(Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
Re: (Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
Post by Coopervid » Wed Apr 01, 2026 9:45 am
MartyMcNuts wrote: Wed Apr 01, 2026 6:20 am
EICP958 wrote: Tue Mar 31, 2026 4:04 pm Hi,
The drives are shipped from the UK, right?
Asmcom is based in Ireland.
They are shipped from Nothern Ireland which is basically UK but with the special status of it no duty applies for shipments to the EU.
EICP958
Post by EICP958 » Wed Apr 01, 2026 11:22 am
Coopervid wrote: Wed Apr 01, 2026 9:45 am
Thanks to both for the info that I'm trying to get by email for the last month.
I already have MKV license, and bought a Verbatim 43888. So, depending on how much Asmcom will ask for an external drive, i will want one.
Thanks again.
Ansark
Post by Ansark » Sat Apr 04, 2026 10:39 am
Hi.
Do you still sell internal UHD disk readers? If not, is it possible to get an adapter to use one of the external drives you sell as 5.25' internal drives?
EDIT: Nevermind. I just managed to apply a fw update with SDFtool Flasher to my 2019 ASUS BC-12D2HT and now it's UHD capable. Didn't even know it was possible to trick a regular Blu Ray player to read UHD Blu Rays.
BabordTribord
Post by BabordTribord » Thu Apr 09, 2026 10:28 am
About Asmcom’s USB Stable Power 5VDC Connector Loom, Can you confirm that there is protection to prevent current from being sent back to the computer ? Some cheap usb hub with additive power have this problem...
Will you sell classiczl 5,25 internal drive when your shop reopen ?
Thank you
Post by Billycar11 » Thu Apr 09, 2026 2:06 pm
BabordTribord wrote: Thu Apr 09, 2026 10:28 am About Asmcom’s USB Stable Power 5VDC Connector Loom, Can you confirm that there is protection to prevent current from being sent back to the computer ? Some cheap usb hub with additive power have this problem...
Thank you
Yes he confirmed to me there is protection
BabordTribord
Post by BabordTribord » Thu Apr 09, 2026 3:57 pm
Billycar11 wrote: Thu Apr 09, 2026 2:06 pm
Thank you
Perfect. Thank you !
babayaga
Post by babayaga » Sat Apr 18, 2026 10:04 pm
Will there be any internal BD-Drives in your store when you re-open? or they almost impossible to find now? :)
asmcom
Update From Asmcom: 19th April 2026
Post by asmcom » Sun Apr 19, 2026 6:43 am
https://shop.uhdfriendlydrives.co.uk/
Asmcom’s USB Stable Power 5VDC Connector Loom and Major Stock Update. Length of Loom is 200cms
Last updated: 19th April 2026
Our website will remain temporarily offline until mid-May 2026 while we prepare a significant new inventory release and implement several technical improvements designed to deliver the best possible performance and reliability from the final generation of Hitachi-LG Data Storage UHD drives.
We are pleased to confirm that we have successfully secured a large bulk order of Hitachi-LG Data Storage (HLDS) optical drives, including production units dated September through December 2025. These drives are believed to be among the final production runs manufactured prior to the official end-of-line (EOL) of these models.
Newly acquired stock includes
Hitachi BP55EB40Revision 4 hardware
Hitachi BU40NRevision 4 hardware with updated internal components
The latest BU40N Revision 4 hardware incorporates refinements to the internal PCB layout, power regulation and drive control sections. These improvements enhance mechanical tolerance control and rotational stability, helping to reduce the likelihood of circular surface marking on certain disc types.
Extensive validation testing
Over the past months we have been carrying out extensive real-world testing of host-powered optical drives across a wide range of systems, including Mac Mini computers, compact PCs, Microsoft Surface devices and other low-power USB platforms.
During testing we deliberately applied heavy load conditions to the USB subsystem while the optical drives were operating. This included simultaneous USB device activity such as external hard drive transfers, phone charging, printing, scanning and other bus-powered devices drawing current from the same host controller.
Under these stress conditions we observed that some systems can experience small but measurable voltage dips on the 5V drive power rail. While these variations are typically within specification, optical drives performing high-speed UHD reading can be sensitive to such fluctuations, which in certain environments may lead to occasional read instability or error recovery events.
To further investigate this behaviour we modified several test units and supplied regulated external 5VDC power directly to the 5V drive power rail. This allowed us to isolate the drive from fluctuations on the host USB bus while maintaining normal USB data communication.
