Public KeyDB Disc Submissions
HCR666
#2101 Post by HCR666 » Sat Mar 28, 2026 4:55 pm
MrPenguin
#2102 Post by MrPenguin » Sat Mar 28, 2026 5:28 pm
HCR666 wrote: Sat Mar 28, 2026 4:55 pm adjusted link I think?
Thanks, that's the MKB_RO.inf file. Do you also have a TGZ dump file to share please? I expect KEYDB will need both files.
HCR666
#2103 Post by HCR666 » Sat Mar 28, 2026 5:33 pm
really sorry, could you tell me how to get that for you? I've only just started all this for this dvd set so im unfamiliar with everything aha
MrPenguin
#2104 Post by MrPenguin » Sat Mar 28, 2026 5:36 pm
HCR666 wrote: Sat Mar 28, 2026 5:33 pm really sorry, could you tell me how to get that for you? I've only just started all this for this dvd set so im unfamiliar with everything aha
Didn't MakeMKV generate a TGZ dump file? E.g. something like MKB20_v82_ARCANE_etc_XXXX.tgz? If it did, then the log output will tell you where it has been written to.
avaka_71
#2105 Post by avaka_71 » Sat Mar 28, 2026 6:09 pm
kasko wrote: Fri Mar 27, 2026 8:39 pm I've inserted it, is that okay now?
Thank you kasko. No it didn't work. Actually my mistake (the MKB_RO.inf was uploaded from a disk dump). Please find below the relevant files from the disk.
https://uploadnow.io/f/Wls1tb4
HCR666
#2106 Post by HCR666 » Sat Mar 28, 2026 7:05 pm
hi there, sorry for the slow reply, I think I've updated the download file with the .tgz
MrPenguin
#2107 Post by MrPenguin » Sat Mar 28, 2026 7:16 pm
HCR666 wrote: Sat Mar 28, 2026 7:05 pm hi there, sorry for the slow reply, I think I've updated the download file with the .tgz
Errr, have you? Your first link still hasn't had its "Share" option updated, your second link is for your MKB_RO.inf file, and there is no third link???
HCR666
#2108 Post by HCR666 » Sat Mar 28, 2026 7:19 pm
i'll just send a new link, sorry about this!
MrPenguin
#2109 Post by MrPenguin » Sat Mar 28, 2026 7:26 pm
HCR666 wrote: Sat Mar 28, 2026 7:19 pm https://drive.google.com/drive/folders/ ... sp=sharing
Thanks, and these log messages indicate that your UHD drive has not enabled LibreDrive:
SDF  v0a5: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MZFP7IH1909
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 2U{2<P"^ib0vfW}i5:213130306
DEBUG: Code 0 at ek0A`ekmmj7(oPSno;:121264395
DEBUG: Code 4 at ek0A`ekmmj7(oPSno;:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
However, you also seem to have ripped your "Season 2 Disk 3" disk correctly, and so this is likely a transient problem. I suggest ejecting the disk, waiting for a bit and then reinserting it and trying again. Hopefully, MakeMKV will generate a usable TGZ file next time.
HCR666
#2110 Post by HCR666 » Sat Mar 28, 2026 7:34 pm
it does seem that one disk randomly works and then another doesn't so I suppose my only option is to eject eject eject until it works? (I'm not sure what a libredrive is unfortunately)
MrPenguin
#2111 Post by MrPenguin » Sat Mar 28, 2026 7:44 pm
HCR666 wrote: Sat Mar 28, 2026 7:34 pm it does seem that one disk randomly works and then another doesn't so I suppose my only option is to eject eject eject until it works? (I'm not sure what a libredrive is unfortunately)
It might help to wait until the disk appears in Windows File Explorer before launching MakeMKV.
The public KEYDB.cfg file only has a partial entry for the MKB20_v82_ARCANE_SEASON_TWO_DISC_TWO_7E25.tgz disk, and so we'd be interested in having a usable dump.
HCR666
#2112 Post by HCR666 » Sat Mar 28, 2026 7:49 pm
is that something I can help with?
MrPenguin
#2113 Post by MrPenguin » Sat Mar 28, 2026 7:54 pm
HCR666 wrote: Sat Mar 28, 2026 7:49 pm is that something I can help with?
Yes please :). When MakeMKV finally manages to enable LibreDrive for your "Arcane Season 2 Disk 2" disk, can you create a discatt.dat file for it please? Basically, use MakeMKV to start creating an encrypted disk back-up into a temporary directory, wait until the discatt.dat file appears (and it should be one of the very first files), copy it to a safe location and then abort the back-up.
HCR666
#2114 Post by HCR666 » Sat Mar 28, 2026 7:56 pm
is this time sensitive (like is it impossible once its fully complete?)? because makekv is currently managing to make a backup of episode two after a few tries, it's roughly half way through atm, could you give me suuuper clear instructions as to what you need form me aha
edit: Ive found the dispatt file, did you mean to say abort the backup only if I'd already backed it up? as in I can just copy this and continue the backup?
MrPenguin
#2115 Post by MrPenguin » Sat Mar 28, 2026 7:58 pm
HCR666 wrote: Sat Mar 28, 2026 7:56 pm is this time sensitive (like is it impossible once its fully complete?)? because makekv is currently managing to make a backup of episode two after a few tries, it's roughly half way through atm, could you give me suuuper clear instructions as to what you need form me aha
If you're already successfully creating a back-up of disk 2 then could you just grab a copy of the discatt.dat or discattd.dat file and upload it please? No need to interrupt anything :).
