Public KeyDB Disc Submissions
Post by Coopervid » Wed Apr 01, 2026 4:35 pm
tomrammer wrote: Wed Apr 01, 2026 4:12 pm
MrPenguin wrote: Wed Apr 01, 2026 3:30 pm
tomrammer wrote: Wed Apr 01, 2026 3:04 pm Disc ID: 18f5ca5432aa5c2f094ad07db367c6e98b9f231f
Disc dump filename: MKB20_v82_Marty_Supreme_6E5C
The latest KEYDB.cfg file has contained this disk for over two weeks.
My bad - I put my new keydb.cfg in the wrong folder. Thanks for the heads up.
If you are on Windows use SamuriHL's tool. It puts a copy in the .Makemkv folder automatically.
bauercole
Post by bauercole » Wed Apr 01, 2026 7:35 pm
Disc type: UHD
Disc ID: 9bcfcaacb0f759dd065f00030aa4db394dfeafc3
Disc dump filename: MKB20_v61_Push_F861.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1Z1UQNB ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1B5EZDM ... sp=sharing
BulldogK9
Godzilla (2014) Mosterverse 5 Disc Set
Post by BulldogK9 » Wed Apr 01, 2026 7:44 pm
Disc type: UHD
Disc ID: f5a833007660315a23819969a1b09efb5ed7e982
Disc dump filename: MKB20_v76_Godzilla_F5E5.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: https://1drv.ms/f/c/e22048a991875da6/Ig ... 0?e=jvCWo6
Disc dump link: https://1drv.ms/u/c/e22048a991875da6/IQ ... gFXgyjagn0
Disc type: UHD
Disc ID: 1d997ff4a4b7a199ccdfc8fb1757819fea8d4034
Disc dump filename: MKB20_v61_Kong-_Skull_Island_1087.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://1drv.ms/f/c/e22048a991875da6/Ig ... w?e=jKO4C4
Disc dump link: https://1drv.ms/u/c/e22048a991875da6/IQ ... g?e=CFo2JG
Disc type: UHD
Disc ID: 41f0ca4bd6dea702b8104a032220a5f08eec8ff7
Disc dump filename: MKB20_v68_Godzilla-_King_of_the_Monsters_AE7D.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://1drv.ms/f/c/e22048a991875da6/Ig ... g?e=GwXyRY
Disc dump link: https://1drv.ms/u/c/e22048a991875da6/IQ ... k?e=Rc9D2k
Disc type: UHD
Disc ID: 4dff2c6cf2da21761a84b86d9c72297872ab495b
Disc dump filename: MKB20_v76_Godzilla_vs_Kong_B9E7.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://1drv.ms/f/c/e22048a991875da6/Ig ... o?e=xyz0Aa
Disc dump link: https://1drv.ms/u/c/e22048a991875da6/IQ ... Y?e=K3XZDK
Disc type: UHD
Disc ID: 0ddf5098532dbe9c3095e9ebe610b2ca9268e940
Disc dump filename: MKB20_v77_Godzilla_x_Kong-_The_New_Empire_9C31.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://1drv.ms/f/c/e22048a991875da6/Ig ... Y?e=5R9pn6
Disc dump link: https://1drv.ms/u/c/e22048a991875da6/IQ ... o?e=i236QP
MrPenguin
Re: Godzilla (2014) Mosterverse 5 Disc Set
Post by MrPenguin » Wed Apr 01, 2026 11:51 pm
BulldogK9 wrote: Wed Apr 01, 2026 7:44 pm Disc ID: 0ddf5098532dbe9c3095e9ebe610b2ca9268e940
Unfortunately, every single one of your TGZ dump files has the same problem:
SDF  v0a5: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO3P41F3338
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 2U{2<P"^ib0vfW}i5:213130306
DEBUG: Code 0 at ek0A`ekmmj7(oPSno;:121264395
DEBUG: Code 4 at ek0A`ekmmj7(oPSno;:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Basically, none of these dumps was created with LibreDrive enabled, which makes them unusable :(.