The results were extremely positive. With a stable regulated supply connected, the drives demonstrated excellent voltage stability regardless of USB system load, even when the host ports were heavily stressed with multiple devices. Disc reading performance remained consistent and predictable, with improved tolerance to demanding workloads. In our testing, this completely eliminated read instability caused by USB power fluctuations on low-power systems such as Mac Mini and Microsoft Surface devices.
This testing confirmed that stable power delivery can significantly enhance the consistency of host-powered optical drives, particularly when connected to smaller modern computers where USB power regulation may vary depending on system activity.
Introducing Asmcom’s USB Stable Power 5VDC Connector Loom
To our knowledge, this is the first USB cable specifically engineered to stabilise power delivery for UHD optical drives.
Figure 1: Asmcom’s USB Stable Power 5VDC Connector Loom showing the additional 5VDC female barrel connector for optional regulated external power.
Based on these findings we have developed a new accessory designed specifically to enhance the performance of host-powered optical drives.
Asmcom’s USB Stable Power 5VDC Connector Loom provides the ability to optionally supply regulated external 5VDC power directly to the drive cable while maintaining full USB data connectivity.
As shown in Figure 1, the loom incorporates an additional 5VDC 3.5 mm x 1.35 mm female barrel connector which allows a regulated power supply to stabilise the drive’s power rail while the USB connection continues to handle data communication with the host system.
The design incorporates:
USB 3.0 Micro-B connection to the drive
USB-A connection for data and host power
Additional 5VDC 3.5 mm x 1.35 mm female barrel connector for optional regulated external power
Additional USB Type A to Type C adaptor will be available for customers with C connectors on their devices
This configuration allows the drive to operate normally from the USB host while also enabling connection of a regulated 5VDC 2A power supply when maximum stability is required.
The result is extremely stable drive operation, even on systems where USB bus power may fluctuate during heavy device activity.
Because this type of cable does not currently exist commercially, we have commissioned a custom tooling production run and are currently having 2,000 units manufactured specifically for use with our host-powered optical drive solutions.
These looms will initially support USB Micro-B optical drive platforms, and we are also developing additional versions for other host-powered drive interfaces including native USB Type-C configurations.
Why the website will remain closed until May 2026
We have decided to delay reopening the site so that we can complete:
Final validation testing of the new drive batches Done
Integration of the new USB Stable Power 5VDC Connector Loom Prototype Looms Approved
Preparation of upgraded product kits and documentation Awaiting New Looms
Inventory system updates for the upcoming release Done
Our goal is to ensure that when the website reopens, customers will receive the most refined and reliable solution possible for these final generation UHD optical drives.
Full availability details and product listings will be published once the site reopens.
Update: We have now received and approved our prototype looms. The stable power USB looms are now being manufactured.
If users have experienced similar read instability on low-power systems, we would be interested to hear your findings.
Thank you for your continued support.
Asmcom
UHD Friendly Drives Team
asmcom
Post by asmcom » Sun Apr 19, 2026 6:45 am
Thank you
Yes, there is protection for reverse voltage / current
Asmcom :mrgreen:
asmcom
Post by asmcom » Sun Apr 19, 2026 6:48 am
Thank you
Yes we have a few
asmcom
Post by asmcom » Sun Apr 19, 2026 9:02 am
Thank you
Thanks Billy for answering this, glad I share my technical ideas with you, as I value your input. I was in hospital for a long period, I am now back at home.
Kind Regards
Asmcom :mrgreen:
azkey
Post by azkey » Sun Apr 19, 2026 11:56 am
This might be a stupid question, but . . .
Will you, somehow, be able to source any of the Pioneer BDR-X13E-X, Pioneer BDR-X13E-S, Pioneer BDR-S13E-X, Pioneer BDR-S13EBK or their U or J variants for the EU zone?
asmcom
Post by asmcom » Sun Apr 19, 2026 12:02 pm
azkey wrote: Sun Apr 19, 2026 11:56 am This might be a stupid question, but . . .
Sorry no we won't be able to get any more of these models.
Regards Asmcom
azkey
Post by azkey » Sun Apr 19, 2026 12:08 pm
asmcom wrote: Sun Apr 19, 2026 12:02 pm
Regards Asmcom
Thanks for the info :)
