Greenland 2: Migration dump submitted
powrhaus
#1 Post by powrhaus » Tue Mar 17, 2026 8:58 pm
Just got the 4k disc today and it fails to open. Attached is the dump file.
Re: Greenland 2: Migration dump submitted
#2 Post by dcoke22 » Wed Mar 18, 2026 1:44 pm
Did you also email the dump to svq@makemkv.com so a hashed key can be made for it?
powrhaus
#3 Post by powrhaus » Thu Mar 19, 2026 9:25 pm
I didn't know that was part of the process. I'll do that now.
noworries1968
#4 Post by noworries1968 » Fri Mar 27, 2026 3:05 pm
Anyone gotten this disk to open???
MrPenguin
#5 Post by MrPenguin » Fri Mar 27, 2026 3:07 pm
noworries1968 wrote: Fri Mar 27, 2026 3:05 pm Anyone gotten this disk to open???
noworries1968
#6 Post by noworries1968 » Fri Mar 27, 2026 4:53 pm
MrPenguin wrote: Fri Mar 27, 2026 3:07 pm
Thanks, I will give it a try.
But isn't it supposed to download updates like this automatically?
I've bene using for years and it usually just downloads some file on the Mac named "_private", or some approximation thereof.
:D
MrPenguin
#7 Post by MrPenguin » Fri Mar 27, 2026 11:57 pm
noworries1968 wrote: Fri Mar 27, 2026 4:53 pm But isn't it supposed to download updates like this automatically?
There are two key databases, and the "hashed keys" inside _private_data.tar are indeed managed automatically. However, KEYDB.cfg is an alternative key database that MakeMKV can use, should the file be available in MakeMKV's data directory. The KEYDB.cfg file can often be updated more rapidly that the "hashed keys", and so it's worth having both databases available.
powrhaus
#8 Post by powrhaus » Mon Mar 30, 2026 8:56 pm
I tried to rip the disc again yesterday and it worked great. I noticed during the loading process it downloaded a new database and that one had the key. If you haven't tried in a couple of days, try again and it should work. If it still doesn't, your disc may be different and you'll need to provide a dump file for it.