Perhaps you need to wait until the disk has appeared in Windows File Explorer before launching MakeMKV?
Happily for you, all of your disks except for "Godzilla x Kong: The New Empire" already has a complete entry in KEYDB. So once you have managed to enable LibreDrive correctly, could you validate this disk using SamuriHL's KeyDB Helper Utility please? That should complete this final entry.
BulldogK9
Post by BulldogK9 » Thu Apr 02, 2026 2:41 am
Well that's just F***in bizarre. I've never had this problem with Libredrive before. It's enabled on the drive (see attached screenshot), but I got that error for every one and assumed it was a missing key. I didn't have this problem a few days ago when I ripped two other UHD discs.
Screenshot 2026-04-01 184531.png (33.69 KiB) Viewed 3496 times
I took your advice and waited until the OS (Windows 11) had recognized Godzilla in the drive and I was able to get MakeMKV to decrypt it. I deselected everything but the movie and had it start ripping it, but it never actually started writing anything to the hard drive.
I restarted the PC, because...sometimes that works.
Tried again. I'm back to my original situation. I can't get MakeMKV to read the thing at all. It's "Parsing file: /AACS/Content001.cer" and "Decrypting". At the 7 minute mark, the drive starts spinning again. Now it's parsing "/AACS/ContentHash001.tbl". it "times out" and I get the errors and it sends me back to the starting screen with the same dump file.
Try again, and I'm getting this:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3P41F3338' at offset '33366145024'
udf: node fe/efe failed!
Error 'Scsi error - UNIT ATTENTION:NOT READY TO READY CHANGE, MEDIUM MAY HAVE CHANGED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO3P41F3338' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Right about now, I'm thinking that the drive (which is maybe 6 months old) is bad. Good thing I bought a backup at the same time. So, I put it in the second drive. (Note: Both have been jailbroken and have libredrive.) But it doesn't appear to be the drive. I'm having the same issue. (Changed the USB cable, no difference. Plugged it directly into the PC, rather than the powered USB hub, no difference.) Again, didn't have the problem on Saturday when I ripped the UHD of Rambo: Last Blood.
Maybe this drive just doesn't like Godzilla?!?
BulldogK9
Post by BulldogK9 » Thu Apr 02, 2026 3:14 am
Tried a different computer. Same symptoms.
Maybe these are just bad discs. I was able to load and start ripping King Kong: Skull Island. But the rip didn't happen. It never started writing data to the hard drive and the disc just sat there for 10+ minutes before I pulled the plug.
Put in one of the discs I ripped last weekend. It spun right up and behaved as expected.
Not sure whether to do a return/replacement of the 4k, or maybe just buy the bluray version and live with that.
Post by MartyMcNuts » Thu Apr 02, 2026 3:51 am
BulldogK9 wrote: Thu Apr 02, 2026 3:14 am Tried a different computer. Same symptoms.
Did you clean the discs? This resolves most read errors unless the drive isn't getting enough power. Use UBS-C if possible and ports direct from the motherboard (not case ports) or an AC self-powered USB hub of at least 24w.
MKVDUDE
Post by MKVDUDE » Thu Apr 02, 2026 10:19 am
Another please -
Disc type: UHD
Disc dump filename:MKB20_v82_The_Nightcomers_827C.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-FWsRwgsGfpOXYNGo
Many thanks!
