there something I need to install to make it work with the Pioneer drive and Linux Mint (22.2)?
Linux Mint 22.2
Windows 11 (24H2)
MakeMKV 1.18.3 (compiled)
(Purchased Key)
BD-RW - Pioneer BDR-X13
BD-RW - Buffalo BRXL-16U3
MrPenguin
Re: Pioneer Bluray Drive does not work in Linux Version
#2 Post by MrPenguin » Mon Apr 06, 2026 8:30 pm
MakeMKV on Linux needs rw access to your BluRay drive's SCSI generic device node.Try this command:
$ lsscsi -g
Can you see a /dev/sgX device node next to your /dev/sr0 or /dev/sr1 device? If not, you'll need to load the "sg" kernel module, and possibly add your user to the "cdrom" group too.
16442496
#3 Post by 16442496 » Tue Apr 07, 2026 4:02 am
I have two old (Non-Libre) Pioneer drives and both works fine with MakeMKV 1.18.3 on Debian 13. Compiled from sources.
Also integration with MakeMKV + mpv media player works as it should. No extra steps here.
Drives i got work with MakeMKV was using MakeMKV 1.17.6 (appimage)to get dump_firmware_files to both my Pioneer drives.
I have paid Key so it is easy in that way.
MakeMKV stores those firmware files to /home/user/.MakeMKV directory. Files looks like a... dump_FW_numbersandletters.tgz
If you have a paid key, you could try install first MakeMKV 1.17.6 and run it with a disc to get that firmware file and then compile newest version from MakeMKV.
Debian
MakeMKV 1.17.6 (Registered)
Pioneer BD (Unsupported, Non-Libre)
DVD to MKV only.
Jogibaer
#4 Post by Jogibaer » Tue Apr 07, 2026 5:22 am
$ lsscsi -g
yes, I can see the BD-RW Drive and the SSD, both SCSI Devices
[0:0:0:0]    cd/dvd  PIONEER  BD-RW   BDR-X13  1.01  /dev/sr0   /dev/sg0
[N:0:0:1]    disk    KXG6APNV2T04 TOSHIBA__1                    /dev/nvme0n1  -
Linux Mint 22.2
Windows 11 (24H2)
(Purchased Key)
Jogibaer
#5 Post by Jogibaer » Tue Apr 07, 2026 5:53 am
Thanks for that information... That helped me to solve the problem. I copied the ‘dump...’ file from the Windows system over to Linux and now it works :))
A simple solution (workaround), though the question remains as to why this firmware copy is generated under Windows but not under Linux...
Linux Mint 22.2
Windows 11 (24H2)
(Purchased Key)
MrPenguin
#6 Post by MrPenguin » Tue Apr 07, 2026 10:07 am
I can only see your Pioneer BDR-X13 drive here. Didn't you say you had a BDR-209M as well? In fact, according to your own MakeMKV info, LibreDrive is not yet enabled for your BDR-X13:
However, LibreDrive is enabled for your BDR-209M and so maybe you should try using that one instead?
As a matter of interest, your user also needs to be able read and write to the /dev/sg0 device. E.g. on my Linux box:
$ ls -als /dev/sg1
0 crw-rw----+ 1 root cdrom 21, 1 Apr  7 10:50 /dev/sg1
And my user ID belongs to the "cdrom" group in /etc/groups.
SamSpeexy
#7 Post by SamSpeexy » Tue Apr 07, 2026 10:20 am
All Linux versions after 1.17.7 don't like drives that don't have Libredrive firmware.
Your Pioneer X13 drive doesn't support Libredrive yet. Since your current firmware is dated before November 2022, you may be able to acquire a flasher for it by PM'ing @Coopervid or @Billycar11.
#8 Post by Coopervid » Tue Apr 07, 2026 10:44 am
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.01
Serienummer:
OS-Gerätename: D:
Produzent: PIONEER
Revision: 8.50
PM sent for your X13 to enable Libredrive / UHD capability.
