Public KeyDB Disc Submissions
Jason1984
Post by Jason1984 »
MrPenguin wrote:
Sun Mar 29, 2026 4:07 pm
Jason1984 wrote:
Sun Mar 29, 2026 3:55 pm
Do you know if there is away to fix this? The other 60+ disc had no issues. Every so often I would have to disconnect power to the drive and restart make MKV. But other than that all other disc worked.
There is only one Power in the world that truly understands LibreDrive, and can bend it to his will... and he ain't me :).
However, you might want to consider waiting until your disk appears in Windows File Explorer before launching MakeMKV?
I finally figured it out. It only works if I uninstall Java version 8 Update 481. Both disc worked after the uninstall.
Hope this helps
ryandenotter
Post by ryandenotter »
Disc type: UHD
Disc ID: 10a8d20f53d02c3586bf4bc5a1061c0b0e132d8b
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_(EXT_)_PT_2_523D
Drive: BDR-XSO7U
Drive firmware: ?
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1CHC6lh ... sp=sharing
Disc dump link: https://drive.google.com/file/d/193FMXB ... sp=sharing
cjrupps
Post by cjrupps »
Disc type: UHD
Disc ID: 861f3aa5efac6de84bfb3afb606ba7e993f1034a
Disc dump filename: MKB20_v77_Duel_F64F
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link: https://drive.google.com/file/d/10cRMn3 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1_P7uCh ... sp=sharing
HCR666
Post by HCR666 »
MrPenguin wrote:
Sat Mar 28, 2026 8:32 pm
HCR666 wrote:
Sat Mar 28, 2026 8:30 pm
I was just wondering, you wouldn't happen to know of a way to convert .m2ts ultra HD 4K videos into a different more accessible format that is lossless?
Ahem, I believe "MakeMKV" can "make .mkv files"... if that's what you're interested in...?
I don't think I could find any part of MakeMKV that could convert video files? :?: :cry: I must be missing something but as far as I can tell it just seems to preserve/back-up videos from dvd's?
HCR666
Post by HCR666 »
HCR666 wrote:
Mon Mar 30, 2026 4:28 pm
What about the BIG BUTTON that is shaped like a disk? Clicking on that will do the default action of convert the files on the disk to MKV files. It's only when you select the smaller "backup" button that it generates the raw files. In general, it was intended to make playable copies.
KeyDB updated with a complete record for the UK 4K UHD disc of Predator Badlands:
Dump file: MKB20_v82_PREDATOR_BADLANDS_0A6A
Disc ID: 328867318BFB65422FD78C2F8406CBF371C5D61F
TheEvilMayor
Post by TheEvilMayor »
First time submitting this way, so hopefully I generated these Disc IDs properly.
Imprint Magnificent Seven Collection:
The Magnificent Seven UHD
Disc type: UHD
Disc ID: BFB8BC64E3337C7A93ECF4BFECC45CB382D1DFCF
Disc dump filename: MKB20_v82_The_Magnificent_7_42C0.tgz
Drive: BD-RE BU40N
Drive firmware: 1.00
MKB_RO.inf link: https://www.dropbox.com/scl/fi/3py5adji ... 89uh6&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/uf2uby4g ... exoxh&dl=0
The Magnificent Seven BR
Disc type: BR
Disc ID: 68F7B052F032AA5B88EA125CF4B24BAFE0847A1D
Disc dump filename: MKB_v82_The_Magnificent_7_D2EC.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://www.dropbox.com/scl/fi/ugwqh7bk ... fclwv&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/i2jein6b ... 6rgca&dl=0
Return of the Magnificent Seven
Disc type: BR
Disc ID: 106607E3F4C21FA721B49B1EB449782E88CFF299
Disc dump filename: MKB_v82_The_Return_of_the_Seven_9C6C.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://www.dropbox.com/scl/fi/boc4n1sy ... rdudr&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/nplvnyh5 ... 0pgry&dl=0
Guns of the Magnificent Seven
Disc type: BR
Disc ID: 10649F2386329607BA9E147CDAC0F42A7A4D39F6
Disc dump filename: MKB_v82_Guns_of_the_Magnificent_Seven_48CC.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://www.dropbox.com/scl/fi/yk5n9ht3 ... hc8c8&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/msl44e7s ... 7lwi5&dl=0
The Magnificent Seven Ride
Disc type: BR
Disc ID: 45003A8253B1CF9E7EB0ED60FD30555D1992D94F
Disc dump filename: MKB_v82_THE_MAGNIFICENT_SEVEN_RIDE_46E8.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://www.dropbox.com/scl/fi/wa9q51ti ... ws0aq&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/q91b4f6z ... lxdij&dl=0
barnstarmer
Post by barnstarmer »
Disc type: UHD
Disc ID: 0x360a18248e3f80e3d9ee8b097e8c92d40d577c66
Disc dump filename: MKB20_v76_DOUBLE_INDEMNITY_F117.tgz
Drive: Asus BC-12D2HT
Drive firmware: LG WH16NS60 1.02MK
MKB_RO.inf link [deleted]
Disc dump link: [deleted]
This disc is already in the database but there is only a Unit Key available. No VUK, Media Key, or VID.
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_IT_A4ED
*MKB20_v76_DOUBLE_INDEMNITY_F117
*MKB20_v82_The_Magnificent_7_42C0
I believe all other valid BD & UHD disc dumps have been processed and added to the public keydb.
peter4432
Post by peter4432 »
Dumps for UK 4K UHD release of Kung Fu Panda 3 [https://www.amazon.co.uk/dp/B0GHSBYYCW? ... asin_title]
Disc type: UHD
Drive: LG BD-RE WH16NS60
Drive firmware: 1.02
Disc dump filename: MKB20_v82_KUNG_FU_PANDA_3_20E6
MKB_RO.inf link: https://mega.nz/file/fEA1gLwC#Sy39xFTYN ... Yn-XDD6FPY
Disc dump link: https://mega.nz/file/7VpHFQaK#VNWsKw_Rb ... rDYy_rgCRA
user76419
Post by user76419 »
Disc type: UHD
Disc ID: C2DBCC4CABF7009317795F6AF56D2EE62DAD4ECE
Disc dump filename: MKB20_v77_BABYLON_322F.tgz
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/wjz9qjwa ... F.tgz/file
Thank you!
keydb_helper
peter4432 wrote:
Tue Mar 31, 2026 2:26 pm
user76419 wrote:
Wed Apr 01, 2026 4:02 am
Thanks for the submissions, these discs have been added to the public keydb.
I'd really recommend that you both try SamuriHL's KeyDB tool for Windows before posting to this thread: Link
As the media keys for both discs were already known to the keydb, the disc dumps would've been immediately processed and added to the public keydb without the need for posting here.
tomrammer
Post by tomrammer »
Marty Supreme 4k
Disc type: UHD
Disc ID: 18f5ca5432aa5c2f094ad07db367c6e98b9f231f
Disc dump filename: MKB20_v82_Marty_Supreme_6E5C
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1VXTmrI ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1z-Q2Zl ... p=sharing
MrPenguin
Post by MrPenguin »
tomrammer wrote:
Wed Apr 01, 2026 3:04 pm
The latest KEYDB.cfg file has contained this disk for over two weeks.