FootFungus07
Post by FootFungus07 » Thu Apr 02, 2026 4:35 pm
Runaway Train Kino Lorber Studio Classics 4K UHD
Disc type: UHD
Disc dump filename: MKB20_v82_Runaway_Train_5E40.tgz
Drive firmware: Enabled 2120-05-07 09:35
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Google Drive Link:
https://drive.google.com/file/d/1Q4lpop ... drive_link
Thanks again!
frameloose
Post by frameloose » Thu Apr 02, 2026 5:14 pm
https://drive.google.com/drive/folders/ ... axLWRmwquf
MKB20_v77_Se7en_4BC1
MKB20_v82_Greenland_2_586A
Pipo_93
Post by Pipo_93 » Thu Apr 02, 2026 5:19 pm
Disc type: UHD
Disc: Battleship
Disc ID: 0x7FCAC1809A9CDE02A152C422B9B848300FC30462
MKB version: 61
Disc dump filename: MKB20_v61_Battleship_AAD3.tgz
Did you sync the public keydb within the last 15 minutes?: Yes
Disc dump link: https://gofile.io/d/9aHuqx
BulldogK9
Post by BulldogK9 » Thu Apr 02, 2026 8:03 pm
MartyMcNuts wrote: Thu Apr 02, 2026 3:51 am
Discs are brand new and pristine. Didn't spot a single mark on them.
My first attempt was on a high-powered USB hub. The laptop I tried it on was plugged in and fully-juiced. I had no problem popping in other UHD discs and burning them again, just to test the drive. I think that this is just a bad pressing.
Post by Woodstock » Thu Apr 02, 2026 8:17 pm
That wasn't the question. "NEW" DISKS CAN HAVE CONTAMINATION ON THEM.
If the disk was in its packaging for more than 6 months before you tried ripping it, it could have accumulated a film that is difficult to see, but interferes with laser reading.
That's why it is standard practice to recommend cleaning a disk if it's giving trouble with reading.
MrPenguin
Post by MrPenguin » Thu Apr 02, 2026 10:37 pm
Pipo_93 wrote: Thu Apr 02, 2026 5:19 pm Disc ID: 0x7FCAC1809A9CDE02A152C422B9B848300FC30462
MKB version: 61
Thanks, and can you also provide the complete MKB_RO.inf file from your actual UHD disk please? The copy of this file inside the TGZ dump has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
keydb_helper
Post by keydb_helper » Fri Apr 03, 2026 1:00 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been processed but the public keydb seems to be having a submission issue:
*MKB20_v61_Push_F861
*MKB20_v82_Greenland_2_586A
*MKB20_v82_Marty_Supreme_3204
*MKB20_v82_MUBIUS008U_1854
*MKB20_v82_POINT_BLANK_3F66
*MKB20_v82_Runaway_Train_5E40
*MKB20_v82_The_Nightcomers_827C
Until the submission issue is resolved, you can grab the keydb entries from this pastebin link and manually append them to your local keydb file.
Pipo_93 wrote: Thu Apr 02, 2026 5:19 pm Disc type: UHD
Disc: Battleship
MKB version: 61
frameloose wrote: Thu Apr 02, 2026 5:14 pm MKB20_v77_Se7en_4BC1
Please follow the submission template detailed in the opening post instead of omitting required fields and adding new ones. If you don't include the full MKB_RO.inf file there are essentially two possible outcomes:
1. Your discs media key is already known to the public keydb, so the absence of the MKB_RO.inf isn't terminal but your discs keys could've been derived with SamuriHL's KeyDB tool
2. Your discs media key isn't known to the public keydb and it can't be calculated because you failed to include the full MKB_RO.inf file
BulldogK9 wrote: Thu Apr 02, 2026 2:41 am Well that's just F***in bizarre. I've never had this problem with Libredrive before. It's enabled on the drive (see attached screenshot), but I got that error for every one and assumed it was a missing key. I didn't have this problem a few days ago when I ripped two other UHD discs.
Whilst MakeMKV describes the LibreDrive status as 'Enabled' a more accurate label would probably be 'Capable' or 'Supported'. LibreDrive requires microcode extensions to run on your drive. If a drive encounters a firmware issue, certain timeouts or transient power faults, they can effectively self-reboot and end up in the non-LibreDrive state that you observed.
