Public KeyDB Disc Submissions
avaka_71
Post by avaka_71 »
I am sending the relevant link for starship troopers - traitor of mars one more time (the previous link has expired)
https://uploadnow.io/f/M50F6LQ
Also please find star trek strange new worlds season 3
disk1
https://uploadnow.io/f/Y8bL9rW
disk2
https://uploadnow.io/f/Vqmc4Kw
disk3
https://uploadnow.io/f/4hGfM6R
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v61_Starship_Troopers-_Traitor_of_Mars_0931
*MKB20_v70_BRIDE_WITH_WHITE_HAIR
*MKB20_v76_Thriller
*MKB20_v77_VS_410 (The Texas Chainsaw Massacre 2)
*MKB20_v82_Blood_From_The_Mummy's_Tomb_D208
*MKB20_v82_Demons_Of_The_Mind_894A
*MKB20_v82_Marty_Supreme_78E0
*MKB20_v82_MONTY_PYTHONS_LIFE_OF_BRIAN_269E
*MKB20_v82_Per_Qualche_Dollaro_in_Più_-_UHD_B524
*MKB20_v82_Ray_3894
*MKB20_v82_Suspiria_A80C
*MKB20_v82_The_Rule_of_Jenny_Pen_6CBE
*MKB20_v82_TROUBLE_IN_PARADISE_9AEE
I believe all other valid disc dump submissions have been added to the public keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
MKVDUDE
Post by MKVDUDE »
keydb_helper wrote: Sun Mar 29, 2026 1:52 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v76_Thriller
*MKB20_v82_Ray_3894
Thanks keydb_helper!
Friggingrease
Post by Friggingrease »
PConnors wrote: Sat Mar 28, 2026 12:51 pm Salem's Lot (mini-series) - Arrow Video
(Someone else posted for this disc but it seems the disc dump wasn't uploaded correctly)
I emailed both of my dumps as well to the email address, but I didnt include all this info. Do they truly need it if I just email them the files? I included what I could, obviously.
Jason1984
Post by Jason1984 »
Disc type:UHD
Disc ID:BDE9D08876205A9C2C3938E7A31D9DC187BFC5C5
Disc dump filename:MKB20_v82_The_Bad_Guys_2_BF61
Drive: BD-RE BU40N
Drive firmware:1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/18YpPSl ... sp=sharing
Disc dump link: https://drive.google.com/file/d/12P8Ipl ... sp=sharing
Jason1984
Post by Jason1984 »
Disc type:UHD
Disc ID:F5B0BC5CF6B42371D585BFCC07C7E882F51DC6A8
Disc dump filename:MKB20_v76_Top_Gun-_Maverick_A7D9
Drive: BD-RE BU40N
Drive firmware:1.03
MKB_RO.inf link: https://drive.google.com/file/d/1MZkEbH ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1OXIfE6 ... sp=sharing
99gagamel
Post by 99gagamel »
Disc Type: UHD
Disc ID:0xA99129DBF1A680F9B43E1CC8F441B0FB7AF52FBC
Disc Dump Filename: MKB20_v61_IT_A4ED,tgz
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1CiV0mV ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/14cPK51 ... sp=sharing
_________________________________________________________________________________________________
DISC INFORMATION
Validation Data : 8F397758528F7522C632667B65D9BC53
Media Key not found
Media Key not found!
Unit Keys validated against 3 aligned units
--- Disc Information ---
Disc ID : 0xA99129DBF1A680F9B43E1CC8F441B0FB7AF52FBC
Volume : IT
Title : IT
Date : 2017-12-01
Disc Type : UHD Blu-ray
Encryption Keys:
VID : 0xF9B81CB7B522137C2E19CAD1B8F00F1E
MKB Version : 61
Encrypted Keys (1):
[1] 0x069EB7FF83B4E6B55E34768DAE52B645
KeyDB Status:
Database : (NOTVALIDATED)
Status : incomplete
MrPenguin
Post by MrPenguin »
Jason1984 wrote: Sun Mar 29, 2026 11:20 am Disc ID:BDE9D08876205A9C2C3938E7A31D9DC187BFC5C5
Jason1984 wrote: Sun Mar 29, 2026 11:24 am Disc ID:F5B0BC5CF6B42371D585BFCC07C7E882F51DC6A8
The latest KEYDB.cfg file already supports both your disks. The reason you cannot rip them is because your drive has failed to enable LibreDrive:
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
DEBUG: Code 3221225653 at 1S?TX+-~m=kM193o:213130559
DEBUG: Code 101067008 at z^.m+4.6#2(DX)H{:121271617
DEBUG: Code 101067008 at 1S?TX+-~m=kM193o:213130559
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom3'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Jason1984
Post by Jason1984 »
MrPenguin wrote: Sun Mar 29, 2026 3:37 pm
Thanks for the quick reply.
Do you know if there is away to fix this? The other 60+ disc had no issues. Every so often I would have to disconnect power to the drive and restart make MKV. But other than that all other disc worked.
Regards,
Jason
MrPenguin
Post by MrPenguin »
Jason1984 wrote: Sun Mar 29, 2026 3:55 pm Do you know if there is away to fix this? The other 60+ disc had no issues. Every so often I would have to disconnect power to the drive and restart make MKV. But other than that all other disc worked.
There is only one Power in the world that truly understands LibreDrive, and can bend it to his will... and he ain't me :).
However, you might want to consider waiting until your disk appears in Windows File Explorer before launching MakeMKV?
Jason1984
Post by Jason1984 »
MrPenguin wrote: Sun Mar 29, 2026 4:07 pm
I finally figured it out. It only works if I uninstall Java version 8 Update 481. Both disc worked after the uninstall.
Hope this helps
ryandenotter
Post by ryandenotter »
Disc type: UHD
Disc ID: 10a8d20f53d02c3586bf4bc5a1061c0b0e132d8b
Disc dump filename: MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_(EXT_)_PT_2_523D
Drive: BDR-XSO7U
Drive firmware: ?
MKB_RO.inf link: https://drive.google.com/file/d/1CHC6lh ... sp=sharing
Disc dump link: https://drive.google.com/file/d/193FMXB ... sp=sharing
cjrupps
Post by cjrupps »
Disc type: UHD
Disc ID: 861f3aa5efac6de84bfb3afb606ba7e993f1034a
Disc dump filename: MKB20_v77_Duel_F64F
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link: https://drive.google.com/file/d/10cRMn3 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1_P7uCh ... sp=sharing
HCR666
Post by HCR666 »
MrPenguin wrote: Sat Mar 28, 2026 8:32 pm
HCR666 wrote: Sat Mar 28, 2026 8:30 pm I was just wondering, you wouldn't happen to know of a way to convert .m2ts ultra HD 4K videos into a different more accessible format that is lossless?
Ahem, I believe "MakeMKV" can "make .mkv files"... if that's what you're interested in...?
I don't think I could find any part of MakeMKV that could convert video files? :?: :cry: I must be missing something but as far as I can tell it just seems to preserve/back-up videos from dvd's?
HCR666
Post by HCR666 »
