Public KeyDB Disc Submissions
keydb_helper
#2161 Post by keydb_helper » Fri Apr 03, 2026 1:00 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been processed but the public keydb seems to be having a submission issue:
*MKB20_v61_Push_F861
*MKB20_v82_Greenland_2_586A
*MKB20_v82_Marty_Supreme_3204
*MKB20_v82_MUBIUS008U_1854
*MKB20_v82_POINT_BLANK_3F66
*MKB20_v82_Runaway_Train_5E40
*MKB20_v82_The_Nightcomers_827C
Until the submission issue is resolved, you can grab the keydb entries from this pastebin link and manually append them to your local keydb file.
Pipo_93 wrote: Thu Apr 02, 2026 5:19 pm Disc type: UHD
Disc: Battleship
Disc ID: 0x7FCAC1809A9CDE02A152C422B9B848300FC30462
MKB version: 61
Disc dump filename: MKB20_v61_Battleship_AAD3.tgz
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes?: Yes
frameloose wrote: Thu Apr 02, 2026 5:14 pm MKB20_v77_Se7en_4BC1
Please follow the submission template detailed in the opening post instead of omitting required fields and adding new ones. If you don't include the full MKB_RO.inf file there are essentially two possible outcomes:
1. Your discs media key is already known to the public keydb, so the absence of the MKB_RO.inf isn't terminal but your discs keys could've been derived with SamuriHL's KeyDB tool
2. Your discs media key isn't known to the public keydb and it can't be calculated because you failed to include the full MKB_RO.inf file
BulldogK9 wrote: Thu Apr 02, 2026 2:41 am Well that's just F***in bizarre. I've never had this problem with Libredrive before. It's enabled on the drive (see attached screenshot), but I got that error for every one and assumed it was a missing key. I didn't have this problem a few days ago when I ripped two other UHD discs.
Whilst MakeMKV describes the LibreDrive status as 'Enabled' a more accurate label would probably be 'Capable' or 'Supported'. LibreDrive requires microcode extensions to run on your drive. If a drive encounters a firmware issue, certain timeouts or transient power faults, they can effectively self-reboot and end up in the non-LibreDrive state that you observed.
polskasubie
#2162 Post by polskasubie » Fri Apr 03, 2026 7:45 pm
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_The_Sword_and_the_Sorcerer_02DA
Drive:
Drive firmware:
Disc dump link: https://drive.google.com/file/d/14A-KH7 ... sp=sharing
keydb_helper
#2163 Post by keydb_helper » Sat Apr 04, 2026 12:19 am
polskasubie wrote: Fri Apr 03, 2026 7:45 pm Disc dump filename: MKB20_v82_The_Sword_and_the_Sorcerer_02DA
Thanks for the submission polskasubie, the 02DA variant of The Sword and the Sorcerer has been added to the public keydb.
The following UHD discs have also been added to the public keydb (new media keys are indicated with an asterisk):
*MB20_v77_PREDATOR_BADLANDS (0x17EA1505F533CEF4965A68D62CE1DA0F3E38D33E)
*MKB20_v82_PIRATI_450A
*MKB20_v82_UFOria (0x5360363407DE9439BDB960F0B6E3002F801BD8EF)
userhou4
#2164 Post by userhou4 » Sun Apr 05, 2026 1:29 am
Hi, I sent you some information about decrypting a CD, but you replied that the MKB_RO.inf file size is incorrect. I tried decrypting the UHD CD I have, but the Disc dump file size is always the same, and the MKB_RO.inf file is only 56 bytes each time. Could you please help me decrypt this CD?Thanks
Disc type:UHD
Disc ID:
Disc dump filename:MKB20_v76_BDROM_3C87
Drive:BU40N
Drive firmware:1.03MK
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1hXziE5 ... drive_link
Disc dump link:https://drive.google.com/file/d/10QM1Qq ... drive_link
keydb_helper
#2165 Post by keydb_helper » Sun Apr 05, 2026 4:10 am
userhou4 wrote: Sun Apr 05, 2026 1:29 am Hi, I sent you some information about decrypting a CD, but you replied that the MKB_RO.inf file size is incorrect. I tried decrypting the UHD CD I have, but the Disc dump file size is always the same, and the MKB_RO.inf file is only 56 bytes each time. Could you please help me decrypt this CD?Thanks
I didn’t receive any message from you so I can’t comment on your prior discussions. But as I noted in the opening post you need to copy the MKB_RO.inf file from the folder on the disc. Extracting the partial file from the disc dump is absolutely useless. Everyone involved in the public keydb is more than capable of extracting files from disc dumps so there is no point in extracting the file yourself. The template you copied explicitly noted this requirement.
You need to browse the disc structure in Windows file explorer, macOS Finder or a Linux equivalent, then open the AACS folder, and copy the MKB_RO.inf file.
