Public KeyDB Disc Submissions
polskasubie
Disc type: UHD
Disc ID:
Disc dump filename: MKB20_v82_The_Sword_and_the_Sorcerer_02DA
Drive:
Drive firmware:
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/14A-KH7 ... sp=sharing
Disc ID:
Drive:
Drive firmware:
keydb_helper
Thanks for the submission polskasubie, the 02DA variant of The Sword and the Sorcerer has been added to the public keydb.polskasubie wrote: Fri Apr 03, 2026 7:45 pm Disc dump filename: MKB20_v82_The_Sword_and_the_Sorcerer_02DA
The following UHD discs have also been added to the public keydb (new media keys are indicated with an asterisk):
*MB20_v77_PREDATOR_BADLANDS (0x17EA1505F533CEF4965A68D62CE1DA0F3E38D33E)
*MKB20_v82_PIRATI_450A
*MKB20_v82_UFOria (0x5360363407DE9439BDB960F0B6E3002F801BD8EF)
Hi, I sent you some information about decrypting a CD, but you replied that the MKB_RO.inf file size is incorrect. I tried decrypting the UHD CD I have, but the Disc dump file size is always the same, and the MKB_RO.inf file is only 56 bytes each time. Could you please help me decrypt this CD?Thanks
Disc type:UHD
Disc ID:
Disc dump filename:MKB20_v76_BDROM_3C87
Drive:BU40N
Drive firmware:1.03MK
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1hXziE5 ... drive_link
Disc dump link:https://drive.google.com/file/d/10QM1Qq ... drive_link
Disc type:UHD
Disc ID:
Drive:BU40N
keydb_helper
I didn’t receive any message from you so I can’t comment on your prior discussions. But as I noted in the opening post you need to copy the MKB_RO.inf file from the folder on the disc. Extracting the partial file from the disc dump is absolutely useless. Everyone involved in the public keydb is more than capable of extracting files from disc dumps so there is no point in extracting the file yourself. The template you copied explicitly noted this requirement.userhou4 wrote: Sun Apr 05, 2026 1:29 am Hi, I sent you some information about decrypting a CD, but you replied that the MKB_RO.inf file size is incorrect. I tried decrypting the UHD CD I have, but the Disc dump file size is always the same, and the MKB_RO.inf file is only 56 bytes each time. Could you please help me decrypt this CD?Thanks
You need to browse the disc structure in Windows file explorer, macOS Finder or a Linux equivalent, then open the AACS folder, and copy the MKB_RO.inf file.
For AACS2/UHD discs, if your MKB_RO.inf file isn’t several megabytes in size it is useless.
Thank you for your reply to my previous post. I've figured out the MKB_RO.inf file this time. Could you please take a look and see if I can decrypt it? Thank you.
Disc type:UHD
Disc ID:
Disc dump filename:MKB20_v68_BDROM_247D
Drive:BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1t_A9GK ... drive_link
Disc dump link:https://drive.google.com/file/d/1KTHToL ... drive_link
Disc type:UHD
Disc ID:
Drive:BU40N
Can you also provide the full MKB_RO.inf file for your MKB20_v76_BDROM_3C87.tgz dump file please?userhou4 wrote: Mon Apr 06, 2026 1:48 pm Thank you for your reply to my previous post. I've figured out the MKB_RO.inf file this time. Could you please take a look and see if I can decrypt it? Thank you.
The Eye 4k UHD (US & UK)
Disc type: UHD
Disc dump filename: MKB20_v82_THE_EYE_3626.tgz
Drive: BD-RE WH14NS40
Drive firmware: 1.02
MKB_RO.inf link: N/A
Disc dump link: https://drive.google.com/file/d/1Oi5hks ... sp=sharing
Disc type: UHD
keydb_helper
Thanks for the new dump files. Both discs have been added to the public keydb.
Could you please provide a link to the full MKB_RO.inf file for MKB20_v76_BDROM_3C87?userhou4 wrote: Mon Apr 06, 2026 1:48 pm Thank you for your reply to my previous post. I've figured out the MKB_RO.inf file this time.
Disc Type: UHD
Disc ID:0x21D55C53732CE1AA8D0AACF3946A279599B39749
Disc Dump Filename: MKB20_v76_RUNNING_MAN_CE59.tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1mAZ8WS ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1MBCehq ... sp=sharing
DISC INFORMATION
Validation Data : 696A7431119E06EE5CE4D393F804E48E
Media Key not found
Media Key not found!
Unit Keys validated against 3 aligned units
--- Disc Information ---
Disc ID : 0x21D55C53732CE1AA8D0AACF3946A279599B39749
Volume : RUNNING MAN
Title : Running Man
Date : 2021-09-22
Disc Type : UHD Blu-ray
Encryption Keys:
VID : 0x6F62A49E9F48B08463CC23DB809DB901
MKB Version : 76
Encrypted Keys (1):
[1] 0xFC50A5E68374F64AD81D1425F163BEF7
KeyDB Status:
Database : (VALIDATED)
Status : incomplete
Drive: BH16NS55
DISC INFORMATION
Media Key not found
Title : Running Man
Date : 2021-09-22
Encryption Keys:
MKB Version : 76
Encrypted Keys (1):
KeyDB Status:
Status : incomplete
keydb_helper
Thanks for the new disc dump. The CE59 variant of Running Man now has a complete record in the public keydb.
Thank you for your previous help. This is another CD; could you please help me with it? Thank you.
Disc type:UHD
Disc ID:
Drive:BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc):https://drive.google.com/file/d/1XTDPOt ... drive_link
Disc dump link:https://drive.google.com/file/d/1ViwHmA ... drive_link
Disc type:UHD
Disc ID:
Drive:BU40N
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
Imprint Blu-rays
A Better tomorrow 1, 2, and 3
The Wiz
Daniel
A Stranger among us
Critical Care
Gloria
Imprint Blu-rays
The Wiz
Daniel
A Stranger among us
Critical Care
Gloria
keydb_helper
Thanks for following up userhou4. Your disc now has a complete record in the public keydb.
Thanks for the new submissions Graham, your discs have also been added to the public keydb.Grahamdoh wrote: Tue Apr 07, 2026 7:53 pm Imprint Blu-rays
The Wiz
Daniel
A Stranger among us
Critical Care
Gloria
Disc Type: UHD
Disc ID: 0xB5647BAA698BEBD46BAC86B5665531C0581A40D8
Disc Dump Filename: MKB20_v77_DAS_APPARTMENT_77A3,tgz
Drive: BH16NS55
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1FbrjOB ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1paY8ae ... sp=sharing
DISC INFORMATION
Validation Data : CCB3DDCE36E76C531D563DFF02FAF2E0
Media Key not found
Disc ID : 0xB5647BAA698BEBD46BAC86B5665531C0581A40D8
Volume : DAS APPARTMENT
Date : 2023-07-20
Encryption Keys:
VID : 0x3E80F6DDE79BE02EF3D004C7A78181E6
MKB Version : 77
Encrypted Keys (1):
[1] 0x9DFBCF94749496C2DFE997CC8E620F47
KeyDB Status:
Status : incomplete
Drive: BH16NS55
DISC INFORMATION
Media Key not found
Date : 2023-07-20
Encryption Keys:
MKB Version : 77
Encrypted Keys (1):
KeyDB Status:
Status : incomplete
