OK, but I would have expected you to have those rules already in your /usr/lib/udev/rules.d/50-udev-default.rules file, which is part of theLaurence5905 wrote: Sun Mar 29, 2026 9:10 pm I do have a file in there called 99-optical-permissions.rules, which I added yesterday in an attempt to fix this issue. The /dev/sr* devices were owned by root:root not root:cdrom so I kept getting permission errors trying to access them.
systemd-udev-258.7-1.fc43.x86_64Code: Select all
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", ENV{ID_CDROM_BD}=="1", SYMLINK+="bluray%n", ENV{GENERATED}="1"
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", ENV{ID_CDROM_DVD}=="1", SYMLINK+="dvd%n", ENV{GENERATED}="1"
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", ENV{ID_CDROM_DVD_RW}=="1", SYMLINK+="dvdrw%n", ENV{GENERATED}="1"
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", ENV{ID_CDROM_CD_RW}=="1", SYMLINK+="cdrw%n", ENV{GENERATED}="1"
SUBSYSTEM=="block", KERNEL=="sr[0-9]*", ENV{ID_CDROM}=="1", SYMLINK+="cdrom%n", ENV{GENERATED}="1"