For AACS2/UHD discs, if your MKB_RO.inf file isn’t several megabytes in size it is useless.
userhou4
#2166 Post by userhou4 » Mon Apr 06, 2026 1:48 pm
Thank you for your reply to my previous post. I've figured out the MKB_RO.inf file this time. Could you please take a look and see if I can decrypt it? Thank you.
Disc type:UHD
Disc ID:
Disc dump filename:MKB20_v68_BDROM_247D
Drive:BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1t_A9GK ... drive_link
Disc dump link:https://drive.google.com/file/d/1KTHToL ... drive_link
MrPenguin
#2167 Post by MrPenguin » Mon Apr 06, 2026 1:59 pm
userhou4 wrote: Mon Apr 06, 2026 1:48 pm Thank you for your reply to my previous post. I've figured out the MKB_RO.inf file this time. Could you please take a look and see if I can decrypt it? Thank you.
Can you also provide the full MKB_RO.inf file for your MKB20_v76_BDROM_3C87.tgz dump file please?
StinkyJim
#2168 Post by StinkyJim » Mon Apr 06, 2026 5:45 pm
The Eye 4k UHD (US & UK)
Disc type: UHD
Disc dump filename: MKB20_v82_THE_EYE_3626.tgz
Drive: BD-RE WH14NS40
Drive firmware: 1.02
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1Oi5hks ... sp=sharing
keydb_helper
#2169 Post by keydb_helper » Tue Apr 07, 2026 3:40 am
userhou4 wrote: Mon Apr 06, 2026 1:48 pm Disc dump filename:MKB20_v68_BDROM_247D
StinkyJim wrote: Mon Apr 06, 2026 5:45 pm Disc dump filename: MKB20_v82_THE_EYE_3626.tgz
Thanks for the new dump files. Both discs have been added to the public keydb.
Could you please provide a link to the full MKB_RO.inf file for MKB20_v76_BDROM_3C87?
99gagamel
#2170 Post by 99gagamel » Tue Apr 07, 2026 11:24 am
Disc Type: UHD
Disc ID:0x21D55C53732CE1AA8D0AACF3946A279599B39749
Disc Dump Filename: MKB20_v76_RUNNING_MAN_CE59.tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1mAZ8WS ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1MBCehq ... sp=sharing
DISC INFORMATION
Validation Data : 696A7431119E06EE5CE4D393F804E48E
Media Key not found
Media Key not found!
Unit Keys validated against 3 aligned units
--- Disc Information ---
Disc ID : 0x21D55C53732CE1AA8D0AACF3946A279599B39749
Volume : RUNNING MAN
Title : Running Man
Date : 2021-09-22
Disc Type : UHD Blu-ray
Encryption Keys:
VID : 0x6F62A49E9F48B08463CC23DB809DB901
MKB Version : 76
Encrypted Keys (1):
[1] 0xFC50A5E68374F64AD81D1425F163BEF7
KeyDB Status:
Database : (VALIDATED)
Status : incomplete
keydb_helper
#2171 Post by keydb_helper » Tue Apr 07, 2026 2:29 pm
99gagamel wrote: Tue Apr 07, 2026 11:24 am Disc Dump Filename: MKB20_v76_RUNNING_MAN_CE59.tgz
Thanks for the new disc dump. The CE59 variant of Running Man now has a complete record in the public keydb.
Grahamdoh
#2172 Post by Grahamdoh » Tue Apr 07, 2026 3:04 pm
Miranda blu-ray Shameless/Cult Films
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
userhou4
#2173 Post by userhou4 » Tue Apr 07, 2026 3:10 pm
Thank you for your previous help. This is another CD; could you please help me with it? Thank you.
Disc type:UHD
Disc ID:
Drive:BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1XTDPOt ... drive_link
Disc dump link:https://drive.google.com/file/d/1ViwHmA ... drive_link
Grahamdoh
#2174 Post by Grahamdoh » Tue Apr 07, 2026 7:53 pm
Imprint Blu-rays
A Better tomorrow 1, 2, and 3
The Wiz
Daniel
A Stranger among us
Critical Care
Gloria
keydb_helper
#2175 Post by keydb_helper » Tue Apr 07, 2026 10:53 pm
userhou4 wrote: Tue Apr 07, 2026 3:10 pm Disc dump filename:MKB20_v76_BDROM_3C87
Thanks for following up userhou4. Your disc now has a complete record in the public keydb.
Grahamdoh wrote: Tue Apr 07, 2026 3:04 pm Miranda blu-ray Shameless/Cult Films
Grahamdoh wrote: Tue Apr 07, 2026 7:53 pm Imprint Blu-rays
The Wiz
Daniel
A Stranger among us
Critical Care
Gloria
Thanks for the new submissions Graham, your discs have also been added to the public keydb.
