Public KeyDB Disc Submissions
HCR666
Post by HCR666 » Sat Mar 28, 2026 7:05 pm
hi there, sorry for the slow reply, I think I've updated the download file with the .tgz
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 7:16 pm
HCR666 wrote: Sat Mar 28, 2026 7:05 pm hi there, sorry for the slow reply, I think I've updated the download file with the .tgz
Errr, have you? Your first link still hasn't had its "Share" option updated, your second link is for your MKB_RO.inf file, and there is no third link???
HCR666
Post by HCR666 » Sat Mar 28, 2026 7:19 pm
i'll just send a new link, sorry about this!
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 7:26 pm
HCR666 wrote: Sat Mar 28, 2026 7:19 pm https://drive.google.com/drive/folders/ ... sp=sharing
Thanks, and these log messages indicate that your UHD drive has not enabled LibreDrive:
SDF  v0a5: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MZFP7IH1909
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 2U{2<P"^ib0vfW}i5:213130306
DEBUG: Code 0 at ek0A`ekmmj7(oPSno;:121264395
DEBUG: Code 4 at ek0A`ekmmj7(oPSno;:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
However, you also seem to have ripped your "Season 2 Disk 3" disk correctly, and so this is likely a transient problem. I suggest ejecting the disk, waiting for a bit and then reinserting it and trying again. Hopefully, MakeMKV will generate a usable TGZ file next time.
HCR666
Post by HCR666 » Sat Mar 28, 2026 7:34 pm
it does seem that one disk randomly works and then another doesn't so I suppose my only option is to eject eject eject until it works? (I'm not sure what a libredrive is unfortunately)
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 7:44 pm
HCR666 wrote: Sat Mar 28, 2026 7:34 pm it does seem that one disk randomly works and then another doesn't so I suppose my only option is to eject eject eject until it works? (I'm not sure what a libredrive is unfortunately)
It might help to wait until the disk appears in Windows File Explorer before launching MakeMKV.
The public KEYDB.cfg file only has a partial entry for the MKB20_v82_ARCANE_SEASON_TWO_DISC_TWO_7E25.tgz disk, and so we'd be interested in having a usable dump.
HCR666
Post by HCR666 » Sat Mar 28, 2026 7:49 pm
is that something I can help with?
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 7:54 pm
HCR666 wrote: Sat Mar 28, 2026 7:49 pm is that something I can help with?
Yes please :). When MakeMKV finally manages to enable LibreDrive for your "Arcane Season 2 Disk 2" disk, can you create a discatt.dat file for it please? Basically, use MakeMKV to start creating an encrypted disk back-up into a temporary directory, wait until the discatt.dat file appears (and it should be one of the very first files), copy it to a safe location and then abort the back-up.
HCR666
Post by HCR666 » Sat Mar 28, 2026 7:56 pm
is this time sensitive (like is it impossible once its fully complete?)? because makekv is currently managing to make a backup of episode two after a few tries, it's roughly half way through atm, could you give me suuuper clear instructions as to what you need form me aha
edit: Ive found the dispatt file, did you mean to say abort the backup only if I'd already backed it up? as in I can just copy this and continue the backup?
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 7:58 pm
HCR666 wrote: Sat Mar 28, 2026 7:56 pm is this time sensitive (like is it impossible once its fully complete?)? because makekv is currently managing to make a backup of episode two after a few tries, it's roughly half way through atm, could you give me suuuper clear instructions as to what you need form me aha
If you're already successfully creating a back-up of disk 2 then could you just grab a copy of the discatt.dat or discattd.dat file and upload it please? No need to interrupt anything :).
HCR666
Post by HCR666 » Sat Mar 28, 2026 8:02 pm
great, alrighty I've added that to the google file, let me know if I need to make a new link to share it aha
are there any other things you need from this season? do you mind if I ask what the discatt.dat file helps you with? (that's just a question out of curiosity more than anything aha)
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 8:26 pm
HCR666 wrote: Sat Mar 28, 2026 8:02 pm are there any other things you need from this season? do you mind if I ask what the discatt.dat file helps you with? (that's just a question out of curiosity more than anything aha)
Thanks, I'm hoping this is enough :). The discatt.dat file contains "disc attributes", which are extracted from the disk's "lead in" section before its UDF filesystem. The drive reads these attributes in while mounting the disk, and The Powers That MakeMKV/KEYDB need to know what they are before they can generate a database entry.
HCR666
Post by HCR666 » Sat Mar 28, 2026 8:30 pm
I see! Thanks for the help! Hopefully I'll be able to complete the rest of these disks.
I was just wondering, you wouldn't happen to know of a way to convert .m2ts ultra HD 4K videos into a different more accessible format that is lossless?
MrPenguin
Post by MrPenguin » Sat Mar 28, 2026 8:32 pm
HCR666 wrote: Sat Mar 28, 2026 8:30 pm I was just wondering, you wouldn't happen to know of a way to convert .m2ts ultra HD 4K videos into a different more accessible format that is lossless?
Ahem, I believe "MakeMKV" can "make .mkv files"... if that's what you're interested in...?
HCR666
Post by HCR666 » Sat Mar 28, 2026 8:40 pm
:shock:
would that maintain the ultra HD 4K quality? (how might I do that exactly? XD)
