LibreDrive for Pioneer drives
cl0udk1ckr wrote: Mon Mar 30, 2026 12:13 am i just stumbled upon this thread today. is it possible to flash my drive with its current firmware? i saw it wasnt included in the list of the first post. any possibility for the package to be updated to include my firmware? thanks in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.11
Serial number: QLDL131444UC
Firmware date: 2023-03-03
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.11/ID34
That's a bit more complicated since you updated it but
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
TheResoluteHawk
Post by TheResoluteHawk »
Hello! I just found another BDR-XS07UHD drive that I want to use as a backup. My concern is that the seller says that it has the newer firmware on it.
Will that be a problem or should it work with MakeMKV out of the box?
MrPenguin
Post by MrPenguin »
TheResoluteHawk wrote: Sat Apr 04, 2026 2:45 pm Hello! I just found another BDR-XS07UHD drive that I want to use as a backup. My concern is that the seller says that it has the newer firmware on it.
If the drive officially supports UHD - and BDR-XS07UHD does - then MakeMKV should support it too. AFAIK the only remaining problem with Pioneer drives is that we cannot (yet?) cross-flash recent non-UHD units.
MrPenguin wrote: Sat Apr 04, 2026 7:28 pm
The drive doesn't need to be crossflashed if it is UHD compatible and with firmware newer than Dec.2022.You are OK.
OneDay
Post by OneDay »
Billycar11 wrote: Mon Mar 30, 2026 1:39 am
Revision: 3.11
see below for email
Billycar11 can do magic. Trust me ;)
schmidtp
Post by schmidtp »
I'm finally getting around to UHD 4K disks. I believe the drive I have is compatible (Verbatim with a Pioneer drive in it). The UHD disc is seen in MakeMKV however when I click on the disc, it tries to use direct disc access but fails with
Loaded content hash table, will verify integrity of M2TS files
So I'm wondering whether it's the disc or the player? (I've only bought the one disc to try). The player rips BR discs fine and using MakeMKV on Linux using the Flatpak version. My drive info is below and I haven't flashed it as yet (I removed the serial number from the listing)
OS device name: /dev/sr0
Product: BD-RW BDR-UD04
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8A10
Firmware version: 1.14
Any help would be appreciated
schmidtp wrote: Sat Apr 04, 2026 11:08 pm Hi,
Revision: 1.14
The drive is fine. Nothing needs to be done. You can start by cleaning the UHD disc. About 90% of the time, UHD discs require cleaning as they often have an invisible layer of film on them from the manufacturing process. Give it a good clean then insert the disc and let the OS initialise it and then once you can see it in explorer you can then open the MakeMKV application.
Also, ensure MakeMKV has internet access (and nothing is geo-blocking it as it is downloaded from Russia) as it needs to download the HK (hashed keys) database to be able to rip UHD discs as well as blu-ray discs with AACS v82.
chris_cta
Post by chris_cta »
For the first time, I tried an UHD disc in the drive below:-
OS device name: T:
Revision: 1.21
Serial number: ----------------
Firmware date: 2014-04-02
Highest AACS version: 82
Drive platform: RS8231
Firmware version: 1.21
The drive wouldn't read the disc, but not in a bad way. Having read a lot of posts in this forum, who do I contact to enable UHD disks please.
regards
Chris Caudy
chris_cta wrote: Sun Apr 05, 2026 5:50 pm For the first time, I tried an UHD disc in the drive below:-
OS device name: T:
Revision: 1.21
regards
Chris Caudy
PM sent.
OS device name: T:
Revision: 1.21
regards
Chris Caudy
see below for email
babayaga
Post by babayaga »
MartyMcNuts wrote: Sat Feb 12, 2022 12:33 am According to the specs for my BDR-S12UHT,
BD-ROM DL (Ultra HD Blu-Ray) = 8x
BD-ROM TL (Ultra HD Blu-Ray) = 4x
BD-ROM SL = 12x
BD-ROM DL = 8x
Maybe the Pio drives are good because they are a bit slower? Damn quiet though, when ripping! I'm not really too concerned with the extra 20-30 mins taken to rip when I can't even hear it working!!
same read speeds as i get on my asus rebranded BDR-209 (now 211) :)
babayaga wrote: Wed Apr 08, 2026 7:25 pm
BD-ROM SL = 12x
BD-ROM DL = 8x
Yep all Pioneer drives are 4x max for UHD discs.
babayaga
Post by babayaga »
MartyMcNuts wrote: Wed Apr 08, 2026 11:42 pm
BD-ROM SL = 12x
BD-ROM DL = 8x
ah, thanks, that explains it :)
macep
Post by macep »
I have the drive below. Is it possible to make it UHD capable?
Product: BD-RW BDR-212BK
Revision: 1.00
Serial number: SEDL004572WL
Firmware date: 2019-01-10
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.00/ID81
macep wrote: Sat Apr 18, 2026 3:06 pm I have the drive below. Is it possible to make it UHD capable?
Revision: 1.00
see below for email
just sent over your flashers