Jogibaer
#9 Post by Jogibaer » Tue Apr 07, 2026 11:56 am
Thank you very much for this information. This helped me to solve (workaround) the problem :-)
The firmware dump was missing from my Linux system, but was present on Windows. So I copied the dump file over and now everything works perfectly...
So I don’t need to go round the back way via an old version of MakeMKV. I hope this will be fixed in the next version
That's right! Of course, I didn't have both drives connected at the same time... The Buffalo one works, which is why I posted the output for the Pioneer drive :-)
And yes, Libredrive isn’t enabled for this drive, nor is it in the Windows version, yet it still works there...
I’m very sorry, but I can’t understand why the Linux version doesn’t work with the same drives as the Windows version... Why does the hardware need different firmware for the Linux version?
So, in that case, the Linux and Windows versions aren’t compatible with each other if the Linux version only works with certain drives and you have to go to the trouble of installing special firmware on the drive to make it work under Linux...
Besides, the solution seems to be much simpler... (see above)
Linux Mint 22.2
Windows 11 (24H2)
(Purchased Key)
#10 Post by Coopervid » Tue Apr 07, 2026 1:34 pm
You don't understand the subject for the X13. The tgz file is supposed to be send to support@makemkv.com so Mike can enable Libredrive support for this. You don't to do that and just flash the drive with the firmware I provided. This is Libredrive capable and also makes it UHD capable. It's not a good idea to have non-Libredrive firmware on your drive because newer discs revoke the AACS certificate while Libredrive enabled drives circumvent this.
Jogibaer
#11 Post by Jogibaer » Tue Apr 07, 2026 2:15 pm
Right, I didn’t understand that!
I haven’t found any decent documentation explaining it either. What I have understood is that, for the Linux version, I have to flash the drive’s firmware or buy a new drive! Nobody here has explained why this isn’t necessary under Windows, and it’s not clear why it works with that dump...TGZ in the .MakeMKV Folder either...
Does that mean the drive doesn’t need to be flashed once Libredrive support is enabled for the X13?
Linux Mint 22.2
Windows 11 (24H2)
(Purchased Key)
Jogibaer
#12 Post by Jogibaer » Tue Apr 07, 2026 2:20 pm
I’m currently using Windows and am gradually switching everything over to Linux... so it’s a real hassle having to go to such great lengths for every piece of software just to get the same functionality...
and by the way, I’ve no idea how to flash the firmware on my Pioneer drive
Linux Mint 22.2
Windows 11 (24H2)
(Purchased Key)
MrPenguin
#13 Post by MrPenguin » Tue Apr 07, 2026 2:20 pm
That makes no sense whatsoever: The firmware dump is a dump of your drive's current firmware and has no effect on MakeMKV's operation!?
By rights, the Linux version of MakeMKV should also have created this exact same firmware dump as your Windows version. (Firmware dumping certainly works on my Linux box...) FWIW I've have been successfully using MakeMKV on Linux since at least v1.17.6.
MakeMKV cannot disable bus-encryption for a UHD drive unless LibreDrive is enabled. However, the last publicly-known host certificate for ordinary BDs was revoked by MKBv82. So as long as you never insert a disk that uses MKBv82 into your drive, you may still be able to use it to rip ordinary BDs without first enabling LibreDrive.
The Linux version of MakeMKV works fine, and I am speaking from personal experience with multiple different drives here. All it really needs is rw access to the relevant device nodes.
#14 Post by Coopervid » Tue Apr 07, 2026 2:22 pm
You probably have to wait very long until Mike will add support for this 1.01 firmware. And no- Windows is not different from Linux. Just go ahead and flash the firmware I have sent and you will have Libredrive in Linux and Windows. And your drive will be UHD capable.
MrPenguin
#15 Post by MrPenguin » Tue Apr 07, 2026 2:24 pm
Flashing the drive changes the drive's firmware, thus allowing MakeMKV to enable LibreDrive. LibreDrive is required for UHD disks because there are no publicly-known host certificates for AACSv2 to disable bus encryption.
